May 11th, 2011, 04:40 AM | #1 |
time to change sprocket?
Hi,
I need a 2nd opinion on this one as I'm not used to scheduling the maintainance on my bikes.. Is this ready for replacement? Or is it good for some more time? Untitled by rousp1, on Flickr
My 250R Upgrades: Yoshi slip-on | Skidmarx double bubble | Sportisi tail tidy | Bikemonkey rear light | |
May 11th, 2011, 05:15 AM | #2 |
Ninjette Owner
Join Date: Jun 2010 Motorcycle(s): 2009 Ninja 250R SE, a puddle of Ninja ZX6 Posts: 520
No, that sprocket looks good still to me. When your sprocket starts to wear it the teeth will thin and the spaces between the teeth will widen. This link has an illustration of what sprocket wear looks like.
http://www.canyonchasers.net/shop/ge...chain-rplc.php You should also check your chain. I found this to be helpful, it is not specifically for Ninjettes, but the basic principals still apply... http://faq.f650.com/FAQs/GeneralChai... and sprockets
May 11th, 2011, 08:06 AM | #3 |
MOTM - Mar '13, Jun '14
Just needs to be cleaned.
May 11th, 2011, 10:02 AM | #4 |
Thanks guys!
A good clean in planned, but not yet scheduled.
May 11th, 2011, 10:24 AM | #5 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
when the teeth start to have a "hooked" appearance, (i.e. not uniform), then it's time to replace.
February 16th, 2013, 09:54 AM | #6 |
Sprocket Change? | csmith12 | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 9th, 2014 03:20 PM |
Sprocket size change | mrudich | 1986 - 2007 Ninja 250R Tech Talk | 1 | April 2nd, 2014 06:27 AM |
Sprocket Change | W.Roworth | General Motorcycling Discussion | 10 | November 5th, 2012 08:03 PM |
15 41 sprocket change | gogiburn | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 22nd, 2012 02:05 PM |
sprocket change | sacreyc | Help | 3 | July 12th, 2011 05:11 PM |
