August 9th, 2011, 01:34 PM | #1 |
Join Date: Jan 2011 Motorcycle(s): 2010 Kawasaki Ninja 250R Special Edition Posts: 31
Help! Both Headlight Bulbs Not Working!
A week ago, both headlight bulbs were working fine, but i noticed that the low beam bulb burnt out so i just rode around with the high beam on, but after three days, the high beam didnt light up? It doesn't seems burnt out like the low beam.. and now I'm riding without any head lights :/.... So today I went ahead and bought new bulbs, replaced them and still nothing????? Anyone have an Idea what the problem might be????
August 9th, 2011, 01:40 PM | #2 |
ninjette.org Pirate
Join Date: Nov 2010 Motorcycle(s): 2009 Ninja 250r Posts: 301
Your lowest repair-cost fix is to return the new bulbs, maybe you just bought a bad pair.
"She said I can't get a bike, so I dumped her." |
August 9th, 2011, 01:51 PM | #3 |
Did you check the fuse for the headlights?
August 9th, 2011, 01:53 PM | #4 |
August 9th, 2011, 08:19 PM | #5 |
August 9th, 2011, 08:20 PM | #6 |
August 9th, 2011, 08:21 PM | #7 |
August 9th, 2011, 09:53 PM | #8 |
Update
"UPDATE" Fuse was blown!! replaced it and now the headlights works! Thanks a lot fellow ninjettes lol otherwise i would of took her to a local motorcycle shop :P
August 10th, 2011, 12:10 AM | #9 |
Just for future reference if someone else reads this, fuse box is underneath the seat. It should already have a couple spares that you can swap out. Just remember to replace them when you have the time
August 10th, 2011, 01:20 AM | #10 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
Make sure to not leave your keys in the ignition without the bike being on. I did that when I was first getting started and popped 3 fuses in a week! Thought something was wrong with the system but I was just being a noob...definitely got pretty good at getting that seat off quickly though...
August 10th, 2011, 07:32 AM | #11 |
ninjette.org Pirate
Glad you got it fixed! Good on you!
August 14th, 2011, 11:15 AM | #12 | |
Replacing the headlight bulbs? | Aurodox | 2013 - 2017 Ninja 300 Farkles | 2 | October 26th, 2013 06:01 PM |
What headlight bulbs do the gen1 bikes have? | CThunder-blue | 1986 - 2007 Ninja 250R Farkles | 24 | September 7th, 2012 01:21 PM |
replacement headlight bulbs | eddiekay | General Motorcycling Discussion | 1 | October 18th, 2011 11:43 AM |
Philips X-tremePower H7 headlight bulbs | arcman | 2008 - 2012 Ninja 250R Tech Talk | 23 | September 27th, 2011 02:13 AM |
headlight bulbs | gamma500 | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 29th, 2009 11:15 AM |
