July 21st, 2010, 02:43 PM | #1 |
Join Date: Dec 2009 Motorcycle(s): Blue 2008 Ninja 250R Posts: 86
Routing for 'side hose' on fuel tank
I removed my fuel tank while replacing my triple clamp. When I did so, the hose on the left side of the tank was so tight I couldn't pull it off, so I just pulled it out of the bike instead. Now I can't figure out the routing back down through the bike, and the service manual isn't much help =( Could someone kindly post a couple of pictures of how the hose on the outside-left side of the fuel tank routes down through the bike?
July 21st, 2010, 02:49 PM | #2 |
pg. 17-8 of the service manual.... item #20, 21
July 21st, 2010, 02:52 PM | #3 |
July 21st, 2010, 03:02 PM | #4 |
the tube runs up and over that tube that the rear shock mounting point is connected to then straight down, through the inside of the swingarm to a small bracket they have welded to the frame where the tube exits. it ends up at the same place as the coolant overflow tube.
July 21st, 2010, 03:04 PM | #5 | |
July 21st, 2010, 03:08 PM | #6 |
look at the lower left pic in the manual on 17-8. just pass the hose through the 2- #21 guides that they have listed.
July 21st, 2010, 03:27 PM | #7 |
Roger that. One other question re: the fuel tank. I took mine off about a week ago and now can't remember whether the fuel level sensor has a hose connection or just the electrical connection. It seems to have a hose nipple, and there's a stray hose near there...but I don't remember disconnecting anything from it. See pics -- the hose I'm talking about is marked in orange. Does B on the hose connect to B on the sensor?
July 21st, 2010, 03:47 PM | #8 |
there should be no hose connected to that nipple on the sensor. the tube you reference in orange is the carb vent which runs straight back and is not connected to anything on the end.
July 21st, 2010, 03:48 PM | #9 |
July 21st, 2010, 03:51 PM | #10 |
np... that's why Alex pays me the big bucks!!
December 12th, 2010, 03:30 PM | #11 |
Join Date: Sep 2010 Motorcycle(s): 2010 ninja 250r Posts: 55
man this just helped me out also thannk you guys and man the search button does work
December 12th, 2010, 05:00 PM | #12 |
Carb Hose Routing | jschatte | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 8th, 2014 08:30 AM |
vacuum hose routing | Sebastian f7 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 28th, 2013 07:06 AM |
Need Visual Confirmation of Carb Hose Routing | indr | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 23rd, 2013 07:49 PM |
Cali bike / 49 state replacement tank / hose routing help | djliquid | 1986 - 2007 Ninja 250R Tech Talk | 7 | December 14th, 2011 09:33 AM |
Routing for fuel overflow hose | haze5736 | 1986 - 2007 Ninja 250R Tech Talk | 3 | July 7th, 2011 07:09 PM |
