May 11th, 2015, 02:05 AM | #1 |
LED Tail Lights
Hi all, did anyone have/tried this on? http://www.ebay.co.uk/itm/201179502856
What is your opinion about it? I'm thinking of getting one in smoke but not sure whether with the amount of LEDs I will be more visible or not. I'm looking for a better looking tail light but of course, visibility is important. |
May 11th, 2015, 02:40 AM | #2 |
Freedom for Germany
This http://www.customled.com/products/20...led-tail-light and nothing else...
May 11th, 2015, 07:24 AM | #3 |
MOTM - June '15
agreed!
May 11th, 2015, 07:36 AM | #4 |
No firsthand experience, but the eBay one looks fairly ineffective. It uses regular LEDs, which aren't as bright as some of the SMD ones. It uses a relatively small number of LEDs, so there simply isn't as much light output. Using a variety of different colored LEDs means a smaller number of LEDs for each color (i.e. turn signal is a small area, brake light is a small area, etc.). I'm counting 25 LEDs in that whole assembly. For comparison, a standard 1.85" round Radiantz cluster has 48 LEDs (they fit 25 on their 1.25" cluster). It also has standard bullet connectors on the wires, as opposed to an OEM connector.
I know people generally don't like the look of standard turn signal stalks, but taillights with integrated signals inherently mean a smaller brake light and often smaller turn signals too (on top of the signals being too close to be legal). They look better, but they really do cut into your bike's visibility too.
May 11th, 2015, 07:47 AM | #5 |
MOTM - June '15
The blaster X was more visible to me, when I was 3 or 4 bikes behind than some of the closer bikes were...
it's a great light, and the signals are also quite visible
May 11th, 2015, 10:36 AM | #6 |
Blind 250 Loving Whore
I have the customled and it's bright for sure. Plus you get the strobe on first press which is really nice. The turn signals are switchbacks so you don't lose any tail light size for them.
May 11th, 2015, 11:51 AM | #7 |
Thanks guys for your feedback, Blaster-X seems nice but I'm not really too keen about adjusting with relays etc...
I came across this, which looks also nice and maybe very similar to Baster-X. What is your opinion about this? http://www.motodynamic.com/kawasaki/...hts-smoke.html Many thanks guys |
May 11th, 2015, 12:41 PM | #8 | ||
May 11th, 2015, 12:44 PM | #9 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
What Bill said. Any change to LED and you will need a different relay.
May 11th, 2015, 04:03 PM | #10 |
MOTM - June '15
I did nothing to install my blaster x
May 11th, 2015, 05:20 PM | #11 |
Freedom for Germany
May 12th, 2015, 02:41 AM | #12 |
Here's a good video showing the difference between Blaster-X and MotoDynamic:
https://www.youtube.com/watch?v=zYJkEbUAkBQ As you rightly said, Blaster-X is brighter, but I can live with the difference between the two so I opted for MotoDynamic, hoping not to have to mess with the wiring. I let you know how it goes and maybe post a video of the outcome! |
May 12th, 2015, 08:10 AM | #13 |
May 12th, 2015, 09:26 AM | #14 |
MOTM - June '15
only if you have LED in the front as well.
LED integrated tail lights now at NewEnough | adouglas | 2008 - 2012 Ninja 250R Farkles | 39 | August 29th, 2011 01:12 AM |
Any cheap LED tail lights out there? | painkille137 | 2008 - 2012 Ninja 250R Farkles | 12 | August 11th, 2011 11:40 AM |
LED brake/tail lights not working properly... | sktrs_kpr | 1986 - 2007 Ninja 250R Farkles | 1 | April 8th, 2010 09:59 AM |
