Old March 15th, 2010, 11:01 AM   #1
headshrink
headshrink's Avatar
Cleaning air filter
What do you all use to clean and re-oil your stock air filter?
The SM says to use a solvant with a high flash-point.... I don't even know if I have anything laying around that would work. What are some examples?
And as far as the oil is concerned... unless engine oil will work, I'll have to buy something else.
Old March 15th, 2010, 11:10 AM   #2
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
I use gas to clean. Did it outside no chance of spark or open flame. The washed a couple times in soapy water. Rinsed in water and pressed it dry with my hands. No twisting that night tear it. Then coated with clean motor oil and pressed out the excess. On dirtbikes or if really dusty I always used foam filter oil which is stickier and traps dirt better.
Posted via Mobile Device
Old March 15th, 2010, 11:18 AM   #3
I do the same as Greg, but I wash the filter in hot, soapy water after cleaning it with gas. I then let the filter air dry completely before oiling it.
To oil, I use filter oil specifically made for foam filters available at MC shops. Put the filter in a plastic bag, add some oil to the bag and massage gently to evenly distribute the oil throughout the filter. Take the filter out of the bag, squeeze out the excess oil, then reinstall.
Old March 15th, 2010, 11:23 AM   #4
headshrink
headshrink's Avatar
Very nice.... I think I will use some old lawn mower gas I have sitting in an can, and go with the motor oil technique, and pick up the MC-specific oil for next time.
Hmmm, I wonder if wife would get pissed if I raided her cooking supplies to pour gas in.....
EDIT: I do have some Jet fuel, I mean kerosene, in my camping supplies. Will that work any better or worse than gas?
Old March 15th, 2010, 12:10 PM   #5
not sure. the gas (solvent) cuts the old oil that the dirt is clinging to. the soapy water gets the remaining dirt off the filter.
feel free to raid the cooking supplies, just don't wash that filter in gas near the stove!!
Old March 15th, 2010, 02:08 PM   #6
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
I clean with denatured alcohol in a baggie. That dissolves the old oil. Then I wring it out gently. I mix about a teaspoon of filter oil (sticky stuff) with about 2 tablespoons of denatured alcohol in a clean baggie and when it's dissolved good I drop in the filter, it doesn't have to be completely dry, and squeeze it until it soaks up the whole mixture. Then I let it dry for awhile. If you set it on a small fan pointing up it dries in few minutes but don't light a match! Now that the alcohol has evaporated it leaves a nice light, even coating of oil with very little waste.
kevlar250 is offline   Reply With Quote
Old March 15th, 2010, 02:12 PM   #7
headshrink
headshrink's Avatar
Awesome tips guys, thanks!
Old March 17th, 2010, 01:08 PM   #8
headshrink
headshrink's Avatar
I stopped by the auto parts store on my way to work today (unfortunately there aren't any MC stores close to me anymore). I picked up the K&M recharger kit; that is all they had. There is a spray to clean the filter (I assume it is useless compared to soaking in gas), and the oil is in liquid form (that is what I was after). I will assume it is all good on the OEM filter, unless I hear otherwise for some unforseen reason.
Old March 17th, 2010, 01:39 PM   #9
HKr1
IC2(SW)
HKr1's Avatar
Have a pipercross cleaning kit that I use.
K&N is gonna make you loose some HP!
Old March 17th, 2010, 01:55 PM   #10
I believe the K&N stuff is for their filters and not as effective on foam. Not 100% sure but thats what i heard, from someone who knew someone, who had a friend who had a bike but doesn't anymore.
Old March 17th, 2010, 02:33 PM   #11
yep, the K&N filter oil is for the gauze type filter, not a foam type filter that the stock filter is. You need to get a foam type filter oil or just use regular motor oil as recommended in the service manual.
For a cleaning solution, you could use simple green full strength with warm water and it will clean the filter quite well.
for a guy that doesn't want to spend money on your bike, you sure do buy a lot of the wrong stuff.
Old March 17th, 2010, 07:25 PM   #12
headshrink
headshrink's Avatar
Ahhhh... I didn't see that coming. OK - back to regular oil then.
Now, when is it safe to switch to synthetic?
Old March 17th, 2010, 08:31 PM   #13
Senator
Motorcycle(s): 09 Ninja 250R, 08 Concours, 85 Ninja 900
Exclamation
Please - please DO NOT use gasoline to clean the air filter, I have seen too many disfiguring accidents when gasoiline is used for cleaning. Do yourself a favor and go to the paint store and buy some odourless paint thinner (a high flash point solvent) like Varsol, it's cheap and much much safer. Be safe out there.
Senator is offline   Reply With Quote
Old March 17th, 2010, 08:45 PM   #14
headshrink
headshrink's Avatar
Will Acetone work? I already have some of that.
Old March 17th, 2010, 09:27 PM   #15
CZroe
CZroe's Avatar
How do you properly dispose of the high flash-point solvent? I just ended up buying a new pre-oiled filter element for $10. *shrug*
Old March 17th, 2010, 09:41 PM   #16
headshrink
headshrink's Avatar
Wait 'till Big Brother is checking out sister, then dispose of in quickest/easiest fashion.
Old March 17th, 2010, 09:51 PM   #17
Senator
Do not use acetone, it disolves plastics and paint! High flash point solvent can be safely combined with used motor oil for disposal and by that I don't mean down the sewer or for weed control in the alley.
Old March 18th, 2010, 07:53 AM   #18
Kelly, if I use regular motor oil on my air filter, can I go with synthetic or should I go conventional for the first xxx miles. Yes I am kidding no need to answer, or as they say on Law and Order: "OBJECTION", withdrawn.
Old July 6th, 2011, 10:17 AM   #19
lockie
lockie's Avatar
Motorcycle(s): 2009 blue ninja 250R
Cleaning the filter myself for the first time and I can't seem to get the frame apart to clean the filter element. I'm afraid of breaking the plastic.
lockie is offline   Reply With Quote
Old July 6th, 2011, 10:40 AM   #20
according to the service manual, the plastic pieces should just come apart. it does look like there are "pegs" that fit together in the center section. have you tried carefully trying to pull/unsnap the "pegs" apart?
Old July 6th, 2011, 10:52 AM   #21
my filter cleaning process:
remove old sock.
apply fresh sock.
ziptie.
jk
Old July 6th, 2011, 06:42 PM   #22
lockie
lockie's Avatar
Kelly.. Yea it was not a problem. They just pulled apart. I was over thinking how to do it. Stupid ah?
Old July 6th, 2011, 06:47 PM   #23
NP, Don.
don't forget to reoil the filter once you've cleaned it.
was it very dirty?
Cleaning and lubing my chain, oilchange , and cleaning air filter SON1C 1986 - 2007 Ninja 250R Tech Talk 3 June 29th, 2013 05:55 AM
Anyone know an air filter I can replace the OEM filter with? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2012 09:34 AM
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su Ninjette Newsbot Motorcycling News 0 June 11th, 2012 06:00 PM
Cleaning Air Filter Murtasma 2008 - 2012 Ninja 250R Tech Talk 2 May 24th, 2011 05:25 AM
