Old April 16th, 2013, 07:15 PM   #241
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
subscribes~ waiting to see this baby in action, he he
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old April 17th, 2013, 12:30 AM   #242
tubarney
Originally Posted by mgentz View Post
I have a degree wheel and indicators, but I would need to pull the motor all apart to check this.
I have this feeling that they are going to be very similar anyway. Something to measure next time you do the valve clearances maybe.
Here's my new hole. It has been heli-coiled. Cost $80. The bolt was die grinded in half, then it was picked out.
As you know I am keen on diy, but I recommend if this happens to take it to a professional, for what you pay, it isn't worth the trouble especially if you stuff your cases.
I have replaced the other bolt for the bracket with new ones just in case.
Just an fyi, regular old degreaser in a can is a lot better than brake cleaner for cleaning, and cheaper. It squirts out instead of sprays, there's no need for compressed air because of how powerful the stream is.
Old April 17th, 2013, 01:40 AM   #243
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Next time you need to repair a threads. Or add threads to something. This is the way to go.
http://www.timesert.com/
The inserts are iron. You can drill them out if you need to. Also the inside and outside are normal thread. Unlike helicoil. So you can drill the next size up and then put one inside another.
They also have a small shoulder. So they can't back out. And they don't back out because they lock in mechanicly and use thread lock. I have used then for over twenty years.
Worlds fastest 250 ninja
Old April 17th, 2013, 03:30 AM   #244
tubarney
Thanks for the tip. Knock on wood there isn't a next time.
How much are they after you buy a kit, because from what I read they aren't cheap? The kits are as much as I spent on the labour, unless your getting them cheaper somewhere.
I'm interested to know how much extra they would have charged me for one. Will have to find out.
The heli-coil was free and they are stronger than the original thread so I'm happy to use them and save a bit of cash.
Old April 17th, 2013, 04:04 AM   #245
Racer x
Racer x's Avatar
They are not cheap. But when faced with a broken engine case in a Porsche. The studs used to pull out of the case. People buy me the kit and I fix the car.
Mercedes uses them to replace ALL the head bolt threads in V8 s
The is 17 each side. Used to take all day.
Price is for a drill tap driver and a couple inserts. Yes it's expensive but you have to look at what you are fixing. Your heli coils is perfect. BTW
Old April 17th, 2013, 04:05 AM   #246
bruce71198
bruce71198's Avatar
Originally Posted by cuong-nutz View Post
Do you have the spark plugs out?
The headgasket won't catch the piston regardless since the piston edges do not protrude past the bore.
If he was using stock pistons from Kawasaki this is something I would take for granted. After market parts should always be checked for fit. A piece of clay on top of the piston will tell you what the squish is at TDC. It was noted by the OP that the condition was noticed after the head was bolted on.
Old April 17th, 2013, 10:12 AM   #247
mgentz
Board Member
alright so here is where I am at.
I flushed the motor one last time with SAE 30 oil.
Finished safety wiring.
Put on all of the body panels.
From there, I cranked the motor over (no fuel) and listened intently. I heard no strange sounds. With this, I assume that the oil pump has been primed (I cranked it for 3 sec each times for 4 times).
I have been over this again and again and I can think of no reason for the tight spot. Funny thing is that based on Bruce's recommendation I turned the motor count-clockwise and it had even more spots.....However, so did Bruce's running motor. With all this research I think that I can rightfully assume that something in the motor (leverage, gears, friction, whatever) is causing the tight spots but they are not a cause of concern.
As for the piston heights, I did check these before I bolted on the head and they came out almost identical..... Therefore, what #1 experiences, #2 should.....
Old April 17th, 2013, 06:42 PM   #248
mgentz
Board Member
where I am today:
Old April 17th, 2013, 06:44 PM   #249
mgentz
Board Member
I still need to wash it, but that will have to be after its break in ride.
If it continues to rain, I'm going to break this thing in on the dyno.
I'm most excited to know that no one will ever know what is "under the hood" but me. It should be a blast to ride.
Old April 17th, 2013, 07:06 PM   #250
Racer x
Racer x's Avatar
Congrats . Do some video on the dyno
Old April 19th, 2013, 03:01 PM   #251
mgentz
Board Member
Do you need to jump the kickstand wires in order to get the bike to start with a jettingpro or brtis?
Old April 20th, 2013, 06:57 AM   #252
mgentz
Board Member
@tubarney how is your build coming along?
