Old March 17th, 2016, 03:42 PM   #1
Nu2Street
Motorcycle(s): 2006 Ninja 250R
I need a second key for my 2006 Ninja 250
So, my bike I bought third hand only has one key. It is the type cut on both sides. The key is not new with sharp teeth, but works well in the ignition and locks. The two local Kawasaki dealers sell blank keys for 8-15.00 each, but can't cut two-sided keys. Is my only option to buy a blank key and then go to a local locksmith? The local hardware stores can't guarantee cutting two-sided keys either. If I get the number off the seat or helmet lovk, can locksmiths cut a new key from that number? Thanks. Frustrated!!
Nu2Street is offline   Reply With Quote
Old March 17th, 2016, 04:27 PM   #2
Ghostt
Ghostt's Avatar
A real locksmith should be able to cut a key, if you get the code off the back of the helmet lock.
What if I lose all my keys?
Well, hopefully you read this and did some preparation. There is a key code that comes with the keys on all new vehicles. If you do not have the code tag that should have come with the keys, take the time now to unlock the helmet lock, unscrew the one phillips head screw that holds it on, look on the back of it, and write down the number you find (usually ZXXXX) in a couple of good places, one of which is the inside cover of your owner's manual. It's much easier to take the helmet lock off when you have a key than it is to destroy it should you somehow wind up with no keys.
This is a picture of the backside of the lock assembly. The locating pin on the left fits into the frame, and the Phillips head screw seen on the right actually comes in from the other side of the assembly and secures the assembly to the frame. The screw is protected from tampering or removal from the bike by the sliding rod that you hang your helmet D-ring through when securing your helmet. The key code is in the whited-out area.
http://faq.ninja250.org/wiki/What_do..._about_keys%3F
Also here's another link on key blanks
http://faq.ninja250.org/wiki/EX250F_key_blanks
Good luck.
violente et ignorantia
ZX-2R BLOG
Old March 17th, 2016, 04:30 PM   #3
HoneyBadgerRy
HoneyBadgerRy's Avatar
Now if only I had a local locksmith.
Old March 17th, 2016, 04:30 PM   #4
I don't think a general locksmith would be able to cut a key from the kawi keycode, but a kawi dealer certainly can. Good wiki entry for the older keys here:
Hillbilly Cycles in West Virginia (http://www.hillbillycycle.com/) used to be good for ordering keys if you had the keycode, but it's been a few years since I've needed one.
Old March 17th, 2016, 05:11 PM   #5
verboten1
verboten1's Avatar
MOTM - June '15
The code is a key code, not a kawasaki code, it corresponds to the depth of the cut.
I had our replacement keys cut at ace.
Ride more, worry less.
Old March 17th, 2016, 05:13 PM   #6
verboten1
verboten1's Avatar
MOTM - June '15
BJ's lock shop
Old March 17th, 2016, 05:29 PM   #7
Interesting! I hadn't thought they were state secrets, but I did think that they were unique by manufacturer.
Old March 17th, 2016, 05:42 PM   #8
verboten1
verboten1's Avatar
MOTM - June '15
I am kind of wrong, it's a possibility that they need the "decoder" a book or cross reference of sorts, but locksmiths should have that. I had keys cut for my Virago at the locksmith, he called me back in an hour with a key.
Old March 17th, 2016, 06:43 PM   #9
HoneyBadgerRy
BJ's lock shop
Thanks, I looked for one online before and came up short handed... I guess I need to get better at my googling skills.
Old March 17th, 2016, 07:00 PM   #10
Nu2Street
verbotten1, so your local ace could cut a new double sided key just from the code? I don't think my local ace hardware has a computerized key machine.
And WHY did my local Kawasaki shop tell me if I wanted to order a new pre- cut key from the key code direct from kawasaki it would be about $80.00?????? That's insane!!!
Old March 17th, 2016, 07:19 PM   #11
verboten1
verboten1's Avatar
MOTM - June '15
No, ace cut me a key from an existing key.
Old March 18th, 2016, 07:07 AM   #12
I took my Kawi key to a local locksmith, he found the blank that worked best, cut it for me, and only charged me like $4 or something. It's been working flawlessly ever since. He even made me go test it in his driveway a bunch of times to make sure I was happy with how it worked in all my locks
Old March 18th, 2016, 02:02 PM   #13
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
yea, getting a replacement key from Kawi is a beech.
