August 5th, 2014, 06:02 AM | #1 |
Join Date: Jul 2014 Motorcycle(s): 2005 Kawasaki Ninja 250 Posts: 124
Feet position
Ok - I went out on a ride last night, mainly 25 up to 45 mph roads. I took my time and stayed relaxed - made for a much more enjoyable ride. I was trying to work on keeping my feet pressed in against the bike, and positioned further back where I was closer to the balls of my feet. I had a hard time keeping them in that position - just not used to it. I have a habit of riding with my feet basically where the middle of my foot/arch is on the footrest.
Present: 05 Kawasaki Ninja 250 Past: 02 Honda Rebel, 09 CFMoto Glory 150 |
August 5th, 2014, 06:08 AM | #2 |
Fighting Texas Aggie '05
I actually prefer the toes/ball on the pegs it may just take your some getting used to. As far as feet pressed in against the bike, don't worry about that one so much. My feet move around ALOT during rides, keeps my legs a little more loose and comfortable.
August 5th, 2014, 06:34 AM | #3 |
Certified looney toon
MOTM Jul '13, Jul '14
This is pure opinion and only how I ride.
On mountains or twisty roads, I keep the balls of my feet on the peg. Makes for an easy slide forward onto the pedals and keeps my toes from dragging in tight corners. For comfort and support, I hook my heel onto the top of the rearset and use that to hold my foot in place. In town or traffic heavy roads, I'm about a 75/25 split between balls of feet on pegs or being lazy and keeping my right foot covering the brake (careful not to drag the brake) and my left foot resting under/over the pedal for quick shifting. On straight flat roads or steady traffic, I'm about 50/50 between being on the balls of my feet, or being flat footed with the peg on my arch. Again being careful to have no pressure on the brake pedal. I move my feet a lot, constantly shifting position so my legs and knees won't get stiff.
August 5th, 2014, 11:03 AM | #4 |
i have gangly legs so i find it easier to have my outside foot resting on the peg against the heel/in the middle of the foot, and the inside foot on the toe for clearance.
August 5th, 2014, 11:04 AM | #5 |
I have no legs lol. I'm only 5'3. I can handle the bike fine I'm just trying to get a better position down right on it.
August 5th, 2014, 12:13 PM | #6 |
Shifting foot position while you ride will help with comfort over the long term. There's no harm with putting the arch of your foot on the peg, but using the balls of your feet does carry benefits. As you start to go faster and lean more, you run the risk of having your foot contact the ground.
As a petite female this is of much less concern than for large men. It was something some of our fellow forum members were encountering at their first track day. One even scraped his toe slider a bit. When you get more miles behind you and start to get comfortable with moving around on the bike, using the balls of your feet will help you. It will make it easier to press your leg against the tank and anchor yourself. It's terrific that you're seeking advice and listening to those with more experience than you've got. You're doing great! Keep up the good work and have fun!
August 5th, 2014, 12:33 PM | #7 |
Wrench wench
Join Date: Jun 2014 Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS Posts: 415
Having the ball of your foot on the inside peg while leaning also makes it easier to weigh that peg, which steadies the bike during a lean.
August 5th, 2014, 12:38 PM | #8 |
Join Date: Jan 2014 Motorcycle(s): 1996 Ducati 900SS/SP 45k miles Posts: 132
foot position . .. .
You have better feeling with the balls of your feet on the pegs. You will develope sensitive feet, feeling vibrations, bumps, no vibrations. You will gain the ability to move your feet between shifting and braking without thinking about it. Practice makes perfect, but make your practice technically correct.
'09 Ninja 250R track only SOLD "If everything seems under control, you're not going fast enough." -Mario Andretti |
Feet down - Which method do you use? | Motofool | Riding Skills | 32 | May 31st, 2015 08:10 AM |
[nytimes.com] - Why Walk 30 Feet When You Can Text? | Ninjette Newsbot | Motorcycling News | 0 | August 27th, 2013 07:00 AM |
Could you live in 258 square feet? | Alex | Off-Topic | 25 | May 20th, 2011 11:18 AM |
[motorcyclistonline] - Zeros At 13,000 Feet | Ninjette Newsbot | Motorcycling News | 0 | November 3rd, 2010 08:20 PM |
Whats on your feet??? | mike_sema | Motorcycle Gear | 77 | April 10th, 2009 01:20 AM |
