November 24th, 2009, 11:50 AM | #1 |
[sportrider - latest stories] - Suggested Suspension Settings
Sport Rider's setup recommendations for every bike tested from 1997 table.performance_chart { font: normal 10px Verdana,Arial; text-align: center; } table.performance_chart tr.heading { font: normal 10px Verdana,Arial; background: #000000; color: #ffffff; vertical-align: top; } tr.heading td { font: normal 10px Verdana,Arial; background: #000000; color: #ffffff; vertical-align: top; } table.performance_chart tr.odd { font: normal 10px Verdana,Arial; background: #ffffff; color: #000000; vertical-align: top; } tr.odd td { font: normal 10px Verdana,Arial; background: #ffffff; color: #000000; vertical-align: top; } table.performance_chart tr.even { font: normal 10px Verdana,Arial; background: #cccccc; color: #000000; vertical-align: top; } tr.even td { font: normal 10px Verdana,Arial; background: #cccccc; color: #000000; vertical-align: top; } table.performance_chart td.dyno { font: normal 10px Verdana,Arial; color: #ff0000; vertical-align: top; } Recommended Suspension Settings These tables show suggested suspension settings for each bike. You can also use the tables to find which issues of Sport Rider each bike was tested. For more information on suspension, check out the Suspension Tuning Guide. Aprilia | BMW | Buell| Ducati | Honda | Kawasaki | KTM Laverda | Moto-Guzzi | MV Agusta | Suzuki | Triumph | Yamaha Yamaha motorcycle issue front preload front rebound damping front comp. damping rear preload rear rebound damping rear comp. damping note: FJR1300 ('05) 6/05 2 lines showing 4 clicks out from full stiff 7 clicks out from full stiff hard position 3 clicks out from full stiff note: YZF600R ('97) 4/97 2 lines showing 3 clicks out 2 turns out stiff 3 clicks out 1.5 turns out note: YZF600R ('98) 8/98 stiff stiff 2 clicks out 1.25 in. sag 3 clicks out 3 clicks out note: YZF-R6 ('99) 6/99 1 line showing 3 clicks out 3 clicks out position 6 8 clicks out 7 clicks out note: raise fork tubes 9mm in clamps with D207GP tires YZF-R6 ('99) 12/99 6 lines showing 3 clicks out 3 clicks out position 4 from soft 8 clicks out 7 clicks out note: raise fork tubes 5mm from stock with Pirelli Dragon EVO tires YZF-R6 ('00) 10/00 7 lines showing 2 clicks out 6 clicks out position 4 from soft 10 clicks out 7 clicks out note: with Michelin Pilot Race tires YZF-R6 ('00) 12/00 3 lines showing 2 clicks out 6 clicks out position 4 from soft 8 clicks out 8 clicks out note: set fork tube height to 12mm from clip-on with Metzeler Rennsport tires fitted YZF-R6 ('01) 6/02 3 lines showing 4 clicks out 8 clicks out position 6 from soft 7 clicks out 7 clicks out note: set fork tube height to 10mm above flat portion of clip-on, with Dunlop D208GP tires fitted YZF-R6 ('01) 12/02 3 lines showing 4 clicks out 8 clicks out position 6 from soft 6 clicks out 8 clicks out note: set fork tube height 10mm raised from stock, with Metzeler Rennsport tires fitted YZF-R6 ('03) 6/03 6 lines showing 2 clicks out 6 clicks out position 4 from soft 11 clicks out 9 clicks out note: set fork tube height to 10mm above flat portion of clip-on, with Pirelli Supercorsa tires, 0mm with stock Dunlop D208ZR tires YZFR6 ('03) 12/03 6 lines showing 2 clicks out 6 clicks out position 5 from soft 10 clicks out 10 clicks out note: set fork tube height to 13mm showing above outer portion of clip-on with Michelin Pilot Race M2 tires, 0mm with stock Dunlop D208ZR tires YZF-R6 ('04) 8/04 7 lines showing 1 click out 11 clicks out position 5 of 9 2 clicks out 10 clicks out note: set fork tube height to 10mm showing above flat portion of bar clamp with Dunlop D208 GP-A tires YZF-R6 ('05) 4/05 6 lines showing 4 clicks out from full stiff 8 clicks out from full stiff position 5 from full soft 4 