August 5th, 2009, 12:22 PM | #1 |
Run Both Headlights?
I didn't see a DIY anywhere for this, has anyone done this one yet? I'm going to install some halo rings so I figured I would do this too. Seems to me it's as simple as running both lights off of the lowbeam wires and taping off the highbeam only. If no one has done it yet, let me know and I will post pics and instructions.
It's not worth doing if you aren't completely stressed out about it. |
August 5th, 2009, 12:26 PM | #2 |
Sounds like a cool mod but I am not sure that the generator can handle the load of both high and low beam at the same time.
August 5th, 2009, 12:28 PM | #3 |
It should if both lights operate in high beam mode. They do don't they? I never got off of my bike to look.
August 5th, 2009, 12:41 PM | #4 |
Join Date: Jul 2009 Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased) Posts: 855
they do.. i've checked
i'd like to see this project
August 5th, 2009, 12:57 PM | #5 |
ummm... so what 's wrong with just leaving the highbeam light switch in the on position?
you might want to be able to turn off the highbeam someday. |
August 5th, 2009, 01:22 PM | #6 |
Track Junkie
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike Posts: 602
you might even run across someone who won't pass your inspection
Las Escobas -- Track Bikes Save Lives JonBroom.com |
August 5th, 2009, 01:25 PM | #7 |
hmm sounds like some valid points, any other ways it could be done?
August 5th, 2009, 02:14 PM | #8 |
You could wire then into a seperate switch independent of the high/low switch.
August 5th, 2009, 02:21 PM | #9 |
Track Junkie
i'm confused, are you trying to change your stock light setup, or add additional lights?
August 5th, 2009, 06:14 PM | #10 |
FORMER MOTORCYCLE RIDER
Join Date: Dec 2008 Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10 Posts: 758
One light will always be brighter than the other...it's the reflector that is different between the bulbs.
August 5th, 2009, 06:23 PM | #11 |
Join Date: Jul 2009 Motorcycle(s): '09 Blue 250R Posts: 446
You go ahead and activate both your lights thinking its a cool idea, then get caught in some fog on the way home from a trip. When your staring at a bright white sheet of fog 5 feet in front of you, you can remember it was me that told you not to mod your bike like this. Having the option of only 1 light on low beam is important, it helps keep the road lit, but also minimizes the amount of reflection of fog blinding your sight.
2 thumbs up |
August 5th, 2009, 06:36 PM | #12 | |
Join Date: Jan 2009 Motorcycle(s): 2015 Ninja 300 (Sold), 2016 Z1000 Posts: 239
Maybe it wasn't thick enough. |
August 5th, 2009, 07:24 PM | #13 |
From my own experiences in a car, low beams work better for me in fog. I decided to do a quick google and came up with this...
http://www.mto.gov.on.ca/english/saf...s/badfog.shtml edit: http://bcrider.com/lowtraffic.html <-- this website is specific to motorcycles and concurs with my point.
2 thumbs up |
August 5th, 2009, 07:40 PM | #14 |
Looks like these people are driving in a cloud. |
August 5th, 2009, 07:45 PM | #15 |
yea i agree with dimeified. cars also have fog lights for these reasons
August 5th, 2009, 09:07 PM | #16 |
Join Date: Jun 2009 Motorcycle(s): 2009 Blue Ninja 250R Posts: 68
I wouldn't mess with it personally. Wouldn't it also blind oncoming drivers? I don't think its a wise idea.
August 6th, 2009, 12:13 AM | #17 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Candy Plasma Blue Posts: 129
Like kkim said both lights are on when you turn on the highbeams, no mod needed.
August 6th, 2009, 03:36 AM | #18 | |
Join Date: Aug 2009 Motorcycle(s): what else? Posts: 121
When I had my low beam with xenon bulb and high with alogen (wich is shorter) the light reached at the same distance. |
August 6th, 2009, 05:11 AM | #19 | |
IC2(SW)
August 6th, 2009, 09:25 AM | #20 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
? Why would anyone want PERMA-High Beams anyways?, personally I like the option to turn them on or off as it suits me oO
August 6th, 2009, 09:32 AM | #21 |
Im not even sure what the original question/idea was anymore
August 6th, 2009, 01:30 PM | #22 |
IC2(SW)
August 6th, 2009, 04:37 PM | #23 |
At some point people stopped understanding my original intent - Modify the lights so that both lights are on at all times, NOT highbeams at all times. The modification looks to be quite simple; just using the low beam wire for both lights. The relay switches the low beam light to high beam and simply shuts off the high beam in low beam mode. So, just tape off the high beam wire. The switch will server the same function, just that both lights will always function.
August 6th, 2009, 04:40 PM | #24 |
IC2(SW)
^ But you have a high beam bulb & a low beam bulb, there not dual filments like an H-4.
August 6th, 2009, 06:16 PM | #25 |
the bulbs are both 55 watt,it's the reflectors behind the bulbs that make one seem brighter than the other
August 6th, 2009, 06:45 PM | #26 |
interesting, i just want to see the halo rings when your done, is there a DIY for this or are you doing that also?
August 6th, 2009, 07:20 PM | #27 |
You can buy HID projectors with angel eyes from F-Sane on Kawiforums. Then you will have two lights on all the time and when you switch to high beam a flap moves to increase the light output.
It is not cheap and it requires slot of modifications to the headlight housing but the light output is amazing. Posted via Mobile Device |
Headlights | ChaoSS | 2008 - 2012 Ninja 250R Tech Talk | 20 | June 14th, 2016 08:14 PM |
Adjusting headlights? | uKER | 2013 - 2017 Ninja 300 Tech Talk | 2 | July 8th, 2013 07:50 PM |
LED Headlights | TnNinjaGirl | 2008 - 2012 Ninja 250R Farkles | 39 | July 31st, 2012 04:42 AM |
HID headlights | eddiekay | 2008 - 2012 Ninja 250R Farkles | 86 | October 24th, 2011 04:52 PM |
Ninja-Headlights | AyMarcus | New Members | 13 | September 21st, 2011 07:24 PM |
