Old May 31st, 2010, 02:19 PM   #1
EngrNewf
Geeket
EngrNewf's Avatar
10mm spool sliders not fitting
So I have several kinds of spool sliders and the 10mm seem to fit into the holes but the spools are to thick? So if I screwed it in all the way theres a gap that shows the screw and the spool is touching the bike only on one side? The screw hole and the rectangle part it's attached to isn't flush. What do I do? What am I missing? An extra piece of some sort? I tried googling around and searched the forum with no success.
bike++;
EngrNewf is offline   Reply With Quote
Old May 31st, 2010, 02:23 PM   #2
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
mine had a spacer that fills in that part....
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old May 31st, 2010, 02:24 PM   #3
Yup, might need a spacer so it sits firmly against the swingarm.
Old May 31st, 2010, 02:47 PM   #4
Rayme
Rayme's Avatar
Motorcycle(s): '04 sv650s
BOth spools I had was like that..I just used blue lock tite and torqued it against the swing arm a bit.
There's 2 types of people in this world, those who complain and those who act.
Rayme is offline   Reply With Quote
Old May 31st, 2010, 03:41 PM   #5
Méké
Méké's Avatar
Motorcycle(s): Ninja 300 2013 SE , Ninja 2009 blue/Honda Nighthawk S 1985 blue
l put 2 lock washer ( stainless ) between the spool and swingarm , perfect , my spools are home-made ,
Méké is offline   Reply With Quote
Old May 31st, 2010, 03:49 PM   #6
EngrNewf
Geeket
EngrNewf's Avatar
Where did you get the spacers?
bike++;
Old May 31st, 2010, 04:03 PM   #7
noche_caliente
came with my spools
Old May 31st, 2010, 05:28 PM   #8
EngrNewf
Geeket
EngrNewf's Avatar
came with my spools
What spools did you get?
bike++;
Old May 31st, 2010, 05:29 PM   #9
Ninja_Moose
I have a set of T-Rex spools and they came with spaces.
Ninja_Moose is offline   Reply With Quote
Old May 31st, 2010, 05:55 PM   #10
Sailariel
Sailariel's Avatar
Terri, Some washers would probably do the trick in place of the spacers you didn't get. Use some Blue Loctite on the treads and you should be OK.
Old May 31st, 2010, 05:55 PM   #11
noche_caliente
OESaccessories.com 250R Spools off of Ebay
Old May 31st, 2010, 06:54 PM   #12
I think I used pitbull spools on the 250. But washers would work just fine. Or just take the spool to the hardware store and I'd bet you could find something that would work great.
Old May 31st, 2010, 07:08 PM   #13
Mine had a *slightly* smaller diameter part on the swingarm side but it was only about as thick as a washer or two which was not enough to fill the space completely. I had to add some washers of my own. I went to Home Depot and Lowes and settled on a combination of normal and rubber-coated aluminum washers. They were the cheap black "extended swingarm slider spools" on eBay. I do like 'em.
SV Racing Parts, 10mm Swing Arm Sliders with Spools for Rear Stands SV Racing Parts Motorcycle-related 0 February 16th, 2015 11:44 PM
Spool size? spool bolt length? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 1 November 29th, 2013 08:48 PM
Spool Installation NHrider19 Videos 1 June 6th, 2012 08:27 PM
[motorcyclistonline] - Fitting (or not fitting) a helmet. Ninjette Newsbot Motorcycling News 0 March 22nd, 2012 01:20 AM
[sportrider - latest stories] - Fitting (or not fitting) a helmet. Ninjette Newsbot Motorcycling News 0 March 20th, 2012 05:20 PM
