Old July 4th, 2011, 08:43 AM   #81
CZroe
CZroe's Avatar
Originally Posted by n4mwd View Post
I was thinking something like this:
See how its designed not to cover the entire animal but just the important stuff.
Something like that would be good for bikes if it was lightweight and possibly made of insulating reflective mylar so that its simple and quick to throw it on and off the bike. It wouldn't have to cover the entire bike (as most motorcycle covers do) but just the important stuff like the seat and the tank. It also needs to be short enough that it doesn't hit the hot parts.
I'm surprised that I haven't seen anything like that for bikes. Full covers are a pain to get on and off.
Uhh... I've seen plenty of "half-covers" for bikes. The pretty much just cover the handlebars to the tail. Your gauges are still going to get wet and dirty, your turn signals and other black unpainted plastics are still going to fade and rot from UV, etc.
Old July 4th, 2011, 12:50 PM   #82
n4mwd
n4mwd's Avatar
Got any links to ones for sale?
Old July 4th, 2011, 12:56 PM   #83
ducducgooseit
Motorcycle(s): ...
To protect your motorcycle against the elements I suggest:
  1. your own garage
  2. your own carport
  3. someone else's garage
  4. someone else's carport
  5. a deciduous tree w/o birds
  6. an umbrella
  7. a motorcycle cover
As I have never gotten past 3. above, I don't have any picture to provide.
Last futzed with by ducducgooseit; July 4th, 2011 at 02:33 PM.
ducducgooseit is offline   Reply With Quote
Old July 4th, 2011, 02:33 PM   #84
headshrink
headshrink's Avatar
I use a 1/2 cover at work. No melting problems as it doesn't touch the pipe....
The best thing though, is I can roll it up tight enough to fit in the rear seat cowl
Old July 4th, 2011, 02:47 PM   #85
n4mwd
n4mwd's Avatar
For me, at home isn't a problem because my bike has a spot in the garage. I know other guys that get their bikes under cover one way or another including putting it in the living room.
A lot of stores around here allow bikers to park under the covered porches directly in front of the store, but unfortunately, many do not and I end up in the main parking lot with no shade. That's when a little mini-cover would be nice.
Old July 4th, 2011, 02:48 PM   #86
n4mwd
n4mwd's Avatar
Where did you get it? I want one.
Old July 4th, 2011, 03:34 PM   #87
ducducgooseit
Motorcycle(s): ...
Ok. So. I'll try to be helpful. My Google search of CoverMax Motorcycle Half Covers came up with:
Is that helpful?
Old July 4th, 2011, 03:44 PM   #88
headshrink
headshrink's Avatar
Any products good for refreshing plastic parts with UV damage (like the stock blinkers)? I found a rag with a light coat of WD40 is better than nothing, but think there has to be a better solution.....
Old July 4th, 2011, 04:11 PM   #89
ducducgooseit
Motorcycle(s): ...
Light UV damage? If you have a power drill, time, and some spare cash go to Autozone or Pepboys and get either a Meguiar's or Mother's Headlight Restoration kit. Follow instructions and your clear plastic will be in far better shape. WD-40 helps only very temporarily because the lubricate fills the UV damaged voids. When the WD-40 completely dries the UV damaged surface will still be in place and the clear will not be as transparent as the restoration kits would have achieved.
Note that the polishing the lens does remove some of the lens - not much - but some. Its useful only 3 or 4 times on the same lens.
There are some other products that can clean and return to excellent condition clear acrylic or poly-plastics but they cost more than a new lens cover would and the correct application is a matter of practice.
Old July 4th, 2011, 04:18 PM   #90
ducducgooseit
Motorcycle(s): ...
If you are going to try to remove UV damage from high gloss or very smooth plastic that is not clear, try Meguiar's #17 and Meguiar's #10 in that order. Each must be applied with a very clean cloth - I recommend 100% cotton - and each must be completely polished off. Elbow grease is required for #17 to do its job.
These will polish the UV damage away. If the original surface is matte do not use these - they will remove the damage AND remove the matte surface treatment of the plastic.
Old July 4th, 2011, 04:26 PM   #91
headshrink
headshrink's Avatar
I was only talking about the black plastic housings, but that is good info to have, because the clear plastic inevitably will start to go at some point too.
Old July 4th, 2011, 05:19 PM   #92
n4mwd
n4mwd's Avatar
Yes it was, thanks.
Old July 4th, 2011, 05:31 PM   #93
Bols
Norwegian dude
Motorcycle(s): Ducati 748
I have the original Kawasaki outdoor cover in silver, don't have a pic of it, but here is the pic from their site, you get the picture
Bols is offline   Reply With Quote
Old July 17th, 2011, 06:02 PM   #94
ladyninja08
ladyninja08's Avatar
Motorcycle(s): 2011 black ninja 250r
Got a Paul Jr Designs(American Chopper) waterproof cover at walmart for $39.99 fits perfect .
ladyninja08 is offline   Reply With Quote
Old July 18th, 2011, 05:17 PM   #95
2011Ninja250R
2011Ninja250R's Avatar
Motorcycle(s): 2011 Ninja 250R SE (Green) Previous bikes R1, Daytona 675, GSXR600, Pre-Gen 250R
Red face
In the garage with my wife's queen sized silk sheet over her.
