September 29th, 2013, 07:53 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
general shim under bucket question
hi I'm not ready yet but I was wondering with the shim under bucket, after all is said and done with the measurements
Would the new shim be placed on top of the valve keeper that center indentation? I remember doing a valve clearance jobs for my 96 ZX 6 and I ran into a little bit of trouble placing the shim under the bucket instead of on top of the valve keeper and then placing the bucket over the Shim and the valve keeper, I remember correctly placing the shim on the center of the bucket and then flipping it over it has a tendency to slide off center Thanks. |
September 30th, 2013, 07:04 AM | #2 |
The old shims will normally stick the the underside of the bucket but the new ones will rest nicely in a little pocket on top of the valve assembly.
September 30th, 2013, 07:56 AM | #3 |
OK thank a
I appreciate that I never liked opening something up without knowing what's underneath it
September 30th, 2013, 09:50 AM | #4 | |
September 30th, 2013, 10:47 AM | #5 |
thanks Alex
I have an 08 with 14,000 miles on it, something tells me it should at least be checked,
September 30th, 2013, 11:09 AM | #7 |
ok
I will give a listen, I think it did sound a little bit like that up top, I really like the bike she is a little bruised and banged up but I don't mind I had to do brakes the brake fluid lines the coolant oil and filter, handle bar, clutch lever
the right fork seal is leaking so I will do both work with heavier oil and new seals, & tires just basic maintenance, the bike runs great starts right up rides well, I used to have the old 250 and the ninja 500 which I traded for this newer 250, I had both of the other bikes down at njmp, by spring time I will have it all together for the track down there, it's always a time and money thing so the things that I can do myself I will, thanks guys you have been a big help, |
Carb Needle Shim Question/Bike Idle | haloninja117 | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 8th, 2014 01:14 PM |
shim kit question | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 15 | November 4th, 2013 06:04 AM |
Fuel Mixture Question - Shim or Jet for this set-up? | folky15 | 2008 - 2012 Ninja 250R Tech Talk | 20 | April 23rd, 2012 06:21 PM |
Quick shim question | Gorilla25 | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 2nd, 2011 10:20 PM |
Quick Shim question | shadowskater | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 28th, 2011 08:41 PM |