clicks out from full stiff 10 clicks out from full stiff note: set fork tube height flush with top of clip-ons YZF-R6 ('06) 7/06 2 lines showing 7 clicks out from full stiff Slow-speed: 4 clicks out from full stiff; High-speed: 2.75 turns out from full stiff position 3 of 8 2 clicks out from full stiff Slow-speed: 14 clicks out from full stiff; High-speed: 9 clicks out from full stiff note: YZF-R6S ('06) 10/06 4 lines showing 4 clicks out from full stiff 4 clicks out from full stiff position 3 from full soft 1 click out from full stiff 4 clicks out from full stiff note: Ride height: fork tubes flush with flat part of clip-ons YZF1000R ('97) 10/97 2 lines showing 3 clicks out 8 clicks out position 7 of 9 7 clicks out 10 clicks out note: YZF1000R ('97) 12/97 2 lines showing 3 clicks out 8 clicks out position 7 of 9 7 clicks out 10 clicks out note: YZF-R1 ('98) 12/98 2 lines showing 2 clicks out 4 clicks out position 5 2 clicks out 7 clicks out note: YZF-R1 ('99) 12/99 2 lines showing 2 clicks out 4 clicks out position 6 3 clicks out 7 clicks out note: YZF-R1 ('00) 8/00 3 lines showing 6 clicks out 4 clicks out position 6 of 9 9 clicks out 11 clicks out note: with Metzeler Rennsport race tires YZF-R1 ('00) 12/00 3 lines showing 6 clicks out 4 clicks out position 6 of 9 9 clicks out 11 clicks out note: with Metzeler Rennsport tires fitted YZF-R1 ('01) 12/02 3 lines showing 6 clicks out 4 clicks out position 6 of 9 8 clicks out 10 clicks out note: set fork tube height 6mm raised from stock, with Metzeler Rennsport tires fitted YZF-R1 ('02) 8/02 3 lines showing 12 clicks out 12 clicks out position 3 from full soft 14 clicks out 14 clicks out note: set fork tube height to 4mm above top triple clamp, 9mm with Michelin Pilot Race 2 tires fitted YZF-R1 ('04) 6/04 3 lines showing 7 clicks out 9 clicks out position 8 of 9 21 clicks out 7 clicks out note: set fork tube height to 5mm showing above triple clamp YZF-R1 ('05) 5/05 4 lines showing 11 clicks out from full stiff 12 clicks out from full stiff 7 from full soft 26 clicks out from full stiff 9 clicks out from full stiff note: set fork tubes flush with triple clamp YZF-R1 ('06) 6/06 4 lines showing 11 clicks out from full stiff 12 clicks out from full stiff position 7 from full soft full soft 9 clicks out from full stiff note: set fork tube height to 4mm above triple clamp YZF-R1 LE ('06) 10/06 5 turns out from full stiff 11 clicks out from full stiff 12 clicks out from full stiff 13mm thread showing to top of preload collar, 14.5 turns out from full stiff on hydraulic preload adjuster 14 clicks out from full stiff Low speed: 10 clicks out from full stiff; High speed: 2.5 clicks out from full stiff note: YZF-R1 ('07) 3/07 5 lines showing 8 clicks out from full stiff 7 clicks out from full stiff Position 7 of 9 7 clicks out from full stiff High speed: 2 turns out from full stiff; Low speed: 8 turns out from full stiff note: Set ride height to 4mm from top of fork tube to top of triple clamp Read More | Digg It | Add to del.icio.us Click here for full story...
[sportrider - latest stories] - Suggested Sport Bike Motorcycle Suspension Settings | Ninjette Newsbot | Motorcycling News | 0 | December 31st, 2013 03:22 AM |
[sportrider - latest stories] - Suggested Suspension Settings Updated | Ninjette Newsbot | Motorcycling News | 0 | December 1st, 2010 01:50 PM |
[sportrider - latest stories] - UPDATED – MV Agusta Suggested Suspension Settings | Ninjette Newsbot | Motorcycling News | 0 | August 12th, 2009 05:50 PM |
[sportrider - latest stories] - UPDATED – KTM SUGGESTED SUSPENSION SETTINGS | Ninjette Newsbot | Motorcycling News | 0 | August 5th, 2009 05:50 PM |
[sportrider - tech] - Suggested Suspension Settings | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2009 01:23 PM |
