Old January 29th, 2012, 07:37 PM   #1
WarWolfX0
WarWolfX0's Avatar
Motorcycle(s): 2010 Ninja 250R SE (EX250JAFA)
O2 sensors
so i am looking to fine tuning my bike
i have a carb with a dynojet kit
i was thinking abut getting this air/fuel gauge
http://www.equus.com/Product/8366/2%...el-Ratio-Gauge
it looks to use narrow band o2 sensors
Since there is a chance that in the next year or 2 i will upgrade to efi
i was wondering if the efi uses narrowband o2 sensors
and what size is the bungs?
I have seen bungs between 12 and 18mm
i have seen info about wideband o2 sensors
and was hopping that it uses the same size bung
from what i seen it is 18mm (from LSU 4.9)
not sure if there is smaller.
what is the smallest size wideband sensor?
has anyone tuned the fuel air mixture using the the wide band o2
http://www.innovatemotorsports.com/x...tid=16328&js=y
is it easier/better to use it then wide then narrow band for tuning?
and yes i know that wide band o2 sensor and narrow band are not comparable with each other.
i was even thinking about using a wide band to set each side individually and putting plugs in the bungs.
Dose anyone know about the if ninja in other countries and what o2 sensor it uses?
WarWolfX0 is offline   Reply With Quote
Old January 29th, 2012, 09:05 PM   #2
why would you bother tuning the carbs if you are going to switch to efi? and vice versa.
Old January 29th, 2012, 09:23 PM   #3
WarWolfX0
WarWolfX0's Avatar
So you are saying that i should ride, possibly rich for 2 years and not have all my power available to me now? (fouling my spark plugs)
or what i think, install the bungs now, tune my system, then in 2 year switch to efi.
i am just thinking of the future.
i just installed the dynojet a few days ago. and i would like to tune the air/fuel mixture independently, and as far as i know this is the only way of doing it.
efi is last on my list of upgrades
with my attempt at a custom header being next.
Old January 29th, 2012, 10:21 PM   #4
just tune the carbs like normal. theres almost no point installing o2 sensors before you get efi. its not that hard to tune carbs by feel. its pretty obvious if a jet works well or not. start with the biggest main and go down until it gets worse. then go up one jet to stay on the rich side. then tune your needle position for midrange and then tune the mixture screws at idle
Traffic Light Sensors Ignoring Bikes n4mwd General Motorcycling Discussion 175 June 18th, 2014 06:43 AM
Recording sensors Yakaru 2013 - 2017 Ninja 300 Farkles 12 April 4th, 2014 12:00 AM
Left turn sensors SemperFudge General Motorcycling Discussion 17 November 1st, 2012 10:26 AM
I Hate Street Light Sensors.... kevheads General Motorcycling Discussion 36 June 30th, 2011 09:22 AM
*HELP* Brake Light and Sensors Brently7785 2008 - 2012 Ninja 250R Tech Talk 3 April 20th, 2010 06:01 AM
