#1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
Is this screw with yellow paint the one for carb syncing?
Is it? It's attached to the throttle cables.
#2 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
That screw appears to be the throttle adjusting screw.
Ron Ayers parts fiche marks that screw as #92001-1998 "BOLT,THROTTLE ADJUST". A closer look at the service manual confirms the orientation of the screw. In addition, the throttle adjuster seems to be the only screw w/ a spring that is oriented parallel with the entire carb assembly. So the top of the screw would be parallel w/ the diaphragm cover. |
#3 |
Motorcycle Nurse?
So what screw adjusts carb vacuum?
#5 |
Motorcycle Nurse?
So this is the screw to adjust when syncing the carbs? It's not like the idle screw is it?
#7 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
Yes that is the screw to sync the carbs. It will open or close the left carb until it matches the right one.
Carb swap, setting mixture screw | bowerbird100 | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 5th, 2014 08:01 AM |
Carb Sync Screw Replacement? | MasterCylinder | 1986 - 2007 Ninja 250R Tech Talk | 8 | April 24th, 2012 07:54 AM |
A thought experiment on carb syncing thru-out the rev range | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 15th, 2011 02:01 PM |
carb syncing | wayanlam | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 11th, 2010 12:42 AM |
Carb screw holes | Momaru | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 11th, 2010 02:16 PM |
