Old July 19th, 2014, 04:32 PM   #1
Rassie
Motorcycle bon vivant...
Rassie's Avatar
Motorcycle(s): 300 Ninja, 250R Ninja, SV650S, CB350, GT750, Aprilia RS250, Triumph Street Triple R
Rotor bolt hole spacing and pattern.
Anyone here know what 300mm disc brake rotor is compatible with the 300 Ninja. I am in the middle of a ZX6R front end swap and the only item I am still unclear on is the rotor. The stock one is 290mm just a tad to short for the ZX6R caliper. Either that or I will have to machine 5mm of the mounts so I can use the stock rotor.
I am planning on running the stock wheel with only one brake caliper. I will chop the left hand side brake caliper mounts off and smooth out the fork lower.
NESBA 13, 300 Ninja, 250r Ninja, 06 SV650, Ninja ex250, CB350, CL90 ,GT750, Aprilia RS250, Triumph Street Triple R www.mybikeproject.com
Rassie is offline   Reply With Quote
Old July 19th, 2014, 06:20 PM   #2
garth285
KAWASAKI GURU
garth285's Avatar
I had to do that on my ZX10. I wound up bringing my caliper to a machine shop and they shaved 5mm off.
Cant help you with any bolt pattern info, sorry!
Old July 22nd, 2014, 07:58 AM   #3
bruce71198
bruce71198's Avatar
Why not get a 300mm rotor off eBay or better yet a 320mm the added braking power would be nice. Also I think the brake pads on the new caliper are to wide for the stock rotor.
Old July 22nd, 2014, 08:05 AM   #4
Rassie
Rassie's Avatar
I will get one off eBay if I can figure out which 300mm one is compatible so I know what to buy. Hence the ask of anyone who knows which other Kawi models have compatible bolt pattern to the 300.
Old August 23rd, 2014, 03:33 PM   #5
Rassie
Rassie's Avatar
To close this thread out. I went with the stock 290mm rotor. I shortened the caliper mounts on the fork I was using, this had the same net effect as using a larger rotor.
Front rotor bolt replacement pdxdavid 2008 - 2012 Ninja 250R Tech Talk 8 September 19th, 2013 07:15 PM
Rear sprocket bolt pattern cuong-nutz General Motorcycling Discussion 7 August 20th, 2013 08:20 PM
Bolt pattern for custom F/E Little Green Machine General Motorcycling Discussion 2 September 8th, 2012 04:27 PM
[twisted throttle] - What is the AMPS Hole Pattern? Ninjette Newsbot Motorcycling News 0 September 22nd, 2011 01:40 PM
lowering link hole spacing mhesse General Motorcycling Discussion 4 March 23rd, 2011 06:29 PM