I just ordered key blanks for a pregen from here: http://keys4urride.com/
Guys at ACE could cut it if I had another key, but alas, I do not, so I'm trying to make my own with some lock picking instructions I've always wanted to try. Picking the gas cap BTW showed me that although the keys are double sided for ease of use (doesn't matter which way you put it in), they don't use double sided tumblers, so to pick the lock is pretty easy. Always learning something new.
Old March 19th, 2016, 09:10 AM   #14
Nu2Street
I'll have to call some semi-local locksmiths and see if they can either duplicate my key or cut a new one from the helmet lock key code.
Old March 19th, 2016, 10:35 AM   #15
gitoy
Motorcycle(s): 04 ninja 250, 05 zzr 600 (sold), 07 cbr600rr
i have an 04 and i just took my key to a local locksmith for a duplicate with no problems...it looks like a double sided key...and cost me $4...
nu2street has a key and wants another key made...what is so special with his double sided key?...
gitoy is offline   Reply With Quote
Old March 19th, 2016, 11:16 AM   #16
allanoue
allanoue's Avatar
MOTM - Sep '14
Ace cut a blank for me off the old bent original. They had me test it before paying. Worked better then the original.
Old March 19th, 2016, 05:29 PM   #17
verboten1
verboten1's Avatar
MOTM - June '15
Nothing, really. So many bike and car keys are or were double sided, I've had many many copies made.
Old March 19th, 2016, 08:36 PM   #18
Nu2Street
My Ace does not have my key blank in stock. Not sure if they can get the Ilco equivalent oe not. I just don't want to pay $8.00+ for a key blank at Kawasaki, and then gave Ace mess up the cutting. Not that they would.
Old March 20th, 2016, 07:29 PM   #19
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Lots of info in this thread: http://forums.ninja250.org/viewtopic...85a9e56b44f403
and here: http://forums.ninja250.org/viewtopic...=829253#829253
Here, too: http://forums.ninja250.org/viewtopic...ghlight=wafers
(There's some overlap in those threads!)
The keys are cut both sides, but only one side is used. It's only cut both sides so that the user doesn't have to think about which way the key needs to enter the lock. Companies that don't do this are IMHO lazy (I'm looking at you, GM!).
Old March 20th, 2016, 07:41 PM   #20
HoneyBadgerRy
Almost every locksmith or hardware store should be able to copy your key, and you can buy keyblanks on amazon. The problem it the copies will be of the used key. If you want a new key you need one cut from the key code.
Old March 20th, 2016, 09:33 PM   #21
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
If a used key works well, a copy of that key should work well, too.
Old March 21st, 2016, 05:20 AM   #22
Werd. My old civic had a used key with a lot of mileage. Got a copy made off the spare (which spent its life in the kitchen drawer, not being used) and the copy was really rough.
Old March 21st, 2016, 06:40 AM   #23
Nu2Street
Well, I took off the helmet lock to get a key code. I don't use the helmet lock anyway, and it turned out the screw was also loose. There are two sets of numbers on the helmet lock, each a string of five characters. One starts with an "S" and ensure in "HH", so I don't think that's the code. The other starts with "Z". I'm not sure which one it is.
Old March 21st, 2016, 06:56 AM   #24
FrugalNinja250
The answer to your question is in the links I posted. To recap, the Z5XXX is the key code. The key cut code is a six digit number used by the locksmith to set up the key cutting machine to cut the depths of the notches. Kawasaki sold key code books that locksmiths used to look up the cutting code based on the Z code. The codes changed each year and were model-specific. Not all locksmiths bought the code books so you will need to call around to find one that did.
I also provided enough info in the links I posted for you to cut your own key if you are handy with a Dremel and have a dial or digital caliper. It's not that difficult and the key would likely be more accurate than a duplicate of your old worn key.
Old March 21st, 2016, 07:32 AM   #25
Nu2Street
I looked through the info you posted again and saw the key code sample, but my code is only Z followed by four numbers.
Old March 21st, 2016, 07:33 AM   #26
Nu2Street
Got it now. Thanks!!
