November 20th, 2015, 04:48 AM | #81 |
Freedom for Germany
Welcome Patrick, good to see a specialist for springs entered the forum
November 21st, 2015, 08:58 PM | #82 |
Slower than you.
Join Date: Oct 2015 Motorcycle(s): CBR600RR, CB750, EX300 (半蔵) Posts: 667
MOTM - May '16
I have no idea how this relates to springs or transmissions, but you've made me glad I'm single. I usually have to go to work, where most of my team is either divorced or on marriage 2 or 3, for that.
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research. If another thread is linked or quoted, go read it yourself. |
November 23rd, 2015, 10:19 PM | #83 | |
Board Member
Will the 92081-112 spring be stiffer in a 2009 250? The spring is longer than stock....
November 24th, 2015, 06:41 AM | #84 | |
Join Date: Nov 2015 Motorcycle(s): DR350, Ninja 250 Posts: 69
That's not true. If we cut a spring in half, we reduce the number of active coils. Recall, spring rate goes by... where... R = Spring constant G = Modulus of shear N/mm2 d4 = wire thickness to the power of 4 D3 = Outside diameter to the power of 3 n = active coils .. as n gets smaller, k (what they call R here) gets larger. This makes sense intuitively if we think about breaking a pencil. Pencils flex a little, but if you break them, you've got less leverage on the shorter piece, and it appears 'stiffer'. A coil spring is just a torsional load applied to a rod, and we can treat it to the same. Longer is easier to flex, shorter... not so much. So again... we really need to find out what the spring constant is for all of these springs, as well as the compression lengths at min and max deflection. At that point, it's easy to find a cheap solution. Last futzed with by Kestrel; November 24th, 2015 at 01:44 PM. |
November 24th, 2015, 06:51 AM | #85 | |
But I haven't verified this, as I don't have access to a NewGen.
November 24th, 2015, 06:54 AM | #86 | |
As I've stated, the difference is noticeable with the upgrade OEM spring over the PreGen Ninjette OEM, but not as stiff as the Blue Magic Spring, and it's a lot cheaper. I've tried both, and in the end I went with the upgrade OEM spring, as the Blue Magic Spring was a bit too stiff for street use IMHO.
November 24th, 2015, 07:07 AM | #87 | |
November 24th, 2015, 07:25 AM | #88 |
Fighting Texas Aggie '05
The comparison we need is factory new gen vs OEM upgrade spring, did anyone get those two side by side. I have the factory pro in my track bike but refuse to spend another $40 on a spring lol.
November 24th, 2015, 07:25 AM | #89 |
I suppose I need to just pick up one of these OEM upgrade springs on my next order and measure the free length, wire thickness, and# coils or somebody send Patrick the all the springs so he can test them and finalize the rates and put it all to bed lol.
November 24th, 2015, 12:00 PM | #90 | |
Board Member
November 24th, 2015, 12:02 PM | #91 | |
Board Member
FYI, my stock new-gen spring only has 10,000 miles on it. |
November 24th, 2015, 01:15 PM | #92 | |
also if you could do a subjective "which feels stiffer" mostly wondering if the OEM upgrade spring is between the newgen and the factory pro of if the OEM upgrade is between pre and newgen
November 24th, 2015, 01:16 PM | #93 |
assuming both springs have the same rate, the spring with the longer free length will have greater preload and provide a resultant force that is greater for that specific installed length yes
November 24th, 2015, 01:49 PM | #94 | ||
Ultimately, we need to figure out a few things... 1)What is the distance from the shift star thing to the top of the bolt / cap, once everything is bolted down into place in the engine 2)What are the spring rates for each of the springs The # of coils and all of the other information doesn't really matter in practice. Once you know those two things, it's simple to solve for the rest with good old F=KX. |
November 24th, 2015, 01:50 PM | #95 |
I would like to know the difference as well for NewGen Vs Blue Magic.
