May 29th, 2019, 03:39 PM | #1 |
Join Date: Feb 2018 Motorcycle(s): 2012 ninja 250r Posts: 18
Turn signal bolt
I removed this turn signal bolt and when I try to replace the screw will turn forever and doesn't lock into anything. I checked my Clymer maintenance book and past threads on here and didn't find any solutions to this. Is there supposed to be a bolt on the other side? If so, I don't have one anymore. Any ideas?
May 29th, 2019, 04:32 PM | #2 |
There is supposed to be a metal piece, basically a plate, on the inside of the fairing that it screws into.
Part number 92200: https://www.bikebandit.com/oem-parts...4178#sch731569 It's possible that the plate fell off or got pushed out of position enough that you can't get the screw back into it. You may have to take off the fairing to see what happened to it.
bike * miles = smiles smiles / bike = miles smiles / miles = bike |
May 29th, 2019, 05:37 PM | #3 |
Thanks man
May 29th, 2019, 09:46 PM | #4 |
Yeah, reach in behind fairing and follow wire away from hole in fairing. Plate probably slid down to lowest part of wire.
May 29th, 2019, 10:13 PM | #5 |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
turn signal help | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 24 | February 25th, 2013 06:09 PM |
How to fix turn signal? | 47ninja | 2008 - 2012 Ninja 250R Farkles | 2 | May 18th, 2012 06:46 AM |
Turn signal problem!!! | danjaho | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 23rd, 2011 07:25 AM |
Turn signal went out, looking for a new turn signal | austinm911 | 2008 - 2012 Ninja 250R Farkles | 3 | January 23rd, 2011 08:58 PM |
