December 5th, 2023, 11:15 AM | #1 |
[webbikeworld.com] - CFMoto Recalls Certain 2022/2023 700CL-X Models over ABS Glitch*
Click here for full story...
If you have a CFMoto 700 CL-X made between January 20, 2022 and February 2, 2023, then you might want to consider getting the thing checked for delayed braking.* Apparently, certain models show a latent ABS braking response when the bike’s handle is pumped more than twice. While this is a common enough occurrence for this to be a serious matter, rest easy – CFMoto has determined that the issue, while indeed serious, will probably only affect braking time by about 0.3 seconds.* Here are the VIN range of 700 CL-Xs affected:*
Should you find yourself with a machine that falls in the above VIN range, we’re told that reparation will be performed at a dealership, where an update to the ABS system will provide* a simple enough solution (CFMoto recommends using the DSCAN diagnostic system). A view of a CFMoto 700 CL-X. Media provided by CFMoto.Got a DSCAN diagnostic?* Here are the steps that CFMoto says will be required in order to fix your 700 CL-X/Sport’s ABS system:*
CFMoto Customer Service Hotline
The post CFMoto Recalls Certain 2022/2023 700CL-X Models over ABS Glitch*& Delay appeared first on webBikeWorld.
[ridermagazine.com] - 2022 CFMOTO 700CL-X | Road Test Review | Ninjette Newsbot | Motorcycling News | 0 | December 1st, 2022 11:15 AM |
[motorcyclistonline] - 2022 CFMOTO 700CL-X/700CL-X Sport | Ninjette Newsbot | Motorcycling News | 0 | November 2nd, 2022 03:11 PM |
[cycleworld.com] - 2022 CFMOTO 700CL-X/700CL-X Sport | Ninjette Newsbot | Motorcycling News | 0 | November 2nd, 2022 03:11 PM |
[motorcycle.com] - 2022 CFMOTO 700CL-X / 700CL-X Sport Review – First Ride | Ninjette Newsbot | Motorcycling News | 0 | July 18th, 2022 10:50 AM |
[cycleworld.com] - 2022 CFMoto 700CL-X and 700CL-X Sport First Ride Review | Ninjette Newsbot | Motorcycling News | 0 | July 10th, 2022 10:32 AM |
