July 1st, 2011, 12:32 AM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2008 Ninja 250r Posts: 94
Is a K&N Crankcase breather filter?
IS there a K&N crankcase breather filter? Any part #s?
"Hey man, I'm not tryin' to start nothin'. But... i wouldn't take that" |
July 1st, 2011, 10:46 AM | #2 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
July 1st, 2011, 08:46 PM | #3 |
Join Date: Jan 2011 Motorcycle(s): 2010 Kawasaki Ninja 250R 2011 Honda CBR600RR Posts: 50
This is the one i used. http://www.knfilters.com/search/prod...x?Prod=62-1340
There are different sized ones on this page. http://www.knfilters.com/vent.htm
Projekt D Fender Eliminater / DMP Integrated Taillight / Proton Flushmounts / Area P 18" CF High Mount Race System / Kleen Air System Removed / Airbox Removed / K&N R-0990 / DynoJet Jet Kit |
July 4th, 2011, 11:49 PM | #4 | |
July 5th, 2011, 09:29 PM | #5 |
all the ones that I've seen, yes. there is a DIY that Kkim did that had some pics of the one on his bike, at least I think it was Kkim. If I can't find it just look around on the DIY's it is on there somewhere with a paragraph devoted to it
July 5th, 2011, 09:34 PM | #6 |
nope, not my bike. I still have the original hose coming out of the crankcase with a rather large fuel filter on the end of it.
July 6th, 2011, 07:34 AM | #7 | |
That DIY was from Vex. Later in that thread, I posted most of the measurements for the crankcase vent, both for attachment to the hose and directly to the case.
July 6th, 2011, 08:28 PM | #8 |
That is unusual Kelly. hehe. What purpose does that serve? Just asking
Is a vent filter recommended guys? I understand that these are connected to the airbox for environmental purposes correct? I wonder how the vapor return affect the burn. insignificant I assume?? Thanks for the replies folks. Much appreciated.
July 6th, 2011, 08:39 PM | #9 |
normally, the crankcase is vented to the airbox to catch and recycle fumes and oil from the engine. when you remove the airbox, there's nowhere to connect.
the fuel filter attached to the stock hose prevents oil from dumping straight out of the tube in case of a tipover and also filters whatever air that travels in and out of the crankcase. it's also a great visual indicator to see if oil has migrated out of the crankcase which would collect in that translucent filter. I intended to replace it, but after I installed it, I liked the benefits using it provided. It may not look trick, but is much more effective than a pretty vent filter. In the old days, crankcases used to vent straight out through a tube to atmosphere, so having it not connected to the airbox is doing the engine no harm. |
July 6th, 2011, 08:54 PM | #10 | |
Thats a good set-up you got there though. I think I'll keep an eye out for something similar.
July 6th, 2011, 09:12 PM | #11 | |
under normal operation conditions, I don't see a problem of routing the fumes back to the airbox. |
Cleaning Crankcase Breather | indr | 2008 - 2012 Ninja 250R Tech Talk | 6 | January 10th, 2013 06:50 PM |
Crankcase Breather POD | zzrguy | 1986 - 2007 Ninja 250R Tech Talk | 7 | May 2nd, 2012 10:28 AM |
Valve Cover Block off Plates / Crankcase Breather ? | jboyd12 | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 29th, 2012 08:57 AM |
K&N Breather Filter | indr | 2008 - 2012 Ninja 250R Tech Talk | 8 | February 12th, 2011 11:35 AM |
K&N Crankcase/Breather Filter | nyczs2k | Motorcycle-related | 6 | February 5th, 2011 02:04 PM |