2011Ninja250R is offline   Reply With Quote
Old August 4th, 2011, 07:42 PM   #96
2fiddy
2fiddy's Avatar
Motorcycle(s): 2010 Red Ninja 250r
Best motorcycle cover for 2010 250r
Hey guys. Looking for another cover for my bike since I lost mine and would like to see what the best cover out there would be for my bike for the best value. I am also thinking that I want something that will also be fine for the winter as well, and shouldn't be that much different since it will be in a shed during the winter. It will be outside though under the cover so I'd like a good cover for a good price.
I had the one from coverace and it was nice but started to fade and let small amounts of water through after a while and that kind of defeats the purpose of having a cover I'd say.
Do you guys have any recommendations for me? Can you please include links as well.
Thanks!
2fiddy is offline   Reply With Quote
Old August 4th, 2011, 08:09 PM   #97
YORCHI
n00b
YORCHI's Avatar
Motorcycle(s): Blue 2010 Ninja 250
I bought the "Trackside" deluxe cover from cycle gear, it was like 70 bucks I think after the military discount and it has worked great. I park the car under a car cover but the sprinklers hit it from the side sometimes and the cover has worked perfectly at keeping the water away. It's pretty form fitting, has a hole to prevent condensation from forming, and it has a strap at the bottom to tighten it up and lock it shut with a cable lock. Good cover I'd say, a lil pricey, but it was the only one I could find that had what I needed...waterproof, tough, lockable, and form fitting
Facebook YouTube
#KCCO
YORCHI is offline   Reply With Quote
Old August 4th, 2011, 09:08 PM   #98
setasai
setasai's Avatar
I use a nelson rigg deluxe all season cover. I like it. Feels pretty sturdy and fits nicely so that the wind wont blow it off. I think the size I have is a medium but i'm not 100% sure.
http://www.motorcycle-superstore.com...son-Cover.aspx
Old November 20th, 2011, 07:27 PM   #99
TheTopher
TheTopher's Avatar
Motorcycle(s): 2007 EX250F
Storage covers
Been thinking of getting one for my bike while it was in storage, I don't know too much about them and unfortunately every time I try googling "bike cover" I get a bunch of results about covers for all the mechanical bits and pieces.
So I'm just curious, do you guys even bother coverings your bikes? Are those 1 size fits all covers good enough or does somebody make a cover specifically for the EX250 that works better? Any particular one you guys would recommend?
Thanks!
TheTopher is offline   Reply With Quote
Old November 20th, 2011, 07:40 PM   #100
/merged a few "motorcycle cover" threads into a one more mongo one. There should be a whole bunch of pics and links within this thread to give folks ideas on covers.
Old November 20th, 2011, 07:47 PM   #101
TheTopher
TheTopher's Avatar
Thanks!
Old March 28th, 2012, 03:08 PM   #102
cuong-nutz
cuong-nutz's Avatar
UPDATE: The Bilt motorcycle covers did not last a year outside. The sun and rain had faded the fabric to where it was brittle and easily torn. I patched up the tears with tape and it's still holding up for the most part.
HalfFast Racing Team
Old March 28th, 2012, 04:38 PM   #103
Darling Ninja
Darling Ninja's Avatar
Motorcycle(s): 2013 Ninja 300 ABS
I have the limited edition Ultra Gard breast cancer pink/charcoal bike cover. It has the breast cancer ribbon on the bottom.
Price: $39.99
I've had it boxed up for a while and finally it started raining pretty hard here in L.A. I took it out of the box and It's held up pretty well against the rain and wind.
"You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck."
Darling Ninja is offline   Reply With Quote
Old March 29th, 2012, 10:35 PM   #104
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
Awesome Bike Cover... for $12
Pick it up at your local Walmart for about $12. It's quite thick, it's weatherproof, and the entire inside is lined with a soft material.
You'd be hard pressed to find a 'motorcycle' cover that's this thick and weatherproof for less than $50, and it'll probably only have a soft lining by the windscreen.
Walmart has 65" ones for slightly cheaper, but they are thin, flimsy and not nearly as good as this 68" one. Make sure you grab the 68" pictured.
Here are the pics of the cover on my bike:
Here is a picture of the inside soft lining. The entire cover is lined with this, not just certain sections:
My Mods | My Bike's Ninjette Thread
Last futzed with by saxnbass; March 30th, 2012 at 09:30 AM.
saxnbass is offline   Reply With Quote
Old March 29th, 2012, 10:36 PM   #105
interesting theory. I'm interested in how well it attaches and how well it holds up
Old March 29th, 2012, 10:42 PM   #106
saxnbass
saxnbass's Avatar
It has velcro straps on the bottom so you can tighten it snuggly on the bottom if you need to.
