October 11th, 2011, 05:20 PM | #1 |
fairing rivets help needed
Hi all,
last weekend i took the fairing off my 08 to install frame sliders and oil change and noticed the rivets under the front were broken (2 out of the 4 or 6) and wanted to replace, since I dont have the bike with me at moment can anyone let me know the actual size as want to order some online before the weekend. ive seen some which are M8 but think maybe too big.. the larger ones at the very bottom of the fairing are ok just the ones near that clip the guard behind the wheel to the side fairing are stuffed.. Paulie |
October 11th, 2011, 06:03 PM | #2 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
yea when i was pulling everything off i broke like more than have of them no beige there identical
http://cgi.ebay.com/ebaymotors/?cmd=...T#ht_886wt_939
THE GOOD LIFE |
October 11th, 2011, 11:44 PM | #3 |
cheers mate, i wasnt sure as thought maybe M6 not M8 but your link was to M7 ones.. i was so impatient i purchased 12 M6 for $4 from hong kong plus the ones you gave the link for .. as i brought my bike used some knuckle head also somehow lost the tread behind the small allen bolt near the front indicator and when tried undoing kept turning and then realised but put a small nut behind the fairing.. what a job on my own having to jam my hand under there with a small pair of pliers while then humbling around to feel where the allen bolt was to undo... next time there off going to have to also do something about that.. maybe glue the nut in place ?
thanks again Paulie |
October 12th, 2011, 05:59 AM | #4 |
That's a rubber wellnut. They always rot and split in two on this bike. Get a windscreen kit that comes with several. There are 14 hidden all over the bike and most will be rotten exactly the same way. The only two that don't are the two exposed on your windscreen an they have a different part number even though they are the same size (which tells you that Kawasaki is perfectly aware of the issue).
October 12th, 2011, 09:34 AM | #5 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
you could also order original ones at bikebandit.com
I can not be a true player by playing around. |
Fairing kit needed | brokenninj | Items Wanted | 4 | April 16th, 2015 10:26 AM |
Fender Rivets | FBR_BDavis | Items Wanted | 2 | March 25th, 2015 05:58 AM |
2009 Ninja 250 Fairing Rivets Size??!! | DLobs | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 22nd, 2014 12:48 PM |
Replacement fasteners (bolts and rivets)? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 19th, 2012 04:33 PM |
anyone lose one of these ignition switch rivets? | backinthesaddleagain | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 10th, 2010 07:45 AM |