The OEM upgrade spring is used in a lot of models, for a lot of years. I'd be curious to seem the difference between the OEM upgrade spring 92081-112, and the NewGen spring 92144-1580. Which according to Kawasaki it fits PreGen and NewGen models.
November 24th, 2015, 03:32 PM | #96 | |
In asking for the specific geometry of the springs measured, one would be making the assumption (this one being my assumption) that the material selected for the two OEM springs would be similar and as a result have a similar modulus. In the end if calculating the different rate assuming similar (same) modulus provides one spring is X amount stiffer than the other, we gut check with the requested "feel" test of stiffness. I did for the record recommend sending them to you to just test the dang rates lol.
November 24th, 2015, 08:35 PM | #97 | |
Board Member
November 25th, 2015, 01:11 PM | #98 |
If you don't mind I think it would be great if we could get them all rate tested side by side but if not, no sweat.
January 10th, 2016, 10:16 PM | #99 |
I put in my blue spring 'upgrade' today.
First impression is that gear changes required more foot effort. Previously I could gently nudge the bike into gear from neutral. With the blue spring installed it took more downward pressure. Definitely felt different from OEM, so I checked chain tension (which can also cause shifting issues) and it was a tad loose. Tightened chain to spec and went for a ride. With the blue spring -- shifting requires more force on the shift lever to change gears. I can see how an extremely worn old track bike might go into neutral when shifting from first to second with your primary focus on the line you're about to take through the first turn. I've done it a few times myself when my focus was moreso on maintaining (too much) speed into a turn. The blue spring is a more conscious effort to shift. Apart from that, no change. Bike is around 30k miles, relatively new chain and sprockets. I said I'd post a review once I installed it so here it is.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
January 10th, 2016, 10:19 PM | #100 |
Slower than you.
MOTM - May '16
So it's not magic then? Bummer. Thank you for the review.
January 11th, 2016, 12:40 AM | #101 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
The new spring is no different than learning something new, once you get some time under your belt with it, you'll be accustomed to it and will no longer think about the effort it takes.
January 11th, 2016, 06:13 AM | #102 | |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
None of the tracks I race on require me to be in 1st gear for more than 2 seconds, after that the lowest I would ever see was maybe 3rd. My false neutrals were happening most between 4th and 5th, on an engine with less than 4k miles. The blue spring fixed.
MCRA.com |
January 11th, 2016, 12:17 PM | #103 | |
Board Member
January 12th, 2016, 05:53 AM | #104 | |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
What you are really doing with a spring is you are twisting it along the lengthwise axis of the wire. A spring is just a torsion bar in coiled form. To demonstrate this to yourself, take a 3ft piece pf 1/8" by 1" aluminum flat stock and clamp one end in a vise. Then take an adjustable wrench, tighten it down on the other end, and then apply force to twist the aluminum in the lengthwise axis. Note the feel of how much force that you have to apply for a given distance. Now cut the aluminum in half and repeat the process with the wrench. You will find that you have to apply more force to get the aluminum to twist the same distance. If you want to increase the spring rate of your stock shift detent spring it may be possible to do it by simply cutting a few coils off the stock spring, Making sure that the cut end is flat and perpendicular as possible to the spring's lengthwise axis. Then you replace the distance that you cut off with a spacer of a length equal to the amount of spring that you cut off. and you now have a stiffer spring. The caveat is that you must make sure that you don't cut too much off the spring and run into coil bind. |
Factory Pro Detent Arm Shift Kit | Surferboy120 | 2013 - 2017 Ninja 300 Tech Talk | 62 | February 13th, 2019 07:41 PM |
FactoryPro Shift Spring -- anyone used? | abhijitz | Ninjettes At Speed | 2 | May 15th, 2014 05:35 PM |
[kropotkin thinks...] - Honda's Magic Gearbox: Worth A Few Hundredths A Shift | Ninjette Newsbot | Motorcycling News | 0 | March 19th, 2011 05:01 AM |
blue magic | blue magic | New Members | 12 | June 14th, 2010 11:50 AM |
