Old November 24th, 2015, 07:02 AM   #1
mbelew
Motorcycle(s): 2006 Ninja 250R
Disconnected hose mystery
It is wonderful to see such an active forum, for an older bike. So maybe you can help.
My son just bought his first motorcycle, a 2006 Ninja ex250, and we are taking it "apart" to do maintenance. We removed the air box yesterday and sitting disconnected under it was a hose that is about 8 inches long, I guess about 1/4 od. It has a factory plug on one end, and factory spring clip on the other. The strange thing, IMHO, is that it has what appears to be transmission fluid in the hose, pink/red in color; oil like consistentsy. It has been a long time, 20 years, since I have had a motorcycle , but I can not think of any place on the engine that would have this type of hose, with this type of fluid.
Any help you can give would be great.
Thanks Mike.
mbelew is offline   Reply With Quote
Old November 24th, 2015, 07:05 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Welcome
Can you post up a photo of the hose lying in the spot you found it?
Worlds fastest 250 ninja
Old November 24th, 2015, 07:10 AM   #3
The drain hose as pictured?
Welcome Mike!
Old November 24th, 2015, 07:22 AM   #4
Kestrel
Kestrel's Avatar
Motorcycle(s): DR350, Ninja 250
OP, that's likely the drain hose for the air box. Ninja 250 utilizes an oil soaked air filter, and the tube catches the run off from that, as well as any oil vapor that may collect in the air box. Red color matches some of the filter oils that are available, and likely explains what you're seeing. Just drain the tube, and carry on as usual.
Kestrel is offline   Reply With Quote
Old November 24th, 2015, 07:22 AM   #5
mbelew
That's it.
Thank for the quick reply.
I looked at the diagrams online, and was able to find it. Sorry for the post before researching more. Can you think of a reason it might have red, transmission like fluid in the tube. I think that is what was throwing me off. The fluid was clean and the tube almost full.
Mike
Old November 24th, 2015, 07:25 AM   #6
mbelew
Thanks all
Kestrels answer about the oil covered filter makes perfect sense. Thanks for the help.
Old November 24th, 2015, 07:26 AM   #7
It's reddish because of dust, dirt and oil filter oils available on the market AND... isn't this hose normally plugged by the factory?
Old November 24th, 2015, 08:17 AM   #8
Brother Michigan
Motorcycle(s): 2013 Ninja 300
I think we should make a sticky for this problem; seems like it pops up every couple of weeks. We could name it "What's this disconnected hose?"
(No disrespect meant toward the OP at all, it legitimately is something that gets asked very often.)
DISCLAIMER: I generally have no idea what I'm talking about.
Old November 24th, 2015, 08:42 AM   #9
...... isn't this hose normally plugged by the factory?
Yes, that hose has a removable plug to avoid infiltration of non-filteted air and meant to be removed about each valve adjustment and drain excessive oil.
Oil accumulation may happen because the admission valves tend to spray some oil back onto the filter during compression overlap.
If no oil comes out, it is time to wash and oil the foam filter or to replace it when it develops some gaps.
The hose gets hard with Sun light and becomes easily detached from the air box, even when it has a wire clip at that connection.
Welcome, Mike !!!
It is wounderful that you are helping your son with his machine.
Old November 24th, 2015, 05:40 PM   #10
xorbe
xorbe's Avatar
Red, because someone used red Mystery Oil (a brand name) to soak the filter.
Old November 25th, 2015, 09:20 AM   #11
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Yes, or nearly any other foam air filter oil.
On the new gens they just made it a plug. The Pregens have a longer tube to give more of a buffer, and although it SHOULD be drained every oil change as MotoFool stated, it can go much longer. It's mainly there to catch water condensation which forms on the "dirty" side of the air filter because the oil in the air filter forms a barrier to water. The condensation runs to the bottom of the airbox and is captured in the tube. If there is very little water, it will evaporate in a dry climate since that side of the airbox is open to the atmosphere and all that will be left will be excessive oil from the air filter element.
The important part here is to make sure the tube doesn't get so full that it start to overflow into the airbox.
Should I replace the petcock if it leaks while disconnected? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 20 August 20th, 2022 01:57 PM
Coolant Reservoir disconnected hose Ninja Rob 1986 - 2007 Ninja 250R Tech Talk 4 September 23rd, 2014 02:15 PM
Took tank off and disconnected many things, now bike won't stay on. CZroe 2008 - 2012 Ninja 250R Tech Talk 17 July 4th, 2014 03:29 PM
Disconnected my idle control cable... how to fix. ericdrum 2008 - 2012 Ninja 250R Tech Talk 2 May 29th, 2010 10:45 PM
speedometer / odometer disconnected IlBLisSlI 1986 - 2007 Ninja 250R Tech Talk 8 June 16th, 2009 08:46 AM
