Old March 14th, 2012, 05:56 PM   #1
cuong-nutz
cuong-nutz's Avatar
Single LED turn signal does not work.
Went down at the track and broke my front turn signal. I have some old dual led pods and I am using one to replace the turn signal. I have it connected but it doesn't flash. It just stays lit.
What size diode do I need?
HalfFast Racing Team
Old March 14th, 2012, 10:27 PM   #2
lc86
lc86's Avatar
Motorcycle(s): 2010 Ninja 250r (RIP)
Do you have LEDs all around or just in the front. If you just have them in the front all you need is to hook up a resistor since the power draw from the led isn't enough to activate the stock relay. A 8-10 ohm resistor should solve the problem.
If you have LEDs all around, just go to this thread and the ~4th post from the bottom has pics and such for the diode installation for all around LEDs.
http://www.ninjette.org/forums/showthread.php?p=43426
lc86 is offline   Reply With Quote
Old March 14th, 2012, 10:42 PM   #3
cuong-nutz
cuong-nutz's Avatar
It's just one turn signal. I'll give the resistor a try.
Old March 14th, 2012, 10:53 PM   #4
lc86
lc86's Avatar
Thats a unique setup Basically though, since the led draws such little power the stock relay will treat it as an open. Installing a resistor should correct this issue. You can also change the flash rate by adjusting the resistance, so if it starts flashing faster than you like, just use a larger resistor.
Oh yeah, if you haven't done it before, just make sure its in parallel. Kind of like in this pic, the top example. http://img.diytrade.com/cdimg/147967..._RESISTORS.jpg
Old March 14th, 2012, 11:02 PM   #5
cuong-nutz
cuong-nutz's Avatar
Yeah I need a workin light to pass inspection. Function over form any day lol
Old March 16th, 2012, 01:35 PM   #6
cuong-nutz
cuong-nutz's Avatar
Installed a 10 OHM 10 AMP resistor and it's flashing now. It's a tad faster than normal but it will get the job done. Thanks again!
Old March 16th, 2012, 08:20 PM   #7
lc86
lc86's Avatar
Dont mention it, and like I said before, if you want to adjust the flashing so that it is slower just use a larger resistor, like a 15 or 20 OHM.
LED Turn Signal problems nestlesnipes 2008 - 2012 Ninja 250R Tech Talk 2 February 8th, 2014 11:33 PM
will this turn signal work skateboarder1210 2008 - 2012 Ninja 250R Farkles 12 June 29th, 2011 08:52 PM
LED Turn Signal wires? shaun2891 2008 - 2012 Ninja 250R Farkles 3 November 24th, 2010 07:49 AM
LED turn signal problems shadowskater 2008 - 2012 Ninja 250R Farkles 12 August 14th, 2010 03:08 PM
Went down, now turn signal won't work subiegy2010 General Motorcycling Discussion 14 March 18th, 2010 12:12 PM
