November 24th, 2010, 06:53 PM | #1 |
certified newbie
Join Date: Apr 2010 Motorcycle(s): 08 ninja 250r blue Posts: 127
slamming on brakes
im amazed that im alive right now. i was going about 55mph about three car lengths away from the car in front of me. the driver in front decided to slam on the brakes coming to a complete stop and so i pressed on my front and back brakes real hard. im pretty sure i locked up the wheels because i started to skid and i felt the seat go left and right as i skidded towards the car infront. luckily i ended up coming to a stop right next to the car that slammed its brakes. so i rode home and i dont think the bike felt right the rest of the way home. it felt a little wobbly. any idea if or what i might have messed up on the bike?
November 24th, 2010, 07:15 PM | #2 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
Your nerves!
November 24th, 2010, 07:20 PM | #3 |
When you locked up the tires you likely flat spotted them. It will take some time for the tires wear even again.
November 26th, 2010, 09:44 AM | #4 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
+1 you flat spotted the rear. Doubt you locked the front, or you would be knee deep in gause pads for your road rash.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
November 26th, 2010, 11:04 AM | #5 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
November 26th, 2010, 09:20 PM | #6 |
I know it's easy for me to second-guess you after the fact over the internet, but three car lengths at 55 mph means you were following FAR too close. Give yourself more room from now on and you'll have fewer moments like that.
Kevin 2009 Ninja 250R |
November 26th, 2010, 09:57 PM | #7 |
Yeah, three car lengths is like 50 feet, and 55mph is like 80fps, so you had like 2/3 of a second ahead of you!
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
November 28th, 2010, 01:36 PM | #8 |
Sounds like you need to practice emergency braking... find an empty road and try braking hard from 55-60-70 whatever without locking up the brakes. Practice makes perfect, you can't afford to not have this skill, this time you got away safely.
November 28th, 2010, 10:19 PM | #9 |
certified newbie
thanks guys. i looked up a few articles on proper emergency braking and im going to practice tomorrow. gonna try to even out the flat spot while im at it
locktite ALL the things!!! |
March 26th, 2011, 01:05 PM | #10 |
Join Date: Oct 2010 Motorcycle(s): 93 ninja 250 Posts: 111
great time to work on preventing skids as well
March 30th, 2011, 02:57 PM | #11 | ||
Join Date: Oct 2010 Motorcycle(s): currently: Yamaha YZF 250 dirt/motard Posts: 787
What should you do if you feel the tires begin to skid and slide all over the place (besides pray and hope you stop in time?) Also onizthegnome mentioned that the seat felt like it was sliding from left to right. What do riders tend to do when emergency braking that makes the bike wobble or slide from side to side??? Quote:
What were some of the best tips you took away from the emergency braking articles you read? Misti
"Leap and the net will appear!" superbikeschool.com www.motomom.ca |
April 1st, 2011, 08:45 AM | #12 |
Join Date: Apr 2011 Motorcycle(s): 2009 Ninja 250R (RED) Posts: 59
I just had a similar incident myself this morning just not with a car.
There is a notorious traffic light that cycles through yellow very fast. Luckily I was alone on the road this morning but parked at the light was the police, they park where it sets off the light rotation quite often as it tries to let the side traffic (police car) go. Needless to say I was going 45 (speed limit) when I saw the police and the light changed - had to slam on the brakes because he was just waiting for me and everyone else who tries to make it through the 2-3 second yellow. I guess I need to practice quick stops too... I killed the bike engine as I was concentrating on braking and not the clutch. I stopped right at the line, looked over at the car and he was just smiling. I had to restart the bike made it through the light but saw it change again in my rear view mirror - next vehicle... I guess I learned to try to remember clutch, front brake and rear brake for a quick stop. |
May 8th, 2011, 02:51 PM | #13 |
If you lock the rear ride it out until you stop. If the rear wheel regains traction you will likely highside. If you lock the front, let off of it asap.
May 8th, 2011, 02:54 PM | #14 |
dont forget to practice emergency swerves. In some cases , no amount of braking is going to save you and you will have to swerve.
