August 14th, 2009, 02:15 PM | #1 |
WTF Were They Thinking??? - handlebar screws
New nightmare:
I bought bar end mirrors for my bike and went to put them on today. After breaking three screwdrivers (literally snapped the tips off) I resorted to drilling and then using a screw extractor. The bar ends are held on by 1.5" bolts with a full tube of RED locktite. It seems to me that this is a bit excessive as if you need to have the throttle serviced, they would have to replace the screw because there is no way you could save it. Anyone else try this horrible task? My hands are killing me.
It's not worth doing if you aren't completely stressed out about it. |
August 14th, 2009, 02:17 PM | #2 |
I've had to put some heat to those to get them loose (torch).
August 14th, 2009, 02:18 PM | #3 |
August 14th, 2009, 02:49 PM | #4 |
Thanks for not reading my mind and sending me this before I started Kelly
Here she is now:
August 14th, 2009, 02:54 PM | #5 |
Join Date: Jan 2009 Motorcycle(s): '08 250R (sold), '05 ZX6R / 636 Posts: 355
Kelly's DIY bailed me out.. I had to readjust the grip on my 636 and didn't have any spray adhesives to glue it back on. Instead of clear spray paint, I used clear spray clearcoat and that worked beautifully
August 14th, 2009, 02:56 PM | #6 |
Join Date: Jul 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 410
1. I love your bike's color scheme with the U.S.S.R. flag motif, damn cool.
2. How do you like the bar end mirrors thus far? Better visibility? 3. You are in hella good shape. |
August 14th, 2009, 03:30 PM | #7 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
Are those rim stripes yellow or gold? Your bike looks good.
August 14th, 2009, 03:34 PM | #8 |
Damn, Thomas... get out and exercise every once in awhile, will ya???
frickin' kids!!! |
August 14th, 2009, 03:35 PM | #9 |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
August 14th, 2009, 10:05 PM | #10 |
Join Date: Feb 2009 Motorcycle(s): Black 2009 Ninja 250 Posts: 52
yeah the guy at the bike shop had to us an impact drill to get my bar off when i got the bar ends changed.
August 15th, 2009, 09:35 AM | #11 |
1. I'm a high school teacher, so all I do in the summer is go to the gym, run, ride bike, etc. Not bad for a 40 year old, huh?
2. The mirrors are better than stock because they aren't reflecting your shoulders. However, because the handlebars are so raked, you have to look down to see them and when you lie down you can't see them at all. So, IMHO, they are worth putting on as they do work better, but they are far from ideal.
August 16th, 2009, 03:44 PM | #12 |
North Alabama Mtn. ryder
cool graphics comrade
QTRltrPWR |
August 17th, 2009, 06:11 AM | #13 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
I remember the horror of changing the bar ends... ende up with me holding the screwdriver in tight, and my dad using a pair of vice grips on the screw driver to take em out - took a bit of effort but it worked
August 17th, 2009, 06:27 AM | #14 |
Bike Thrasher
Join Date: Apr 2009 Motorcycle(s): 2008 EX250r Posts: 334
I just drilled them out after about 4.5 seconds of trying to heat and a screw driver.....
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns |
August 17th, 2009, 06:51 AM | #15 |
Join Date: Nov 2008 Motorcycle(s): '09 Ninja 250R Posts: 518
I heated 20-30 seconds with a torch and they came out with ease. I read on my red loctite bottle that it breaks down at something like 250 F. There is a **** load of loctite in there though!!
August 17th, 2009, 06:51 AM | #16 |
Join Date: Apr 2009 Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold) Posts: 586
Am I the only one that thought of Ivan Drago when I saw the bike? The colors work well.. even the sliders!
2000 Honda CBR600F4 Silver and Red 1999 Kawi Racing Green Ninja 250 sold |
August 19th, 2009, 02:03 PM | #17 |
3 for street, 2 for dirt
Join Date: Mar 2009 Motorcycle(s): 2008 Can Am Spyder PE #1344 / 2009 Kawi KLX140L Monster Energy / 2009 Kawi Ninja 250R (RIP 8.23.09) Posts: 586
I'm actually interested in raising my handlebars on my 09... like 1"... does anyone make handlebar risers for our 250's? Any adverse effects on handling? I have short arms so there is quite a reach for me. I'd like to be able to sit a little more upright and still have some bend in my arm instead of riding stiff-armed.
Feel free to look me up on facebook. |
August 19th, 2009, 02:08 PM | #18 |
just buy a front lowering kit for your bike, install the lowering blocks, but don't do anything w/ the forks. That will effectively raise the handlebars. Can't say if you'll have any problems w/ control cable/hose lengths though.
August 19th, 2009, 02:13 PM | #19 |
Oh, okay. I might get lucky. I saw that Roaring Toyz has some 1" blocks.
August 19th, 2009, 02:42 PM | #20 | |
Join Date: Jul 2009 Motorcycle(s): F650GS Dakar, FJR1300, Ninja 250R Posts: 47
If you're raising the forks as well to lower the front end, you can get away with the stock lines (just need to move the brake hose clamp). On the clutch side, the cable is very tight unless you re-route it. And by re-route, I mean pulling the cable out of the metal loop. That's about it. Ergo wise, using the risers and lowering ONLY the front end will give you pretty much the SAME riding position as stock, so that won't help you. Sounds like all you want is a more upright riding position so use the risers and leave the forks alone. Unfortunately, that means getting new brake lines and the work associated with putting them on (which is not hard at all!). Like you, I wanted a more upright position so I didn't touch the fork position and just used the risers. It's much more comfortable for me now, and because I'm more relaxed and balanced, I'm in better control of the motorcycle. I'm actually riding faster at the same comfort level with the risers than without. The only negatives are ergos for very aggressive and track riding where you're typically tucked, hanging off, and/or putting more weight on the front end. In that case, you'll want bars possibly lower than stock based on your reach and height. Cheers! |
August 19th, 2009, 02:47 PM | #21 | |
Hey, you're in the Bay Area, maybe you'll want to help a fellow Ninjette rider out???
August 19th, 2009, 03:01 PM | #22 | |
Anyways, I'm done hijacking of this thread. Maybe we can setup a riser and braided line install day for the Bay Area folks... |
WTF!!!!!!!! | LNasty | Ride Reports | 19 | December 28th, 2013 02:29 PM |
WTF is going on here? | Rekognize | General Motorcycling Discussion | 19 | November 20th, 2012 02:51 PM |
New problem! WTF is this.... | SemperFudge | General Motorcycling Discussion | 22 | October 15th, 2012 12:09 PM |
Holy ****, wtf? | Cab305 | General Motorcycling Discussion | 26 | March 22nd, 2012 11:23 PM |
Wtf??!! | nutless_neo | General Motorcycling Discussion | 14 | September 3rd, 2010 09:35 PM |
