June 24th, 2010, 10:34 AM | #1 |
Turn signals dont flash or click
Hello all this is my first post on this forum but I have been lurking on these boards for a while. I'm having an issue with my turn signals and figured this would be a perfect place to look for help. My turn signals don't flash or click so I was wondering if anybody can lead me to some suggestions to fix this solution. For starters I purchased a used flasher relay from suncoastcycles and that didn't help. I purchased the bike used and it had been dropped on its left side so maybe this would have something to do with my problem. Any help would be greatly appreciated.
June 24th, 2010, 10:43 AM | #2 |
Welcome to the forum. Is the bulb good? Does the right side flash?
June 24th, 2010, 10:50 AM | #3 |
Thank you, I have learned a lot from just lurking around, but do you think one bad bulb can cause all four turn signals to not function since the right side does not flash either
June 24th, 2010, 11:00 AM | #4 |
Fuse maybe or connections have come undone?
June 24th, 2010, 01:17 PM | #5 |
check your bulbs... all of them. a blown bulb will cause the turn signals not to blink on that particular/respective side. it may be something else (relay), but always start with the easiest/cheapest thing when troubleshooting.
June 24th, 2010, 08:30 PM | #6 |
Ride Smart, Ride Safe
Join Date: Mar 2010 Motorcycle(s): 2007 Ninja 250, 2006 Yamati 150cc Scooter Posts: 71
I had the same issue with mine a couple months back. I would hit the switch and nothing would happen. I checked the fuse and it was blown, so I replaced it thinking all was solved. Not so fast, POP, the new fuse instantly blows when I hit the blinker switch.
I carefully checked each of the wire connectors by each of the four blinkers. Sure enough one of the plastic wire connector covers for the right rear blinker was exposing the metal connector and it was shorting out against the frame. I made sure that there was no more exposed metal on the wire connector, replaced the fuse again, and I have been blinking successfully ever since.
Ride Smart! Ride Safe! |
Blinkers/ Turn Signals don't flash | 08GreenNinja | 2008 - 2012 Ninja 250R Tech Talk | 17 | March 6th, 2015 09:23 PM |
[motorcyclenews.com - news] - Staff Blog: To Flash or Not to Flash? | Ninjette Newsbot | Motorcycling News | 0 | July 29th, 2013 03:10 AM |
[motorcyclenews.com - news] - Staff Blog: To Flash or Not to Flash? | Ninjette Newsbot | Motorcycling News | 0 | July 29th, 2013 12:40 AM |
[motorcyclistonline] - Adjusting Motorcycle Suspension | Click, Click | Street Savvy | Ninjette Newsbot | Motorcycling News | 0 | July 10th, 2012 10:20 PM |
Rear turn signals don't blink, front turn signals don't turn on | andyuc88 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 23rd, 2012 02:47 PM |
