Old July 5th, 2010, 01:29 AM   #121
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
Yea took the tire off now. Surprisingly easy with the chain. Just loosened the rear axle, took it out and pushed the tire a little forward and the chain was completely loose. Didn't touch the chain tensioner at all, don't know why I was thinking i had to.
Edit. Easy to get the chain back on also. Great DIY once again Kelly!
Bridgestone 140/70, love it!
Last futzed with by Guinss; July 6th, 2010 at 01:21 PM.
Guinss is offline   Reply With Quote
Old October 18th, 2010, 04:47 AM   #122
g21-30
g21-30's Avatar
The only comment I have is when putting the rear wheel back on, I could not for the life of me get the rear caliper to line up properly while juggling the tire and axle all at the same time. I must have worked on this for a good half hour before I found a solution. I couldn't believe how easy it was to assemble the rear wheel once I tried it. Instead of inserting the axle from the left side of the bike, insert it from the right side and use the axle to keep the brake caliper in place as you line up the rest of the wheel and axle properly.
Over the weekend, I changed my rear/front tires to the BT-016s (150/60/17) and (110/70/17) using this DIY. The one difference is I found a way to install the rear axle from the LEFT side, just as it comes from the factory. The secret is to place a 4"X4"X22" (why 22"? Because I had 2 of those already cut.) under the tire. I then used my harbor freight tire tool as a lever under the tire/wheel assembly to raise the tire up, while sliding the axle in from the LEFT side!
Here's the tire tool I used:
One other note, my chain guard touched the new tire, so I placed a 3/16" thick washer (actually a cantilevered brake washer off one of my grand children's bike) between the chain guard and it's mounting hole. That resulted in the chain guard clearing the tire by about 1/2".
Old October 18th, 2010, 10:42 AM   #123
headshrink
headshrink's Avatar
That is so simple, it is genius.
Old October 18th, 2010, 05:31 PM   #124
Cuongism
Cuongism's Avatar
Haha, I wish you posted that a couple of weeks ago. I dremeled a notch into the chain guard.
Old October 19th, 2010, 03:29 AM   #125
g21-30
g21-30's Avatar
^^^Exactly what I was going to do, until I saw how much it flexed with hand pressure!
Old October 25th, 2010, 09:58 AM   #126
CZroe
CZroe's Avatar
I only have a socket for the axel bolt side and not the axel nut side. Does it matter which end I torque the rear axel from?
Old October 25th, 2010, 10:04 AM   #127
I've always torqued nuts, not bolts, because the bolt shank has friction loads on it that the nut does not. If you torque the bolt you could get a false reading.
This is just IMHO. I have no reference for this.
Old October 25th, 2010, 10:09 AM   #128
dubojr1
dubojr1's Avatar
There's not a whole lot of science to this anyway. Seems that every time I torque an axle nut, it never falls on the alignment hole to insert the pin. You have to decided whether to go forward or back off a bit to align the hole. All tend to go forward.
Old October 26th, 2010, 12:26 PM   #129
CZroe
CZroe's Avatar
WTH am I doing wrong?! I can't get the tire back onto the rim. I get one sidewall over and it looks very much like kkim's pic with the remaining sidewall very close to the rim, but I can not for the life of me finish getting the second sidewall over. I start it and make my way around but eventually each pry I make makes an equal or larger part of the sidewall slip back out on the other end. Also, by that point, the remaining sidewall has risen inches above the rim! It's very frustrating. I've been prying and slipping and cursing and sweating all morning.
Old October 26th, 2010, 12:37 PM   #130
dubojr1
dubojr1's Avatar
Front or rear?
Old October 26th, 2010, 01:09 PM   #131
CZroe
CZroe's Avatar
Originally Posted by dubojr1 View Post
Front or rear?
Both. I now have this to show for it.
As many times as I slipped and damaged the rims (even with protectors), i guess it was only a matter of time.
Old October 26th, 2010, 01:38 PM   #132
dubojr1
dubojr1's Avatar
Attachment 9744
Attachment 9743
Wow! That looks like it would hurt.
Do a YouTube search for "scudman" and look for his removing and mounting video. I found these helpful when I started changing my tires. I can change one now start to finish in about 5 mins. I hope your working with good tools though. Makes a ton of difference. I picked up a 3 piece tire iron set at cycle gear. Work perfect.
Don't give up. You'll get it. It sounds as if you need to keep good pressure on the sidewall closest to you with your knee's while you slowly take small bites of tire and pry it over.
Old October 26th, 2010, 01:43 PM   #133
headshrink
headshrink's Avatar
Wow, that's funny... I was just going to say the same exact thing. It was these videos, along with Kelly's DIY that gave me the confidence to do it.
Old October 26th, 2010, 01:55 PM   #134
CZroe,
what type of lube are you using? be sure the lube is where the edge of the tire slips over the edge of the rim when you're levering it on. Also, too much lube will actually make the job more difficult as things will slip and slide out of position too easily.