Old April 20th, 2013, 07:33 AM   #253
Racer x
Racer x's Avatar
I think so. I don't have a key anymore. But I think I remember that.
Old April 20th, 2013, 09:27 AM   #254
mgentz
Board Member
Lol. Any way you could check?
Old April 20th, 2013, 11:17 AM   #255
Racer x
Racer x's Avatar
Post 12
http://www.ninjette.org/forums/showt...ht=Brt+install
Old April 20th, 2013, 01:54 PM   #256
mgentz
Board Member
I jumped the wires but she still won't start. I even put the stock cdi back in and it still won't start.
I pulled the plugs and I have spark. ..and the plugs are wet when I pull them but it may be oil from the cylinder installation.
Currently upset about this but I want to fix it.
Thoughts?
Old April 20th, 2013, 02:17 PM   #257
Might sound like some dumb suggestions considering your work on this bike so far, but a double check is always a good idea:
I know you bored it. What size pilot jets are you running? Sure they're enough? Is the choke working right? Might be too lean to start with what's in the carbs now. The bike likes to start right as you cross the threshold from normal to rich with the choke. Maybe the choke isn't enough because the pilots are small? idk.
Are the carb bowls full? Suck on the vacuum nipple for a bit with a spare piece of hose and make sure the bowls are full.
You've already checked compression and spark, so those bases are good. Just my input.
Old April 20th, 2013, 03:05 PM   #258
Racer x
Racer x's Avatar
The kick stand switch blocks the starter. If the engine cranks but no start there is a problem. Lets hit basics. Spray eather in the carbs. If it won't fire then do a compression test. Anything below 125 psi won't start
Old April 20th, 2013, 06:23 PM   #259
mgentz
Board Member
Comp is about 150 each side right now. She wants to kick over but just can't. Even on the starter she has gotten to 3000 rpms....I don't think that is just starter.
Old April 20th, 2013, 06:31 PM   #260
mgentz
Board Member
She won't start with starting fluid
Old April 20th, 2013, 06:38 PM   #261
Racer x
Racer x's Avatar
So the engine spins when you push the starter button? You have compression(150 psi)
Take a plug wire off. Put a screw driver in the end of the wire. See if you can get the spark to jump 1/2 to 3/4 of an inch.
How old is the gasoline?
pull the exhaust and see if flames come out when you try to start it. Then double check the cam timing.
Old April 20th, 2013, 06:56 PM   #262
mgentz
Board Member
I pulled the plugs and got spark to show when they were grounded to the frame....How does one do a shooting spark test?
I bought the gasoline yesterday.
white smoke is coming from the exhaust now....I still feel like there is too much oil in there but have no logical method of removing it.
Old April 20th, 2013, 07:20 PM   #263
Racer x
Racer x's Avatar
Put a screw driver in place of the plug. Hold it to ground and crank the engine. As it starts to spark. Move the screwdriver away and stretch the spark.
Put the plugs in with the gap at .019
Old April 20th, 2013, 09:09 PM   #264
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
I think there's nothing you must worry about since your engine is rebuild now everything is dry and it's not running in yet so the residence is high.
When you see white smoke from the exhaust that means the engine is trying to start but can't because of -> see above.
Like Eric said ether is a good idea to use and in cases like this it's always helpful to take a second battery because the engine now is draining many power.
After it's started keep it running for maybe one minute and then turn it off to look for leaks. If everything is ok start it again and warm it up with low rpms.
Good luck.
Old April 20th, 2013, 09:54 PM   #265
tubarney
Have you got the problem sorted yet?
Old April 21st, 2013, 12:50 AM   #266
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
Subscribed! Best thread so far..
I have a few question though,
-what countershaft sprocket are you running? I love the holes on it but neve found one for the ninja.
- i dont have the LV exhaust, but i will be putting bazzaz on mine.will the LV airbox mod benefit me? This is going to be on my race bike and some weekend canyon ride.
red26 is offline   Reply With Quote
Old April 21st, 2013, 08:17 AM   #267
cuong-nutz
cuong-nutz's Avatar
Did you Set the fuel on prime? All hoses connected property? No vacuum leak?
HalfFast Racing Team
Old April 21st, 2013, 02:36 PM   #268
mgentz
Board Member
ok.
So I re-checked the valve clearances....middle of spec to loose.
Re-checked the valve timing....spot on.
Compression....good.
Fuel set to prime.
all hoses and electrical connected.
do we have a tip over switch or something? This is going to something stupid.
