April 13th, 2010, 10:27 PM | #1 |
Join Date: Dec 2009 Motorcycle(s): Kawasaki Ninja 250 2008 Posts: 10
White smoke, am I burning oil?
I was sitting at the stop light the other day and I was completely engulfed by a cloud of white smoke from my bike. It's been smoking mildly a lot lately, but this was really bad, so I'm concerned now. I checked my oil levels and they don't seem to be much lower, but my coolant seems to have gone down some as well (although I think it's due to the overflow tube) I checked the spark plugs and sure enough they were all black on the ends. Any suggestions on what might be happening/how I can fix it?
April 13th, 2010, 10:40 PM | #2 |
generally when exhaust smoke is concerned...
white=water/coolant blue=oil black=unburned gas I'd suspect a coolant leak somewhere. |
April 14th, 2010, 07:26 AM | #3 |
I agree with KKIM. White is usually an indicator of a cracked block where coolant is leaking into the cylinder. Get your bike hot and then put it in your garage and lie next to it. You may be able to smell the coolant as it is very sweet smelling.
It's not worth doing if you aren't completely stressed out about it. |
April 14th, 2010, 08:07 AM | #4 |
Watch your fluid levels to see if they go down. I agree with the others. It sounds like a coolant leak.
April 14th, 2010, 08:49 AM | #5 |
April 14th, 2010, 09:15 AM | #6 |
Thanks guys. So you think it's a coolant problem even though my spark plugs were black and oily? I've got a new head gasket coming in the mail. We'll see if that does the trick.
April 14th, 2010, 09:37 AM | #7 |
When the head gasket leaks, it's possible for coolant to mix with the oil and/or to enter the combustion chamber. It's also possible for the oil to leak into the coolant and your coolant tank volume will increase and look black. So, check your oil level and if it's not increasing, but the coolant level is decreasing and you have white smoke, most likely coolant is getting into the chamber.
April 15th, 2010, 04:50 PM | #8 |
I'm curious, do you have your crankcase breather plugged like some here do?
April 15th, 2010, 05:18 PM | #9 |
Who has their crankcase breather plugged?
April 15th, 2010, 05:41 PM | #10 |
I've actually got a much different set up than anyone on here. Mine has a wet turbo. No, my breather isn't plugged up though. By the way, do I want the piston cover gasket or the lower cylinder cover gasket? Or both?
April 15th, 2010, 05:48 PM | #11 |
April 15th, 2010, 05:53 PM | #12 |
April 15th, 2010, 07:05 PM | #13 |
April 15th, 2010, 07:06 PM | #14 |
April 16th, 2010, 02:43 AM | #15 |
April 16th, 2010, 04:12 AM | #16 |
1) thats the Kleen system inlet to the exhaust.
2) yes, crankcase vent is the tube coming out of the case that connects to the bottom of the airbox. |
April 16th, 2010, 04:46 AM | #17 |
Thanks, didnt know that!
Oil leak!!!with a little smoke!!! | devinmills | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 23rd, 2014 02:50 PM |
Burning oil is scary smell | jayman87 | 1986 - 2007 Ninja 250R Tech Talk | 1 | July 16th, 2013 03:03 PM |
smoke and burning smell | RED_09 | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 10th, 2013 09:10 PM |
white oil?! help please | xA2D9 | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 20th, 2012 03:34 PM |
Oil vanishing/burning | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 17 | August 31st, 2011 05:20 AM |
