Old September 26th, 2013, 09:00 AM   #1
jenndiggity
jenndiggity's Avatar
Motorcycle(s): Black 2011 Ninja 250R
my front end jiggles
If I take my hands off the handlebars the front end jumps/dhskes a little. What could it be?
jenndiggity is offline   Reply With Quote
Old September 26th, 2013, 09:22 AM   #2
cuong-nutz
cuong-nutz's Avatar
tire following imperfections in the road.
You had too much weight on the handle bars and shifted the weight back which makes the front end get lighter. Some people don't know it but one hand may leave the bar faster or later than the other which in turn may slightly push the bar forward or pull the bar back and induce a small shake/wobble. Decelerating and accelerating makes it worse too.
It's just my guess.
Other factors, forks are twisted or not aligned with the triples. Unbalanced wheel/tire. Bent wheel. Worn tire, overinflated/underinflated tire, stem bearings loose.
HalfFast Racing Team
Old September 26th, 2013, 10:10 AM   #3
Panda
not an actual panda
http://www.ninjette.org/forums/showt...nt+end+wobbles
Old September 26th, 2013, 02:56 PM   #4
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
To sum it up, i believe it's innate with our bike at lower speeds.
broilmebk is offline   Reply With Quote
Old September 26th, 2013, 04:42 PM   #5
It could be many things, Jennifer, but is normal for many of these bikes.
It is recommendable not to take both hands of the handlebar, since they work as shock absorbers, together with those weights at both ends of that bar.
If you feel a stronger effect at high speeds, even with both hands on it; then you will need to worry, as those oscillations could rapidly grow and become a dangerous tank-slapper.
The good condition and adjustment of the bearings of the steering column, wheels and swingarm and of the chain and brakes, as well as the proper balance and pressure of the tires will always help reduce those annoying oscillations.
If it really bothers you now, try regulating the shock absorber to be a little higher, if it is not adjusted too hard as it is now, ......that may help.
Old September 26th, 2013, 05:25 PM   #6
Galaxieman
Galaxieman's Avatar
Motorcycle(s): 2008 Ninja 250, 2009 Concours 14
I'm on another forum with a sub-group called the Mind In The Gutter Club... and this post title is straight up their alley.
Sorry... I couldn't resist
That said, unless the wobbles get stronger as speed increases, it's not anything to be significantly worried about.
Igitur qui desiderat pacem, praeparat bellum...
Galaxieman is offline   Reply With Quote
Old September 26th, 2013, 08:12 PM   #7
jenndiggity
Thumbs up
Thanks guys!
Old October 1st, 2013, 08:40 AM   #8
JAG
Motorcycle(s): 2010 Kawasaki Ninja 250
a similar problem and loosened and retightened
Lower fork bolts as stated in the manual for adjusting
Steering. There shouldn't be any wobble at all even with driving
One handed etc.
Last futzed with by JAG; October 1st, 2013 at 10:55 AM.
JAG is offline   Reply With Quote
Old October 1st, 2013, 10:50 AM   #9
i say pics or lies.
Old October 1st, 2013, 07:08 PM   #10
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
i say vid or lies.
^Fixed
Upgraded front suspension, front end tuck Ginganinja 1986 - 2007 Ninja 250R Tech Talk 12 October 30th, 2014 10:27 AM
front end work fred smoot Ninjettes At Speed 3 August 5th, 2014 12:58 PM
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal 1LoneWolf Items Wanted 3 July 8th, 2013 02:50 AM
front end chatter... joseg1981 Ninjettes At Speed 94 June 5th, 2013 07:21 AM
Hey all. Q's about front end... Kilometers07 2008 - 2012 Ninja 250R Tech Talk 2 April 22nd, 2012 04:37 PM
