September 15th, 2011, 06:05 PM | #1 |
Join Date: Oct 2010 Motorcycle(s): 93 ninja 250 Posts: 111
Carbon fiber bars
so why is it that there are no carbon fiber bars on the market, maybe its just me but from the cycling world we have the technology to make incredibly light and strong bars so why hasn't this transferred into the moto world?
September 15th, 2011, 06:22 PM | #2 | |
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250R Posts: 159
Also, carbon fiber is far more likely to crack and break in the event that the bike falls over. By cycling I'm assuming you are talking about bicycles? There's much higher forces being put on the handle bars of a 400 pound motorcycle traveling at 100+ mph than there on a 20 pound bike going 20 mph or less. |
September 15th, 2011, 06:37 PM | #3 |
They would be under constant pressure with minimal support, so they would eventually snap in half or shatter, leaving you with a hand full of expensive splinters.
September 15th, 2011, 06:59 PM | #4 |
my main thought would be that the constant vibration might somehow eventually compromise the structural integrity....still think it could be done
September 15th, 2011, 07:42 PM | #5 |
September 15th, 2011, 08:03 PM | #6 |
how are you thinking they are under constant pressure? trying to figure out what you mean by that.
September 15th, 2011, 08:35 PM | #7 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
i don't think light handle bars are a good place to save weight on motorbikes. you would need even heavier end bars to compensate.
i noticed that my handlebars vibrated a lot when i changed the oem ones out for clipons, before i put bar ends on them. once i put bar ends they stopped vibrating again. the weight savings would be so minimal in the end, that it would not balance out the additional costs. as far as strength, im sure that carbon fiber handlebars would be strong enough to withstand just about anything besides a crash, lol they are used in many situations where there is pressure/stress/vibrations and hold up perfectly i believe.
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
September 16th, 2011, 07:48 AM | #8 |
ModMy250.com
They would have to be much thicker than steel bars to have comparable strength. I ran a CF drive shaft in my turbo stealth and it was much thicker than the stock steel one. You would have to wrap the CF around a thick, almost solid cardboard core to get what you're after. It's not cost effective. Like Wayan said, the vibration dampening needed would negate any weight savings you would see.
Now... carbon fiber forks? That sounds interesting indeed
The www.ModMy250.com guy |
September 16th, 2011, 09:24 AM | #9 |
They would work fine except they would be prone to shattering if the bike fell over. On a bicycle, it's good weight saving. On a 300+ lb bike, the weight difference between cf and aluminum is negligible.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
September 16th, 2011, 05:19 PM | #10 |
yeah weight was never the concern, just wondering why i hadn't seen any out there
September 16th, 2011, 06:24 PM | #11 |
ratlab
Join Date: May 2011 Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100 Posts: 132
lockhart-phillips has been selling replacement carbon fiber bars for clip-ons for years-they do vibrate more than alloy
September 16th, 2011, 07:01 PM | #12 |
AKA. Carbon Fiber Vibrator?
September 16th, 2011, 07:48 PM | #13 | |
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250r SE green/black Posts: 40
In my opinion carbon fiber handlebars would be really cool if you could see the weave through clear grips! |
September 16th, 2011, 07:56 PM | #14 |
you would also need a clear tube for the throttle grip, lol
its something that crossed my mind too, often CF is something ppl like to show off, but on the handlebars, it would barely bi visible,
September 16th, 2011, 08:07 PM | #15 |
You are sleeping
I was going to say resonance.
<Yeah, it's a 250. LMFAO! Weaksauce |
September 16th, 2011, 08:08 PM | #16 |
I hadn't thought about the throttle tube! Now I'll know if I ever want to make a carbon ninja haha
Also this just reminded me I read about Lamborghini's carbon fiber car. Pretty much everything is carbon fiber besides the engine, engine mounts and suspension points on the rear axle. -> Lamborghini Sesto Elemento I think this proves carbon fiber can be used for a lot of things |
September 16th, 2011, 08:46 PM | #17 | ||
One thing you'll find in motorcycling, is that you really shouldn't be putting much force into the bars at all. The geometry of our bikes allows very little work to do the steering, and aside from crashes, the handlebars do not go through a lot of forces. The major forces you will find come from braking, or from resting your weight on your wrists. Another thing you will find is that the amount of force put on bicycle handlebars vs motorcycle bars.. Is more than likely greater. In any sprint or out of the saddle climb, your hands are on the bars. Pulling in sync with cadence, you're likely to pull a good amount of force over any given span of time. Unlike motorcycling, a lot of times your weight will be in your bars (especially TT and Track bikes). I should note that a lot of riders (professionals included) actually prefer alloy bars over carbon, as there is always the issue with crashing. Crash in a race with carbon and there's a chance of game over. Crash with alloy, unless you are injured, it's a guaranteed play-on. Alongside gram savings in weight, carbon tends to be a stiff, responsive, but still forgiving material unlike aluminium. It's easy to make aerodynamic (compared to aluminum), and will guarantee weight savings. These are all things we don't need in the motorcycle world, combined with the un-crashability. Blah blah blah. I talk too much, I'm sorry |
September 16th, 2011, 08:59 PM | #18 |
You are sleeping
Carbon Fiber Bar
Does it help with ED and BM's?
Carbon Fiber | THE BIG SITT | 2008 - 2012 Ninja 250R Farkles | 8 | January 15th, 2012 08:37 PM |
3D carbon fiber vinyl | n4v1n | 2008 - 2012 Ninja 250R Farkles | 38 | November 27th, 2011 08:46 AM |
Carbon Fiber Can Idear | THE BIG SITT | 2008 - 2012 Ninja 250R Tech Talk | 5 | October 6th, 2011 06:40 AM |
Carbon Fiber Parts | Dino | General Motorcycling Discussion | 0 | September 5th, 2010 09:48 AM |
What's so great about carbon fiber? | Techno250 | 2008 - 2012 Ninja 250R Farkles | 29 | June 2nd, 2009 06:49 PM |
