July 5th, 2011, 09:15 PM | #1 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
carb sync question
Ok wanna make sure I got this down before I do it tomorrow.. I've read the diy but just want to make sure..lol I got the bottles and hoses all hooked up, lines on the carbs are all setup.. basically I'm gonna warm the bike up, shut it down and hook the 2 vac lines up to the bottles. once started I'm gonna see the water go to one side or the other and if it does I'm going to adjust the screw until the water in the bottles stay even in both of them? Once it is shut it down and it will be synced?
#1 |
July 5th, 2011, 09:19 PM | #2 |
if everything is setup right with your sync setup, yes, that's the procedure.
July 5th, 2011, 09:23 PM | #3 |
Ridin Dirty
Ok cool..I never checked it when I did the shims, but now after rejetting and all I wanna make sure its running as good as possible. Can you feel when the carbs are out of sync by riding it or just periodically check it with the rig setup?
#1 |
July 5th, 2011, 09:26 PM | #4 |
once the carbs starts to get way out of sync, you can usually hear the engine rpms vary at idle at a rhythmic rate and the tach needle will dance around a bit instead of being rock steady.
July 5th, 2011, 09:28 PM | #5 |
Ridin Dirty
Ok good to know. Thanks
#1 |
July 6th, 2011, 07:51 PM | #6 |
Ridin Dirty
yeah it was out of sync.. as soon as i started the bike all the water pulled from one glass into the other.. the adj screw is very touchy, i turned it like a 1/4 of a turn and all the water went to the other glass..loL! took like 1/8 or even 1/16 adjustments to get it balanced out right.. all is snyced now though
#1 |
July 6th, 2011, 07:53 PM | #7 |
does it idle and run better?
July 6th, 2011, 08:41 PM | #8 |
Ridin Dirty
Honestly.. didn't notice much difference lol! Idle was steady before I did it and was running good..just wanted to check it cause I rejetted. Bike only has 750 miles too so fairly new.
#1 |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
carb sync | WELLS | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 19th, 2013 08:30 PM |
Carb Sync Question | cuz | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 28th, 2011 08:05 AM |
Carb Sync Question | tjb0012 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 25th, 2011 08:59 PM |