Use small bites of tire and keep your starting point levered with one tool... so in essence, you need three levers when things get difficult.
one other trick... when you get about halfway mounted, make sure the portion of the bead that's already on the rim is pushed down toward the center of the rim in that "well"/center section of the rim so it gives you a bit more wiggle room on the section you're working on.
Old October 26th, 2010, 02:01 PM   #135
CZroe
CZroe's Avatar
I've watched scudman and watched him again when I started having trouble ("if you're working hard, you're doing it wrong"). I weigh a lot and yet I can barely squeeze it down with all my weight, much less when I start applying some to the tire irons. I've bruised my knees with all the pressure I've applied. It seems that no matter what, it pulls my end up away from the middle when I get anywhere near the opposite side.
Well, I've damaged my rims more since the road hazard that caused all this and now my body (it will leave a scar), so I'm throwing in the towel for now. I'll practice later with my old tires and rims.
Old October 26th, 2010, 02:24 PM   #136
g21-30
g21-30's Avatar
Get some of this:
http://shop.advanceautoparts.com/web...%7CGRP2068____
I was able to get the first side on without tools on both the front and rear BT-016 tires. The last side is a PITA, but with knee pressure and prying. it can be done.
Old October 26th, 2010, 03:15 PM   #137
headshrink
headshrink's Avatar
One trick I use for mounting is to leave the new tire in the sun for a bit.... this of course softens it up a bit.
The trouble you are having is the reason I am in the process of building a tire station. It will be a happy day when I don't need to use tire levers/spoons!
Old October 27th, 2010, 11:33 AM   #138
CZroe
CZroe's Avatar
What are the torque values and socket sizes for the axle nuts anyway? Can we get them edited into the OP?
I think the axle nuts are 22mm front, 24mm rear.
CZroe,
what type of lube are you using? ...
Very diluted dish detergent in water.
Originally Posted by g21-30 View Post
Get some of this:
Yup. I'll practice with my old rims and tires. There are no Advance Auto Parts in CA, so I'll see if they have that or something similar elsewhere.
Good luck!
Kawi sez "go forward" too:
http://www.ninjette.org/forums/showp...6&postcount=37
Old October 27th, 2010, 01:58 PM   #139
g21-30
g21-30's Avatar
Look for this in Napa stores in CA:
Napa locations here:
http://www.napaonline.com/Locator/Re...&ZIP=&st=STORE
Old October 28th, 2010, 01:54 AM   #140
CZroe
CZroe's Avatar
kkim: can you edit the OP to reflect 17mm/22mm 65 ft lb front and 17mm/24mm 72ft lb rear specs? That's also 9 kgf m front and 10 kgf m rear for you metric nuts.
Old October 28th, 2010, 09:30 AM   #141
CZroe
CZroe's Avatar
I have three of those but I usd them differently. I still inserted from the right, but, when I realized that a spacer fell out and I'd have to remove the axle again, I placed all three across my Harbor Freight low-profile aluminum rear stand and it only fell a tiny little bit. Of course, it all depends on your tire's thickness, the spools, etc, but it worked well enough for me to believe I could easily insert it from the left if I had to.
Old October 28th, 2010, 10:39 AM   #142
sorry, I can't edit the OP as Alex has things set up so people can't edit their posts after a certain amount of days.
Old October 28th, 2010, 07:48 PM   #143
All set, it's been edited.
Old October 28th, 2010, 10:05 PM   #144
CZroe
CZroe's Avatar
Awesome. Thanks!
Old April 10th, 2011, 03:54 PM   #145
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Hey guys. I'm having a heck of a time installing the rear 150 tire on. I was able to get the front on and was using the same techniques for the rear; taking small bites while keeping pressure down on one side. It's just not working. I get to a point where I can hear the tire ripping. Any advice? I should also add I've watched youtube videos and read thru the diy. I'm also using the camel lubricant on the part that slides over the rim.
EDIT: Nevermind. I finally got it! . I had to just make sure the tire was pushed down into the well more so the other side would slip over. Yay. I can put it back together and commute with it tomorrow.
The www.ModMy250.com guy
Last futzed with by CThunder-blue; April 10th, 2011 at 06:03 PM.
Old April 11th, 2011, 09:30 AM   #146
CZroe
CZroe's Avatar
Originally Posted by Noob View Post
I accidently removed the wire that connects to the front brake and some brake fluid came out. I reconnected it, but when I tugged on the front brake, it wouldnt function. What happened?
You've got air in the line. Look up the procedures for bleeding it. Also, make sure you clean it up because it eats paint and most plastics.
Old April 11th, 2011, 11:14 AM   #147
CThunder-blue
ModMy250.com
BTW, I used the HF bead breaker and it worked great. Paid $25 for it. You could probably pay less if you use the 2x4 method, but then you have to cut pieces up, measure, and put it together. I had the tool out of the box and assembled in 1 minute since it comes in 2 parts. It would be nice if they drilled holes so you could mount it to something, but I can do that myself. I also picked up the wheel balancer for $50 and that worked out nicely as well. I had to adjust the bars so that they were level and sprayed some wd40 on the wheels, but well worth it. No need to jerry rig something.
