Old April 8th, 2013, 10:12 AM   #1
bjl4776
Fuel tank venting issue
Im having a problem with fuel flow on my ninja. The past 2 times ive filled the tank up its ran fan until just below half a tank. Ill be running great at 60 or so and then she'll lose power. Ill pull over and notice my fuel filter is empty. The first time I switched it from on to prime as well as opened up the tank. Ive left it on prime since then and it happened again. Opening that cap allowed flow. The vent line is clear and the vent hole in the cap itself seems to be clear as well. Anybody have any ideas?
bjl4776 is offline   Reply With Quote
Old April 8th, 2013, 10:16 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Drill a few vent holes in the top of your tank
AFM #676
Supersports are for n00bs
Old April 8th, 2013, 10:49 AM   #3
just ride with your gas cap open
Old April 8th, 2013, 11:15 AM   #4
mlj2093
Motorcycle(s): 2011 Kawi 250 SE
2 very helpful solutions right there.
mlj2093 is offline   Reply With Quote
Old April 8th, 2013, 11:19 AM   #5
Joshorilla
Bass Master General
Joshorilla's Avatar
I've heard of people drilling the vent hole bigger.
Old April 8th, 2013, 01:41 PM   #6
bjl4776
I did notice that the rubber gasket on the cap is cracking. If anything that should make it vent more, but I dont know if that cap works in any kind of fancy way.
Old April 15th, 2013, 09:07 AM   #7
Yeah, but they do that to stop the whistle.
There was a big thread where people determined that fuel filters with specs that shouldn't have been an issue, were. Also, it has happened to me several times and I have no added fuel filter. It only happens when I am at about half a tank or lower and parked for ~15 minutes after reaching full operating temps, and then ridden off (dies a couple blocks later).
new gen gas tank venting issues wardie 2008 - 2012 Ninja 250R Tech Talk 6 March 20th, 2015 03:13 PM
[motorcycle-usa.com] - Harley-Davidson Recall for Fuel Tank Issue Ninjette Newsbot Motorcycling News 0 April 30th, 2014 07:30 AM
Fuel tank/Fuel gauge issues coolcatjames 2008 - 2012 Ninja 250R Tech Talk 10 August 23rd, 2012 06:25 PM
