October 4th, 2010, 11:12 AM | #1 |
Join Date: Jul 2010 Motorcycle(s): 2010 Ninja 250R Posts: 306
Pirelli Diablo Rosso, Bridgestone BT-016, Sizes?
Hi all. Thinking about new tires. Anyone use the Pirelli Diablo Rosso? I'm checking these and the BT-016. Would anyone happen to have a comparison of these two tires? For the Pirelli's I would be getting 110/70 or 120/60 front, 150/60 rear. Bridgestone's would be 110/70 front, 150/60 rear.
Thank you for any assistance. |
October 4th, 2010, 12:47 PM | #2 |
Just a suggestion...
http://www.ninjette.org/forums/showthread.php?t=57081 I also have a coupon code for an additional 10% off the Pirelli's at motorcyclesuperstore.com if you choose to get them there. Best prices! Good luck!
October 4th, 2010, 02:01 PM | #3 | |
Thanks for the coupon code too, but someone forwarded already. |
October 6th, 2010, 02:18 PM | #4 |
Norwegian dude
Join Date: Aug 2010 Motorcycle(s): Ducati 748 Posts: 120
I'm using Pirelli Diablo Rosso 120/60 and 150/60
October 6th, 2010, 06:09 PM | #5 |
Thank you for the reply! Yours is the one post I found. Would you happen to have any pictures of the tires mounted? Did you have to remove or modify the chain guard? Why did you go with 120/60 instead of 110/70?
Any further assistance would be appreciated. |
October 7th, 2010, 08:03 AM | #6 |
Norwegian dude
I don't have any pictures of it right now, but i'll see what i can do
I didn't have to remove or modify the chainguard, it fitted right in there. After reading abit on forums and checking out tire manufacturers webpages, it seemed to be more usual to have a 120/60 tire with a 150/60, so i just went with that. |
October 7th, 2010, 08:36 AM | #7 | |
October 7th, 2010, 08:59 AM | #8 |
I'm pretty sure this will be the case with any 150/60 no matter the brand. I believe it has been determined that the BT-016 is the narrowest of the 150 series tires.
October 8th, 2010, 07:10 AM | #9 |
October 8th, 2010, 02:09 PM | #10 | |
Pimpin
Join Date: Nov 2008 Motorcycle(s): Bunch of em Posts: 973
The BT016s pinch less on the rear rim. I'd say the Pirelli's pinch the most, with the Michelins in the middle. |
October 8th, 2010, 04:16 PM | #11 |
self wrencher
Ahh. Which explains why my bt16 doesn't rub the chain guard
October 8th, 2010, 06:00 PM | #12 |
Mine is super close to rubbing. Double-check your adjustment marks to make sure they are identical. Small changes in the adjusters will swing the front of the tire either to or away from the chain guard.
October 8th, 2010, 06:09 PM | #13 |
My BT 016 does rub (the center groove). I'm going to dremel off a notch for clearance. I do have a 15T sprocket which probably causes less clearance (there's about 1/4 inch of clearance, but it rubs when moving). |
October 8th, 2010, 10:59 PM | #14 | |
Edit: Regarding the Pirellis pinching the most, is that for the Diablo Rossos? I found a post of yours (http://www.ninjette.org/forums/showp...3&postcount=19) but the thread didn't specify the Rossos. Thanks for any further assistance. Last futzed with by lux; October 9th, 2010 at 12:14 AM. |
July 24th, 2011, 06:47 PM | #15 |
Join Date: Jun 2011 Motorcycle(s): 2008 Ninja 250r Posts: 94
will a 160/60/17 Pirelli Diablo Rosso Corsa fit? I know nothing about buying tires for a bike, that is the smallest rear they have to offer I can find
"Hey man, I'm not tryin' to start nothin'. But... i wouldn't take that" |
July 24th, 2011, 06:54 PM | #16 |
No.
July 25th, 2011, 06:09 PM | #17 |
July 25th, 2011, 06:41 PM | #18 |
Cuz I can search?
July 27th, 2011, 09:20 AM | #19 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
my bt-016s don't rub, but just to make extra sure I put a couple washers in behind the chain guard to make sure it would clear.
Pirelli Diablo Rosso II Tires | akima | 2008 - 2012 Ninja 250R Tech Talk | 532 | April 28th, 2018 04:33 AM |
Pirelli Diablo Rosso II takeoff | Trailerboy531 | Motorcycle-related | 29 | November 14th, 2013 10:58 AM |
Pirelli Diablo Rosso II So Cal pickup | Trailerboy531 | Motorcycle-related | 6 | March 7th, 2013 05:10 PM |
Pirelli Diablo Rosso II | OzzyDevil | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 18th, 2012 01:16 PM |
Bridgestone Battlax BT-003 OR Pirelli Diablo Rosso II??? | HMRNKING | 2008 - 2012 Ninja 250R Tech Talk | 13 | June 22nd, 2012 02:14 PM |
