July 18th, 2011, 06:13 AM | #1 |
Join Date: Jul 2011 Motorcycle(s): 2003 Ninja 250r Posts: 7
Changed oil, things are different
I bought my bike (2003) about a three weeks ago and I've put about 200 miles on it so far. The previous owner had the oil changed last fall before putting it up for the winter. This past weekend, I changed the oil to Rotella T6 with a KN-401. Everything went as expected (except I don't have the washer for the top of the spring---not attached to the old filter). The oil I pulled out was dark and completely opaque.
The bike behaves differently now. It must warm up or else it stalls. Also, if I stop the bike in first and leave it for a while, I have to hold the clutch and rock it back and forth to get the clutch to disengage before I start it, otherwise, it bucks like a mule. I'm a bit of a newb so this might be normal... |
July 18th, 2011, 06:48 AM | #2 |
Join Date: Jul 2011 Motorcycle(s): Ninja 250, Vulcan 500 Posts: 50
If oil was black, he most likely lied about just changing it. I see no reason for new better oil to effect your warm up time. If anything, the synthetic oil will be thinner when cold with engine running smoother. Ninjas have to be warmed up otherwise they will stall.
Not sure what you mean about the clutch. Sometime you have to rock the bikes to pop it in the gear. |
July 18th, 2011, 06:58 AM | #3 |
I figured that about the stalls and about the previous change of oil.
If the bike is cold and I hold down the clutch and try to roll the bike, it will stop as if I wasn't holding the clutch at all; however, if I keep pushing or rock it back and forth, the clutch will slip and I'm able to push the bike with the clutch depressed. I'm not talking about changing gears---I'm talking about moving the cold bike in first with the clutch depressed. Before changing the oil, I could cold start the bike in first by holding the clutch. I would move a bit, but not much---now, after the oil change, it jumps a lot unless I make the clutch slip before starting it. Thanks |
July 18th, 2011, 07:05 AM | #4 | |
Edit: + I remember readin on ninja250 org that the pregens lurched when started in gear since the clutch plates would stick/until the oil lubed them up |
July 18th, 2011, 07:09 AM | #5 |
Sure, and often I do that, but I'm trying to figure out if the new behavior of the bike expected or if I messed something up.
Last futzed with by Foom; July 18th, 2011 at 07:10 AM. Reason: wording |
July 18th, 2011, 07:23 AM | #6 | |
And from 2008 http://forums.ninja250.org/posting.p...&t=69819&tro=1 Edit: I don't own a pregen and my bike doesn't seem to do this, but from the sounds of it, all is normal |
July 18th, 2011, 07:31 AM | #7 |
Ahh, thanks. That makes me feel better. I wonder what oil was in it before that made it not lurch as badly---like if it was energy conserving oil.
July 18th, 2011, 07:39 AM | #8 |
My guess is that the former owner used a motorcycle specific oil which has friction modifiers for wet clutches. Try changing to a motorcycle specific oil such as what I use which is Mobile 1 full synthetic motorcycle oil. When I used "automotive" oil my clutch plates would stick and the bike would lurch at startup even while in neutral.
July 18th, 2011, 08:57 AM | #9 |
Join Date: Feb 2011 Motorcycle(s): '96 EX250 Posts: A lot.
My 96 is the same way with motul in it. In gear with clutch depressed, try to push it and it feels like I'm dragging it. Better just to move it in neutral.
July 18th, 2011, 05:58 PM | #10 |
Join Date: Feb 2011 Motorcycle(s): Ninja EX250R Posts: 80
The lurching part is normal. I've never had my bike lurch to the point it was out of control. I did notice it did it more with the original oil in the bike that the previous owner was using (not sure what it was). I run Honda 4 stroke 10w-40 in my bike and it seems to love it. The guys at the local motorcycle shop recommended it and a lot of them run Kawsakis themselves.
As for the stalling part, that seems to be very bike and temperature specific. My bike use to do it all the time until it warmed up (the bike and the weather). Now that it's about 90*+, I've shimmed the carbs, and modified the intake box, it starts just fine and doesn't stall. I know sometimes on cold starts in the mornings the first few times I give it a bit of throttle it will chug along (the RPMs don't raise according to the amount of throttle input), but not to the point it stalls. It goes away after the first block or two from my house. |
July 19th, 2011, 06:34 AM | #11 |
this might sound dumb, but when you start it cold and have that stalling problem, do you use the choke at all? If i use no choke to start the bike and just leave it there, inevitably after a minute or so it'll try to chug and stall. using choke is not bad. it raises the rpm's and it wont stall with partial choke just sitting there, at least in my experiences it wont
July 19th, 2011, 01:42 PM | #12 | ||
As far as the lurching goes, I just have to pay attention a bit more and make sure I break free/slip the clutch before I start it/put it in gear. Thanks for the help. |
Changed the oil now it shuts off when idle. | StrangeKnowledge | 1986 - 2007 Ninja 250R Tech Talk | 11 | October 17th, 2014 02:20 PM |
[crash.net - MotoGP] - Hayden: Things have changed, for sureā?¦ | Ninjette Newsbot | Motorcycling News | 0 | October 10th, 2013 09:20 PM |
Things have changed | TnNinjaGirl | Off-Topic | 27 | April 26th, 2011 03:35 PM |
So I changed my oil | BSNinja250 | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 11th, 2010 11:57 AM |
Shifting changed with new oil. | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 25th, 2009 05:21 PM |
