June 20th, 2013, 03:18 PM | #1 |
Join Date: Sep 2012 Motorcycle(s): gsf1200, gsxr750, r6, gpz400, gpx400r, zx6d Posts: 21
zzr 250 forks
hey been searching the web for information on the zzr as i got one that is in need of repair. i know parts are scarce due to the fact they only sold them in canada for a few years. any zzr people one here
June 20th, 2013, 03:28 PM | #2 | |
Join Date: Jan 2013 Motorcycle(s): Ninja 300R Posts: 181
and it says "The main differences are an aluminum perimeter frame, adjustable levers, adjustable rear preload, totally different bodywork and instruments, much larger front brake, integrated turn signals, and EX500 37mm forks. " hope that helps |
June 20th, 2013, 04:06 PM | #3 |
i know they are 37mm but did kawi use the same forks, i know that kawi likes to reuse and recycle parts. there is not much info in the wiki as i have looked there already
June 20th, 2013, 04:21 PM | #4 |
well since the wiki says the ex500 and the zzr250 are the same forks, you could like cross reference the forks in a parts catalog of both bike, same part # = same part
June 20th, 2013, 05:21 PM | #5 |
ya i been looking at parts fiche also but sometimes they change the pn for suttle differences even color can make a item a different part number. i have a work college with a second gen 500 parts bike that will sell me the forks so i can take them and check if they work with all the zzr bits.
June 20th, 2013, 06:16 PM | #6 |
Even if the forks aren't identical part numbers, who cares? They're both the same OD and they're both damper rod forks. Just swap the springs, change the oil (and fill to spec for the ZZR), and you're good to go.
Knowing Kawi, they're identical forks, just maybe different spring rate/oil thickness/oil height. |
June 20th, 2013, 07:28 PM | #7 |
Join Date: Sep 2012 Motorcycle(s): zzr250 gt650r zxr250 ninja 300 Posts: 114
do an USD conversion like me
June 22nd, 2013, 03:54 PM | #8 |
this is a budget build.. lol
June 22nd, 2013, 05:35 PM | #9 |
fair enough mate
June 29th, 2013, 01:15 PM | #10 |
so for anyone that finds this thread ignore all the internet geniuses that have posted and i can tell you only thing that the 500 and the 250 zzr share in common is fork diameter and maybe spring rate. now what is different..
the zzr runs a full floating rotor that is larger so the brake will not mount as it seems the ears on the 500 fork are not in the same place as the 250. the front fender mounts are totally different the damper rod bolt is a m8 on the 250 and a m6 on the 500 the top plug on the 250 is thread in not held with a clip (no biggie) |
Sweet ZZR 250 | Ninjinsky | General Motorcycling Discussion | 15 | October 7th, 2014 01:11 PM |
ZZR-250 Forks? | htdub | 1986 - 2007 Ninja 250R Tech Talk | 3 | June 21st, 2012 12:20 PM |
looking for a ZZR 250 frame. | Racer x | 1986 - 2007 Ninja 250R Tech Talk | 4 | June 20th, 2011 10:43 AM |
