June 19th, 2014, 06:18 AM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Front brakes getting weak over time.
So I have been having a problem with my front brakes getting weak requiring me to bleed the air out every few weeks to a month. The brake lever will slowly get loose but still works pretty well. I usually just tie the front brake to the bars and leave it over night and it will be rock solid in the morning and last for couple weeks. I am guessing I am getting air in the system some how but not sure where. I use synthetic dot 3+4 fluid and did a front caliper rebuild a few months back though the seals were fine.
Last futzed with by agentbad; June 19th, 2014 at 10:00 AM. |
June 19th, 2014, 09:38 AM | #2 | |
MOTM - Mar '13, Jun '14
June 19th, 2014, 10:07 AM | #3 |
Just ordered this one.
http://www.amazon.com/gp/aw/d/B000GZ...ot_redir=1&tbm |
June 19th, 2014, 11:33 AM | #4 |
it seems to me like pressurizing the system and leaving it pressurized for a long time would not be so great for it considering they are rubber lines and not the highest quality calipers or master or seals
June 19th, 2014, 12:01 PM | #5 |
I bled the air out last night and the lever is very solid today. It's bothers me because my roommate rides a rebel that he neglects most of the time but the front brake lever pull is strong regardless.
June 19th, 2014, 12:05 PM | #6 |
take his master cylinder and replace it with yours? redo the seals on your master?
Please Help! I'm an idiot without front brakes! | Falcor | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 1st, 2014 07:36 AM |
Front brakes | fast1075 | 1986 - 2007 Ninja 250R Tech Talk | 4 | January 22nd, 2014 01:45 PM |
Front Brakes | checho323 | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 25th, 2012 02:16 PM |
Questions about front brakes | outasight20 | 1986 - 2007 Ninja 250R Tech Talk | 21 | December 27th, 2011 03:06 PM |
Best brakes for 08+, front and rear combo? | KawiRider | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 2nd, 2011 05:25 PM |
