#1 |
Join Date: Dec 2009 Motorcycle(s): 2009 Ninja 250R Black - Sold / 2011 Honda CB1000R Posts: 176
Resetting CCT while on the bike
I have a ticking noise off of throttle as seen in a previous thread. My first attempt to fix is of course to reset the CCT, being the cheapest easiest thing to try first. However, I cannot find the gasket anywhere that isn't a week and a half out. In an effort to forgo an leaks I was gonna trying resetting the CCT while on the bike, leaving the (2) 8mm bolts secured. I had read someone else saying they had done the reset on the bike.
After doing some reading and looking at the service manual it appears I can do the following and achieve the same resetting as if I were to remove the entire CCT. (1). Bike is off and in neutral (2). Remove right fairing (3). Remove center 10mm bolt/cap (4). Use a flat blade screw driver,alot of pressure, and turn the center screw clockwise until it stops. This should retract and reset the CCT, correct? Then by removing the screw driver the CCT rod will extract back contacting the timing chain. Or do you need the extra force on the CCT Rod end to retract the rod? As seen here http://www.ninjette.org/forums/showthread.php?t=50930 I guess I'm asking if anyone else has done the reset this way? It may indeed be alot easier to pull the CCT, reset, and reinstall. I'm just trying to totally eliminate the possibility of the gasket leaking. None of the Kawi dealerships have either the CCT or gasket. I suppose I always have some gasket material and silicone if it does leak.
2009 Black 250R - Stock and staying that way. No matter what you do it's still a 250 at the end of the day! Save your money for gear, riding lessons, & a 600cc |
#2 |
Join Date: Jun 2011 Motorcycle(s): 2007 Kawasaki Ninja 250R (EX250F) Posts: 50
Sorry, I'm of no help, but what does CCT stand for?
#3 |
Camshaft Chain Tensioner
#4 |
Thanks!
#5 |
Yup. That's how you "reset" the cct. But I can tell you the click will be back. Same thing with a new cct. From what I can gather the kawi-click is something you'll just have to live with. Buy a mgp growler and that pesky click will be gone
http://sandollarmotorcycleclub.com/ |
#6 |
Be mindful of the torque specs on that cct!
#7 |
Thanks.
I'm hoping it's just a noisy Kawi motor but I'm not sure since I haven't fully checked everything. I only have 12,000 miles but I ride this little thing like I stole it. My baffled HMF Slip-on doesn't muffle the noise very much either. Valves are all within spec and I don't believe it fits the old-gen related clutch basket noise. The baskets also appear to be different from old to new gen. Only reason I am further investigating is to make sure there is no mechanical issues. I am looking to sell the bike next year and I would never want to hand something serious down to an unsuspecting buyer. BTW Bob, I seen you had performed the reset and the noise went away. Did yours return in sometime as well?
#8 | |
#9 |
Interesting, thanks a lot for the fast response!
#10 |
just think of it as a sign of quality. ever hear a ducati? nastiest sounds i've ever heard from that dry clutch
#11 |
People act like the "click" sound is normal, but what if mine sounds like a horrible rattling chain? Its "horrible" when starting cold but eventually seems to settle down until I rev in neutral and I hear it come back for several seconds even after RPMs fall, as if I disturbed the loose chain and it takes a few seconds before everything falls back in place.
#12 | |
There is one sound that is normal among CV type carbs however It tends to get overlooked...slide rattle, which can be heard more at idle and tends to go away when throttle is applied. Even though we have Keihin carbs this info about slide rattle from Mikuni may help a little since they work similar. http://www.mikuni.com/c-faq.html Also some info from Factory Pro. http://www.factorypro.com/tech/needle_jet_wear.html |
#13 |
Is there audio/video of the sound?
Also, if it is the CCT, consider getting a manually adjusted one. I have one and won't go back. Just be careful not to over-tighten it. This where I got mine: http://zxzone.com/tensioners.html
#14 | |
Where to get a Manual CCT? | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 17 | August 21st, 2013 11:59 AM |
WTB: new or used CCT | NinjaBoyEddy | Items Wanted | 8 | January 19th, 2013 07:31 PM |
Shift lever not resetting | Malicious Logic | 2008 - 2012 Ninja 250R Tech Talk | 13 | August 5th, 2012 06:35 PM |
CCT Removal | menikmati | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 3rd, 2012 01:51 PM |
is it my cct? | alex.s | 2008 - 2012 Ninja 250R Tech Talk | 3 | November 8th, 2011 09:40 AM |
