December 4th, 2009, 08:38 PM | #1 |
Join Date: Feb 2009 Motorcycle(s): blk ninja 250 2008 Posts: 391
tire pressure visual
got these to keep a eye on my tire pressure (32 rear 28 front) got them at target for $9, full green 32,half green 28
2 bro CFSO, factory pro 3, hotbody DS , krayzie graphics rim tape, brake flasher, DIY fender chop, DIY flushmounts & LED rear, K&N filter, 15/43 Driven, DID race chain, air stuff removed, clipons |
December 4th, 2009, 09:14 PM | #2 |
Not a bad product but I would check their accuracy against a pressure gauge. It only takes 1 minute per tire to check the pressure before going on a ride.
December 4th, 2009, 09:38 PM | #3 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
I'm going to stick with the old school for two reasons. 1) for the cap to give you a pressure reading it has to have the valve depressed at all times - you are one step away from a total loss of air. 2) In all the vehicles and bicycles I have had before I got my Ninja the only time there was a significant change in tire pressure (other than big temperature swings) was because there was something wrong, you just had to go look for it.
But that's just my $0.02
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
December 5th, 2009, 01:03 AM | #4 |
i got them to see why i lost like 5psi maybe cause its getting cold but i do check the pressure the old way have a small guage on me always its been like 40 ish at night and early mornings still riding till i cant take it anymore lol when should i check it like once a week
December 5th, 2009, 07:59 AM | #5 |
December 6th, 2009, 11:54 AM | #6 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
Check them while the motor is warming up every day, and use the SAME airgauge to check them. If you can get a small portable airtank that can hold 35psi that contains its own external gauge, you can compare your gauge to the one on the tank, split the difference and add or subtract appropriately from what your gauge reads so you have a consistent measurement. A good knock can change your gauge up or down as much as 1psi at a time.
December 7th, 2009, 06:34 PM | #7 |
Join Date: Oct 2009 Motorcycle(s): 2010 ninja 250 Posts: 91
added weight on stem
I don't know how heavy these are, but my bike came from PO with some of those little lights on the valve stems. I took them off first day, I don't like to have any added weight on the ends of the valve stems. It may not really be a problem, but I see it as another potential cause of failure.
December 8th, 2009, 03:41 PM | #8 |
what kind of readings are you good folks coming up with on your bike?
oh dAng! |
December 8th, 2009, 10:01 PM | #9 | |
Here with the colder temps, I have been -1--5psi between leaving work and getting ready to leave the next morning. Today for instance. I had 32/30 when I left the house after topping them up. While warm up was happening I had 29/26 in the rear, and when I got home, just to check I had 30/28. |
Best tire pressure ... | Davis937 | 1986 - 2007 Ninja 250R Tech Talk | 17 | February 17th, 2014 02:25 PM |
Help! Need RossoII tire pressure | SPG | Ninjettes At Speed | 5 | July 17th, 2012 12:08 PM |
Bt-45 tire pressure | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 5th, 2011 09:05 AM |
BT-016 Tire Pressure? | spencerkro | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 22nd, 2011 04:53 AM |
Tire pressure.... | Davidb1986 | 2008 - 2012 Ninja 250R Tech Talk | 31 | May 24th, 2010 12:59 AM |