Old April 21st, 2013, 02:38 PM   #269
mgentz
Board Member
It's either a renthal or a vortex.
As for the airbox, if you're only putting on the exhaust I would leave the airbox as it is for street riding.
Old April 21st, 2013, 03:33 PM   #270
Racer x
Racer x's Avatar
ok.
Fuel set to prime.
No tip ove switch.
So it still will not start? It has to be timing. if compression is over 150 and the fuel is new. Did you spray anything down the carbs? Are the plugs wet?
Looks like you need a timing light to check.
Old April 21st, 2013, 04:45 PM   #271
tubarney
ok.
Fuel set to prime.
Best thing to get the stupid stuff out of the way first before you start thinking its something more serious.
Here's some ideas.
The wires that come out of the alternator cover. One connector is black the other grey. Any chance you have them switch over.
What about the sensor that goes into the cases thats located just above the front sprocket.
Have you tried starting it with the throttle wide open.
Here's a question.
Is fuel getting into the bottom of the carbs?
Old April 21st, 2013, 04:47 PM   #272
tubarney
Racer x might be able to answer this one. Is there any chance that running a pilot jet or main jet that is either too big or too small could cause it not to start?
Old April 21st, 2013, 05:12 PM   #273
mgentz
Board Member
Plugs are wet.
Nuetral light is on.
Exhaust starts to get hot.
I'm going to clean the carbs and reseal all of the boots. From there I will test electrical.
Old April 21st, 2013, 05:12 PM   #274
Racer x
Racer x's Avatar
Not really. It should be doing something. Backfire sputter. If you spray starting fluid in the carb. You bypass the whole carb.
Old April 21st, 2013, 05:53 PM   #275
tubarney
Plugs are wet.
It could be the plugs. Did you wash it before you tried to start it?
edit... forgot you tested for spark. I'll keep thinking.
Old April 21st, 2013, 06:14 PM   #276
ManOfGod
ManOfGod
ManOfGod's Avatar
Motorcycle(s): '02 Ninja 250r Scuffed and scratched blue...soon to be black, I think...
Subscribing. This is very interesting.
"For God so loved the world that He gave His only begotten Son that whoever believes in Him might have eternal life."-John 3:16
ManOfGod is offline   Reply With Quote
Old April 22nd, 2013, 09:15 AM   #277
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
So you have spark and fuel. Only thing you are missing is timing. Pull the valve cover and triple check the timing. Even one tooth off could prevent starting.
Mods: 636 front suspension conversion, wc clip ons, bohemian rear sets, FP jets, k&n filter, and AP full race exhaust
gt_turbo is offline   Reply With Quote
Old April 22nd, 2013, 09:39 AM   #278
bruce71198
bruce71198's Avatar
Plugs are wet ? with oil or gas. or coolant ?
What are the odds that you were just over zelous with oil during assembly and oil fouled the plugs on initial start ?
I haven't studied the ignition system on these yet, but could it be timed 360 degrees out and firing on the exhaust stroke? I imagine ,in this day and age, it probably has a waste spark system and fires on compression and exhaust strokes.
If you have spark then theres no electrical problems and nothing electrical for the fuel system.
Old April 22nd, 2013, 10:12 AM   #279
mgentz
Board Member
it fires on both strokes.
oil could be fouling the plugs. However, to curb this I keep pulling them and cleaning them. No coolant.
I will check the timing....again. But I know that I am the requisite 34 links (counting 1-36 as shown in the service manual) and that the 2IT mark is ligned up and that the cam sprocket marks are flush with the head. This time I will pull the plug and use a dial indicator to be even more sure.
Old April 22nd, 2013, 10:13 AM   #280
mgentz
Board Member
If I feel like pulling the head....do I need a new gasket? I was debating.
Shin's 250r Build Thread Shintoxica 1986 - 2007 Ninja 250R Farkles 3 August 22nd, 2013 11:10 AM
My 250R Race Bike Build icbm Pictures 5 August 16th, 2012 11:06 AM
Is the ninja 250r the ultimate beginner bike, or should I settle for something else? Mulholland General Motorcycling Discussion 188 April 15th, 2012 09:28 PM
[topix.net] - Freestyler Josh Borne guest stars on Discovery's Ultimate Car Build Off Ninjette Newsbot Motorcycling News 0 June 25th, 2010 07:50 AM
I want to buy or build an 08+ 250R racer. Seanslides Ninjettes At Speed 20 March 1st, 2010 07:34 AM
