February 26th, 2012, 05:39 AM | #1 |
Join Date: Feb 2012 Motorcycle(s): '98 EX 250, '07 650R, '78 CB750k Posts: 5
Clutch Replacement
Clutch is shot and the local guy wants 300 Euro for a new clutch kit. I see one online for $300. I'd love to pay in dollars because the Euro rate is horrible. Is there any difference between the euro model and the US models? It's a '98 EX250 Euro Spec. Also, would you recommend getting the whole kit, or just the friction/steel plates? I'm the 3rd or 4th owner but it's most likely never been raced or "beaten". Neglected perhaps...but not killed.
February 26th, 2012, 06:22 AM | #2 |
What is wrong with the clutch?
I guess they all have same specs.
February 26th, 2012, 07:21 AM | #3 |
Join Date: Oct 2011 Motorcycle(s): 2009 CBR600rr Posts: A lot.
Just remember, depending on how you get it into Italy, you may be liable for import and customs, which could add up to more than the savings of the Euro vs Dollar price.
February 26th, 2012, 09:20 AM | #4 | |
We have a US mail address (US Air Force) so no worries as long as the company ships USPS. Motofool, The problem is when it gets up to operating temp, the clutch slips more than a greased banana on a hockey rink. I don't want to pay the euro price if I don't have to. Do you think there are any differences? Do you think it's worth it to just get the clutch plates or should I get the entire kit? |
February 26th, 2012, 09:41 AM | #5 |
Don't know if you have seen this thread, but here you go... http://www.ninjette.org/forums/showthread.php?t=25301
February 26th, 2012, 10:48 AM | #6 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
maybe its just the clutch springs?
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
February 26th, 2012, 12:03 PM | #7 |
Jono, I did read that post; that's why I registered with the site in fact
EMSRacer 07, why only the springs and not the plates? |
February 26th, 2012, 12:06 PM | #8 |
the ninja sometimes slips the clutches if the springs are worn. thats whats happening with my bike. the clutches are supposed to be a lifetime thing.
February 26th, 2012, 12:10 PM | #9 |
MrCycles has springs for $4 a piece...is it worth it do you think to just pull it and replace the springs? Well, for that matter I'd be able to tell if the friction plates are worn and the steel plates as well.
February 26th, 2012, 12:44 PM | #10 | |
There should be some slack at the lever that enters the clutch cover. Something elementary but many times overlooked You don't need to pay for all the parts of the clutch (and shipment weight); new plates and springs will suffice. Oil with additives can create deposits between the plates that reduce the coefficient of friction greatly. If you have been using oil labelled as "Energy Conserving" or EC, then your problem may be solved by simply changing the oil to non-EC synthetic oil. Once the plates start slipping among them, the temperature may rise enough to compromise the flatness of the metal plates and the strength of the springs. If you disassemble the clutch and can measure the springs and compare length with new ones (or with repair manual specs) you can determine if the springs have weakened and need to be replaced (has became shorter). Check this link for general info: http://www.dansmc.com/clutches.htm .
February 26th, 2012, 01:35 PM | #12 |
Motofool,
Thanks so much for the advice :thumbsup ! I'll order the springs and plates then. I wouldn't have the foggiest what oil is in there. Probably dinosaur. She'll get some Royal Purple though. Saxnbass, You're correct! Aviano until July...then we're off to Minot...possibly. There's an issue with taking our dependents (as in they're not allowed due to a shortage in housing) but we're exploring some options. It's a mess... |
Replacement Radiator | Nova46 | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 15th, 2015 12:14 PM |
motor replacement | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 8th, 2014 12:14 PM |
Please help!! Clutch cable replacement complication | Dustinfools | 2008 - 2012 Ninja 250R Tech Talk | 31 | November 29th, 2012 01:34 PM |
2003 Ninja 250 Clutch Basket Replacement!! | RobJB | 1986 - 2007 Ninja 250R Tech Talk | 3 | March 2nd, 2012 07:16 AM |
2008 model clutch cable snapped @ 17,800 miles. Replacement? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 14th, 2010 05:40 PM |
