Old May 8th, 2009, 04:40 PM   #1
DirtyBoy
DirtyBoy's Avatar
Higher mileage 08-09's
Just curious how many of you have over 10k+ miles on your bikes. Any mechanical issues? What type of maintenance besides fluid changes have you done? I have 14,921 miles with zero problems (bought brand new with 1 mile). I've replaced 2 rear tires and 1 front(not needed), changed front brakepads twice and rear once(not needed). I also just replaced the chain and sprockets and rear taillight bulb. I have a fork seal that needs to be replaced as well as the shifter linkage boot. I will be checking everything else when I do my own 15k mile service.
49T sprkt/ EK gold chain/ Galfer pads and SS lines/120 frt 150 rr Pilot Powers/ GSX-R can/Desnorkled/ Raised needles/ Slider spools/ Cowl/ LED rear signals/ Fender eliminator/ Tinted lights / Emu seat
DirtyBoy is offline   Reply With Quote
Old May 9th, 2009, 02:37 PM   #2
Bill N
Motorcycle(s): 250 Ninja
Dirty boy,
Did you have valves checked/adjusted?? If so how much were they out of tollerance.
Thanks, Bill
Bill N is offline   Reply With Quote
Old May 10th, 2009, 04:06 PM   #3
DirtyBoy
DirtyBoy's Avatar
Originally Posted by Bill N View Post
Dirty boy,
Thanks, Bill
I am very ashamed to say that I never checked or adjusted them Hopefully no damage has been caused but I will soon find out. I was going to to it myself but I found a shop that will do it for $150 so im going to go with that since just the shim kit is $90. saving $60 is not worth my time.
Old May 10th, 2009, 04:10 PM   #4
DirtyBoy
DirtyBoy's Avatar
I aslo just realized that I have had 1 issue with the gas gauge but that mysteriously fixed itself after about a week. The gremlin that caused it must have fell off the bike.
Old May 12th, 2009, 10:10 AM   #5
GreezMunky
GreezMunky's Avatar
Motorcycle(s): 09 250r (*sold*), 2010 Daytona 675
I have 14.3k on my 09. No issues except for the gas gauge but that was within the first 200 miles. All I've had to change was both tires. Brake pads are next but I was told to wait until 15k. Had them checked out at 11.3k and they said they were fine.
DB, what's the deal with replacing "I also just replaced the chain and sprockets and rear taillight bulb. I have a fork seal that needs to be replaced as well as the shifter linkage boot." I've never had any issues whatsoever with mine.. You're making me nervous here, lol.
GreezMunky is offline   Reply With Quote
Old May 12th, 2009, 05:41 PM   #6
DirtyBoy
DirtyBoy's Avatar
All that stuff is pretty routine maintenance stuff. My old chain needed to be adjusted at least once a week when I hit about 13k so I decided to replace it. Sprockets looked ok but I wanted to go up a few teeth in the back. The front sprocket was only $11, so I figured I might as well get a new one since everything was being replaced. I didn't notice the fork seal leaking until after the new sprocket went on, so i'm assuming I blew it doing a wheelie. The rubber boot is from my shoe rubbing on it, so depending on where your foot rubs that may not be an issue for you. 14k+ miles on an 09 is pretty impressive.
Old May 13th, 2009, 02:24 PM   #7
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
One thing: over on http://forums.ninja250.org/ someone posted a step-by-step log of the process involved with adjusting the newer Ninja's shim & bucket valves. Wow. It is a LOT more complex than the old Ninja. Now, mind you it doesn't need to be done nearly as often, but it's a job that is way beyond most do-it-yourselfers.
Old May 13th, 2009, 02:31 PM   #8
similar to this???
http://www.ninjette.org/forums/showthread.php?t=9787
http://www.ninjette.org/forums/showthread.php?t=9924
How to make seat HIGHER? BRad704 2008 - 2012 Ninja 250R Farkles 13 May 15th, 2013 06:16 PM
Idle goes higher when on kickstand zedzedR 1986 - 2007 Ninja 250R Tech Talk 9 March 16th, 2013 06:33 PM
Dies at higher speeds/slowing down from higher speeds TheFranchise216 1986 - 2007 Ninja 250R Tech Talk 67 April 20th, 2012 01:13 PM
Higher RPM Problems!! cameronatkinson 2008 - 2012 Ninja 250R Tech Talk 5 August 17th, 2011 06:47 AM
higher than normal idle speed? kyle98927 2008 - 2012 Ninja 250R Tech Talk 17 July 29th, 2009 01:03 PM
