January 18th, 2012, 08:50 AM | #1 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250 09 Posts: 31
Intake Camshaft
I need a intake camshaft for a new gen 2009.
Guessing that will be hard to find, so if anyone has any suggestions on replacing, speak up. |
January 18th, 2012, 09:04 AM | #2 |
Is this what you are looking for?
http://cheapcycleparts.com/model_yea...semblies/25731 Edit: It's part #49118 |
January 18th, 2012, 09:10 AM | #3 |
Ya, 49118-0098
theres a crack in the round end part that goes past the sprocket, @!#$ |
January 18th, 2012, 09:12 AM | #4 |
Well there you go.
Might I ask how you managed that? |
January 18th, 2012, 09:16 AM | #5 |
a mixture of being clumsy and removing it across the bike? not sure.......is it possible for it to hve cracked while running?
Cant find the piece which worries me more then buying the part. i stuck a magnet down the cam chain area, not sure if i should tear it all down since im going to have a couple weeks...turned the engine over manually, didnt hear anything unusual. would that be enough to know if i have a piece down in my cam chain area? |
January 18th, 2012, 09:22 AM | #6 |
Probably 99% of cam failures are due to flaws in manufacturing.
If you thoroughly checked the area with the magnet it should be ok. You might want to tear it down just to be sure. Because if there are any pieces in there, the next time you run the motor, you are going to end up with a massive headache. |
January 18th, 2012, 09:27 AM | #7 |
haha, that makes me feel better. the #$@ looks like it chipped....
i feel like thats one of the more expensive parts on the bike.... yes, no? have you ever taken it down that far? |
January 18th, 2012, 09:33 AM | #8 |
Yeah, that's a pretty expensive part. It's still not as bad as OEM plastics. The 2011 SE left lower faring (the one I need) is $420 =(
No, I've never been that far down in the engine. I'm in the middle of a valve adjustment at the moment. This is the furthest I've ever been into this engine. |
January 18th, 2012, 09:40 AM | #9 |
thats painful.
thats what I was doing. last adjustment i ended up taking out the stock airbox. now its cams. i cringe when i need to do valves. I always manage to extend the process. |
January 18th, 2012, 09:44 AM | #10 |
Well luckily there's an excellent video tutorial that @ninja250 did that's helping me out A LOT for this first time. I'm sure next time will be a breeze. But I'm about 4 hours into it right now. Let's hope I don't have any major issues like that.
January 18th, 2012, 09:48 AM | #11 |
i saw that video, its amazing....... i had pictures and descriptions from kkim or vex or one of them... so i was pretty set....goodluck dude.
January 18th, 2012, 09:52 AM | #12 |
Thanks bro, and good luck with your cam.
January 19th, 2012, 07:49 AM | #13 |
Join Date: Nov 2009 Motorcycle(s): 08 ninja 250 Posts: 51
i have the cam in stock. pm sent
January 19th, 2012, 08:45 AM | #14 |
kycycles, 49118-0098, correct?
January 19th, 2012, 08:55 AM | #15 |
yep
Camshaft questions 86,87 vs 88+ | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 20th, 2014 11:49 AM |
Camshaft Issue | jpatt87 | 2008 - 2012 Ninja 250R Tech Talk | 42 | March 25th, 2014 02:49 PM |
camshaft profiles | micoulisninja | 2008 - 2012 Ninja 250R Tech Talk | 30 | February 12th, 2014 04:01 AM |
Camshaft Chain Inspection | indr | 2008 - 2012 Ninja 250R Tech Talk | 18 | February 2nd, 2013 08:29 PM |
Photo of stock camshaft | tubarney | 2008 - 2012 Ninja 250R Tech Talk | 2 | January 24th, 2013 05:09 PM |