Old April 11th, 2011, 11:26 AM   #148
dubojr1
dubojr1's Avatar
I choose to just let Cycle Gear electronically balance mine. Just easier for me and free.
Old April 11th, 2011, 11:59 AM   #149
CThunder-blue
ModMy250.com
As long as they keep their machines calibrated, that's cool.
Old April 12th, 2011, 08:16 PM   #150
red
Motorcycle(s): TR7, Trident, SuperIII, BMW, HD, Duc, Vespa, MP3
Rear tires are always harder than fronts - stiffer. New stiff tires are always harder to put on than old clapped out tires to take off (my experience anyway). I think rear tires are 2x harder to do than fronts. IIRC, scudman's youtube vids, and most of the others, are always fronts - I wonder why.
Usually after I wrestle a front tire off and back on, paying someone (or finding a friend with a no-mar or hf changer to take a donation) to do the rear is looking pretty good. At least you save 50% of the cost of mounting a set of tires and saves many bruises. Even having a solidly mounted rim clamp to a bench makes quite a bit of difference, which I don't.
The bigger and heavier the tire, fatter the rim, the worse, or nearly impossible, it is with spoons. For me anyway. A 190 on a 6+ inch rim even takes some skill on a manual changer. Still, it is sick to see how easy it is to do normal sized tires and rims on the most basic manual no-scratch tire changer.
Every time I buy a set of tires and change the front I learn this over again the hard way Then I contribute to the local economy to mount the rear.
2010 Ninja 250R SE - I got this bike for my wife. It was a good trade.
red is offline   Reply With Quote
Old April 16th, 2011, 01:43 PM   #151
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
service manual says to use a new cotter pin on reassembly, is this necessary, or can I get away with reusing it. It's not that I'm cheap, I just don't have any here so I'd have to go pick a couple up...
kamikaze is offline   Reply With Quote
Old April 16th, 2011, 01:48 PM   #152
I've reused mine before, but if it looks like it's about to break at the "bend" line, definitely replace it when you get the chance.
I try to be very careful to not overstress the cotter pin when removing it. That helps to keep it in a reusable condition, if you need to.
Old April 16th, 2011, 02:28 PM   #153
kamikaze
kamikaze's Avatar
cool thanks.
any final words of wisdom to someone that's never had the wheels off a bike before?
Old April 16th, 2011, 02:42 PM   #154
red
Originally Posted by kamikaze View Post
cool thanks.
If you're handy, it's not so bad. If you have a bike friend to help, it's much easier. The project on on what you are trying to do once they're off should probably be most of the work. Reinstalling the rear axle in from R to L is easier (opposite of OEM) unless you have a dummy dowel or something used to align from R to L that you'll drive out if you choose to put the axle back in L to R.
Old April 16th, 2011, 02:47 PM   #155
I would plan to change only one tire at a time. It's going to take longer than you expect, especially if this is your first time doing this.
plan for X amount of hours, budget for double that.
to make installing the new tires easier, heat them outside in the sun, first... the longer the better... hours, if you can plan it that way, to make them more pliable to work with when it comes time to actually install them.
double check, when you get ready to install the tire on the rim, that you have the tire orientated in the proper rotational direction. It's a bitch to completely mount the tire and then find out you've installed it backwards. Ask me how I know!!!
gl... take your time and have fun.
Old April 16th, 2011, 02:48 PM   #156
red
Don't forget tire lube and rim protectors. Might help to have three hands.
If it becomes frustrating, having a place to take them to mount if it becomes too much is a good plan B.
Old April 16th, 2011, 03:34 PM   #157
kamikaze
kamikaze's Avatar
i'm chickening out and getting a local guy that has a no-mar tire changer to do it. he's doing them for 20/wheel which isn't too bad. I still have to get the wheels off and stuff, so I'll be doing that tonite. I'll see how he does them with the machine and see if I want to invest in one (or make one, since I can weld pretty well), looks a lot easier than doing with spoons by hand.
Old April 16th, 2011, 03:42 PM   #158
lol... I learned to do this as a poor, no money high school student. I had no options.
Old April 16th, 2011, 04:04 PM   #159
kamikaze
kamikaze's Avatar
hey, the axle nuts are reverse thread are they? I can't get it to budge
Old April 16th, 2011, 04:07 PM   #160
no, they are regular threaded. left loosy, righty tighty.
how long is the wrench you're using?
DIY EFI KIT for our 250r forbitel 2008 - 2012 Ninja 250R Tech Talk 331 January 30th, 2024 07:03 PM
Tires changing colors Sirref General Motorcycling Discussion 42 June 21st, 2014 09:16 AM
changing tires oompa 2008 - 2012 Ninja 250R Tech Talk 8 April 21st, 2014 02:02 PM
DIY - Changing jets WITHOUT removing the carburetors VeX 2008 - 2012 Ninja 250R Tech Talk 22 May 29th, 2012 04:39 PM
DIY on washing my 250r? SF-Dug General Motorcycling Discussion 116 March 9th, 2012 10:23 AM