May 8th, 2011, 03:14 PM | #15 | |
May 9th, 2011, 12:25 PM | #16 |
This is usually if you are turning. Basically, restoring rear-wheel traction with the two wheels pointing differen't directions is a bad, bad thing. When going straight, they are usually aligned enough to regain traction and brake properly.
May 9th, 2011, 03:59 PM | #17 |
im amazed that you're alive right now
May 10th, 2011, 06:24 AM | #18 |
Join Date: Aug 2010 Motorcycle(s): 2011 KTM 990 ADV Posts: 234
I don't know where you are at as a rider, so take the following as you need it:
Keep your braking and swerving separate. The harder you are braking the less traction you have for turning, and conversely, the harder you are turning, the less traction you have for braking. |
May 10th, 2011, 07:29 AM | #19 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Contrary to what online will tell you, you can lock up the front wheel, and not go down. Ive locked the front at 70mph on a bike before, ...bike went straight just like normal. I however dont recommend it, because normally...it does dump you and real quick.
And if you lock and release the rear wheel, it doesnt automatically toss you off in a highside. It mostly depends on how far the rear wheel gets out of alignment with the front. If the bike is still upright and level, and the rear wheel hasnt skipped out more than a couple of inches...letting off wont do much. You might get a little bump as it re-centers, but its still better than keeping it locked, because the bike stops faster if its not locked. However, if you are leaned over or the tire slides out a foot...you might as well hang on to what youve got because you are going to dump it anyway....better lowside than highside. |
May 10th, 2011, 09:34 AM | #20 |
I bent my front wheel (different bike) weekend before last by hitting a rock. Bent it enough to start leaking air, but was slow enough to get me home. Had it fixed just this past weekend at a local shop, and all is well. Was chatting with a friend about it, and he was riding with someone a few years back who hit a rock so hard, that it bent the front wheel so badly it immediately locked the wheel when it couldn't fit through the brake caliper anymore. This was at highway speeds, and somehow the rider managed to keep the bike upright with a locked front wheel all the way down to zero. All I can imagine is that he is lucky it was a somewhat heavy bike, with less than uber-sticky tires, or I would expect that a stoppie was a distinct possibility.
He was just sitting there in the middle of the road trying to get the bike to move and wondering why it wasn't going an inch, until they got off and looked at the front wheel and saw the problem. Had to be lifted off the road and towed home. But, to your point, it is possible to lock a front wheel and not immediately crash. It's just not recommended.
May 12th, 2011, 02:01 AM | #21 | |
May 12th, 2011, 06:10 AM | #22 |
May 12th, 2011, 09:02 AM | #23 |
Giggity Giggity
Join Date: Feb 2009 Motorcycle(s): 08 ninja 250R aka Hiryu Posts: 481
While practicing emergency stops in a parking lot it would benefit to also learn fast downshifting with throttle blips. I have found the rev matcing/engine breaking helps me a lot than with the clutch in and f/b brakes only.
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods |
May 12th, 2011, 09:37 AM | #24 |
You don't want to be incorporating engine braking into your emergency stops. You can't stop as quick that way.
May 12th, 2011, 09:43 AM | #25 |
Giggity Giggity
Maybe im just to used to hammering down in gears no matter how I break, it just seems to me I have to press harder on the breaks when I am just coasting.
Brakes what would you do? | crazymadbastard | General Motorcycling Discussion | 7 | March 30th, 2015 11:27 AM |
Need new brakes! | corksil | 2008 - 2012 Ninja 250R Tech Talk | 18 | September 28th, 2014 11:36 PM |
Brakes | momoru | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 10th, 2014 07:26 AM |
Better brakes?? | LittleRedNinjette | 2013 - 2017 Ninja 300 Tech Talk | 39 | July 11th, 2014 08:42 AM |
[topix.net] - A motorcyclist is dead after slamming into a pickup truck | Ninjette Newsbot | Motorcycling News | 0 | March 3rd, 2013 04:20 PM |
