October 11th, 2013, 09:25 AM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
front fork disassembly question
hello I picked up 2008 ninja 250 which I love, it came with leaky fork seals and my question is
since I do not have a vice, and I see that I have to loosen the allen bolt on the bottom of the fork could I loosen it while it is still pinched by the triple clamp? I assume it must be removed in order to take the forks apart Thanks Mike Handler. |
October 11th, 2013, 10:01 AM | #2 | |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
CVMA #55 |
October 11th, 2013, 10:26 AM | #3 |
dirty boy
MOTM - Apr '14
Doesn't sound like you have prior suspension experience so I will give you some advice.
Take the forks out of the triple and take them to a suspension specialist place and pay them to rebuild your forks for a little more than it would cost you for just the parts and tools and be uber happy that you didn't have to e'f with it yourself and that it is done right. And if you want you can pay a little more to get better components and get suspension tuned for your weight and type of riding you do. you're welcome
October 11th, 2013, 10:31 AM | #4 |
dirty boy
MOTM - Apr '14
these guys don't seem to far from you, not sure about their reputation but they will still fix it better than you (no offense)
http://epmperf.com/motorcycle-shock-rebuild.htm
October 11th, 2013, 10:52 AM | #5 |
ok thanks guys
I have only redone Springs and forks on my 500 but have not been that deep into it,
I just took the forks off make some preloaded spacers I went with 80 Springs and 15 weight oil & that really helped at the track, minor rear suspension work an SV shock, but I see that this is a little more involved & that bottom screw I lack experience with, I really appreciate the help and the suggestions on the diy the fork was vice and then it was removed, but with the forks leaking like they do I don't have a choice taking them off and having somebody do it might not be a bad idea You guys are awesome thanks that suspension shop is only a town over. So when I botch the job they can fix it. Last futzed with by mikedabike64; October 11th, 2013 at 11:44 AM. Reason: a thank you |
October 11th, 2013, 03:24 PM | #6 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
@Dino 74 has the answer. I would add, disassemble and empty the fork oil first. Then reassemble the fork and clamp it into the triple. Then use a large wrench and clamp the fork above or below the axle. Then unscrew the bolt with a long hex wrench. Do not use a wrench with a ball end, the chance of it striping the bolt is too high. The fork will turn until the wrench is braced against the triple tree stand. (Hopefully you are using one.) then the bolt will come loose. If you need more force, add a box wrench to help you turn the hex wrench. Installation in reverse.
http://faq.ninja250.org/wiki/How_do_..._fork_seals%3F
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
October 11th, 2013, 04:19 PM | #7 |
ok lychee
Ok thanks, I will check the procedure out
October 13th, 2013, 08:06 PM | #8 |
I ended up doing it myself
I wanted to use the company that subxero found for me but when I called they are out until the 23rd racing somewhere.
but since they are so close I figured if I mess it up , but I actually finished it, the allen bolt on the bottom of the fork was a bit of a pain with no vice, I just did what you guys told me to do and it worked out good , I went with 15 weight oil, and for me it is perfect gives me just enough feel up front but not so compliant that it wallows. Thanks everyone, I appreciate the help. |
October 19th, 2013, 04:41 PM | #9 |
Join Date: Aug 2013 Motorcycle(s): 2010 Kawasaki Ninja 250 Posts: 22
Took forks completely apart two weeks ago. With no special
Tools available. The most difficult part is outer bushing, getting it back in using two screw drivers and or anything flat on each side and other than that no special tools needed. All the bushings were like new at 16,600 miles so taking The forks apart was a waste of time. The right fork damper Was damaged. It was loose and turns freely. Doesn't seem to be a problem for now. Put everything back together with new oil with no noticeable difference. Taking the forks apart causes some damage to the inner bushing as that is what drives out the outer bushing. No weight needed for this either. Bushing material coating is like soft Teflon. As far as measuring the amout of oil a tape measure seemed to work perfect from the top of the tube to the oil level 4.3 inches. |
October 19th, 2013, 06:30 PM | #10 |
I had a fork seal leak
I replaced the oil with 15w, I'm kind of glad that I did take it all apart because it was a learning experience worst case scenario I could have brought the forks to a, local shop one of the guys actually found for me, but at least I know in the future I can disassemble them and maybe put some of the gold valve emulators.
Iam trying to do as much as I can because I would rather buy parts then pay for labor which is very expensive these days. I need to check valve clearance I was quoted 285 dollars |
Fork oil question | MattP3 | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 10th, 2015 10:20 PM |
Fork Spring Question | Dsheumaker | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 25th, 2015 05:08 PM |
fork oil question | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 19th, 2014 06:40 PM |
Front bolt / fork question | razingman | 2008 - 2012 Ninja 250R Tech Talk | 4 | July 12th, 2013 06:38 PM |
Sloppy fork bushings after disassembly? | SV_Hadder | 1986 - 2007 Ninja 250R Tech Talk | 1 | April 29th, 2012 05:40 PM |