Old March 21st, 2016, 09:38 PM   #27
FrugalNinja250
Just so anyone else reading knows, there are only theoretically 1,000 different key codes, Z5000 through Z5999. In reality there are less than 1,000 different keys because some combinations of key land depths aren't used, such as all notches being the same depth.
Old March 22nd, 2016, 03:15 PM   #28
InvisiBill
InvisiBill's Avatar
I'm in ur locksmith, stealin ur Ninjettez...
Old March 23rd, 2016, 07:05 PM   #29
Nu2Street
Well, I checked with local locksmiths, and neither of them had the right key! They both have the fancy key code cutter machine and said if I could get the keys and had my key code, no problem cutting new keys. I searched the internet and found a pack of 10 KA14 keys on Amazon. With shipping the keys are only a little over $10.00. Once the keys arrive and I get a couple cut I'll reply how I made out. I may start off taking one to Ace and see how they do copying my current key.
Old March 24th, 2016, 09:08 PM   #30
FrugalNinja250
Since there're only four depth positions for each of the six notches, I can look at a picture of your key and tell you what the cut code would be. So could any competent locksmith for that matter.
Old March 25th, 2016, 04:52 AM   #31
HoneyBadgerRy
So your saying that if I took in a used key to any competent locksmith they could look at it and cut a brand new version of the key? (Not a used copy)
Old March 25th, 2016, 05:15 AM   #32
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
Reminds me of that time the TSA posted photos of their master key set for TSA approved luggage locks.
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old March 25th, 2016, 06:00 AM   #33
allanoue
allanoue's Avatar
MOTM - Sep '14
It explains why the key I had made works smoother than the original.
Old March 25th, 2016, 10:21 AM   #34
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
Something to keep in mind is that when the original key has worn down a little from a "new" key, the cylinder itself has likely worn. Brand new keys cut from a code or keys that aren't replicated to the original's specifications may not work as well as the original itself.
"That's what" -she
Roark is offline   Reply With Quote
Old March 29th, 2016, 03:39 PM   #35
Travis789
Travis789's Avatar
Motorcycle(s): Honda Elite 50S, Suzuki DR350S, Honda XR100R, Kawasaki Ninja 250R
Smile
Good luck.
thank you so much for this! You just saved me 130$ because I didn't have to have the lock reverse engineered. I bought a ninja 250r with no keys but I was able to pick the helmet lock, retrieve the code, and order 2 keys cut to code for $30 online.
Travis789 is offline   Reply With Quote
Old March 29th, 2016, 05:24 PM   #36
Ghostt
Ghostt's Avatar
if you want to send me the money you saved my PayPal account is .......
Glad I could help.
ZX-2R BLOG
Old March 29th, 2016, 07:49 PM   #37
HoneyBadgerRy
Online, did you say online locksmith? Link?
Old March 30th, 2016, 01:55 AM   #38
Travis789
Travis789's Avatar
Yes, they were mentioned earlier in this thread, too. http://keys4urride.com/. It took a while to figure out the key type I needed but then you give them the code and they'll cut the key to the code for 6$+-, all together 30$ for 2 with shipping.
They have a whole section on kawasaki key blanks and if you can't find your year/model just email them.
Last futzed with by Travis789; April 4th, 2016 at 02:54 PM.
Old April 6th, 2016, 08:12 PM   #39
Nu2Street
To keep everyone up to speed, I ordered 10 keys on Amazon- KA14 key blanks. The locksmith where I work said the local Tru Value Hardware had a key cutter with a good set of jaws that would probably hold the KA14 key. I went in, the guy looked at my original key and said he could probably cut new keys.. I had him cut two. He didn't even charge me because I supplied the blanks! Brought them home to try in the bike and they work perfect. Even tried turning the keys and inserting them both directions. Perfect keys.
Last futzed with by Nu2Street; April 7th, 2016 at 04:15 AM.
Old April 6th, 2016, 08:25 PM   #40
Ghostt
Ghostt's Avatar
Any updates? How did the keys work? Which blank did you get?
ZX-2R BLOG
How to find key code ninja 250 dibbles 2008 - 2012 Ninja 250R Tech Talk 2 April 24th, 2015 07:45 AM
1993 ninja 250 key tdog7812 1986 - 2007 Ninja 250R Tech Talk 5 December 21st, 2012 11:48 PM