Old March 29th, 2012, 10:47 PM   #107
Snug enough to handle NW Ohio winds?
Old March 29th, 2012, 11:01 PM   #108
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Good of you to share this bro...I'll definitely look into it. My current cover, albeit advertised as 'water proof', gets soaked through and through. Only thing it has going for it is a hook that you can pass through a hole in the cover making it extremely secure. Anyway, thanks again, I'll see how this'll hold up.
EthioKnight is offline   Reply With Quote
Old March 29th, 2012, 11:01 PM   #109
saxnbass
saxnbass's Avatar
Chris, I'll let you decide that when I post pics tomorrow.
Alex, it's very nice. You'll see by the pics tomorrow. Water on this thing just beads up and rolls off. Someone else who uses this to cover their bike said it rained for 2 days and the bike underneath was completely dry.
Old March 30th, 2012, 05:05 AM   #110
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Looks worth a try.. hell I already spent $20 on a MC cover, that is very thin and wouldn't hold up to more than a sprinkle for it's 'waterproofing' Plus it's so loose at bottom it lets way too much air in.. a few times it almost blew off, it's 1 little hook barely keeps it on.
Old March 30th, 2012, 05:17 AM   #111
n4mwd
n4mwd's Avatar
Looks like a good find - thanks.
My Ninja Blog
Old March 30th, 2012, 05:43 AM   #112
CZroe
CZroe's Avatar
Heat resistant? Most people are in no hurry to cover their grill, so it doesn't really have to have it.
Most motorcycle cover brands offer e "dust cover" and a "deluxe cover" with heat resistance as the main distinguishing difference.
Old March 30th, 2012, 06:06 AM   #113
cuong-nutz
cuong-nutz's Avatar
subb'd for pics.
People will probably be wondering what kind of grill has two giant wheels.
Old March 30th, 2012, 06:42 AM   #114
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
That's thinking outside the box ! Nice tip
Old March 30th, 2012, 07:09 AM   #115
GreenNinja
GreenNinja's Avatar
Name: I'm a ninja!
HAHA that is pretty smart thinking!! I bought a cheap one for $15 including shipping off of ebay last year and I've never had problems with rain coming through it. It was just a generic gray bike cover. For the little hole on the bottom of the cover, I use yarn to tie the two ends together. It has worked fine for the 30mph gusts of wind we have had this past Jan. I will definitely recommend that to my friends and if I need another one I will look into it myself. Nice find saxnbass!!
GreenNinja is offline   Reply With Quote
Old March 30th, 2012, 09:27 AM   #116
saxnbass
saxnbass's Avatar
Pics added to the original post.
Old March 30th, 2012, 09:32 AM   #117
saxnbass
saxnbass's Avatar
When I covered the bike last night, I got home after about a 50 mile ride, so the bike was toasty hot. I went inside, got out of my riding gear, put the dog on a leash, grabbed the cover and went outside to cover it up. It was parked for all of about 5, maybe 10 minutes before I threw the cover on it. No damage or anything to the cover. The picture of the inside lining is actually the part that covers the exhaust, as you can see it's just fine.
Old March 30th, 2012, 10:50 AM   #118
n4mwd
n4mwd's Avatar
How well do the velcro strips keep it tied down?
My Ninja Blog
Old March 30th, 2012, 11:14 AM   #119
GreenNinja
GreenNinja's Avatar
Name: I'm a ninja!
that actually is funny looking since it doesn't go all the way down and hide the wheels. If it works well then it would be worth it.
Old March 30th, 2012, 11:30 AM   #120
saxnbass
saxnbass's Avatar
I didn't use the velcro straps as it fits my bike pretty nicely as is, but I did use them just to see. It brings the bottom up a bit more so more of the wheel is exposed, but it does tighten up the front and back very snuggly; I can't see it going anywhere with it tightened up like that.
About it not hiding the wheels all the way, not sure why that'd be a big deal anyways. Plus, for $12, I really can't complain in any way. I'd have to spend $75+ to get a comparable motorcycle specific cover, IMO.
Tire recommendation. Gregg_VA 2008 - 2012 Ninja 250R Tech Talk 26 January 17th, 2014 01:47 PM
dealership recommendation on parts t0sh 1986 - 2007 Ninja 250R Tech Talk 11 June 18th, 2013 07:43 AM
Glove recommendation hirubhaiambani Motorcycle Gear 11 August 28th, 2012 04:52 PM
need recommendation on feeler gauges CThunder-blue 2008 - 2012 Ninja 250R Tech Talk 4 January 6th, 2011 11:27 AM
Why is Kawi's break in recommendation... wild-bill 2008 - 2012 Ninja 250R Tech Talk 5 November 8th, 2010 06:44 AM
