July 21st, 2015, 12:31 AM | #1 |
MOTM - July '15
Front master cylinder questions
I broke my front brake's master cylinder in a crash. I bought a replacement in eBay from a 1990's parts bike. My bike is a 2003. It says to only use dot4 fluid on the 2003 master cylinder. But the 1990 master cylinder says to use dot3. At these parts incompatible? Can post pics if it'll help.
July 21st, 2015, 02:11 AM | #2 |
The difference between the DOT (Department of Transportaion) ratings of brake fluid are the boiling point ranges that they achieve both dry (no water absorbed) and wet (about 3-4% water content). For DOT 3 the dry boiling point is at least 401 and the wet 284 degrees. DOT 4 raises the bar to 446 and 311 respectively. Those are the DOT ratings mind you , and there are high performance brake fluids that exceed those ratings.
https://en.m.wikipedia.org/wiki/Brake_fluid I personally use Motul DOT 5.1 Brake Fluid , which has a higher boiling point, and it's compatible with DOT 3 & 4 100% synthetic Mixes with DOT 3, 4, and 5.1 (not Dot 5) Boiling points: Dry 509 degrees F, Wet 365 degrees F Motul DOT 5.1 Brake Fluid - 1/2 L. 8070HC / 100951 https://www.amazon.com/dp/B005UGKDRY..._YNGRvb6J721CM DOT 5 which is a silicone based product is not compatible with any of the above. You'll be fine running DOT4
July 21st, 2015, 08:08 AM | #3 | |
Both fluids are mixable and compatible.
July 21st, 2015, 02:19 PM | #4 |
MOTM - July '15
Thanks for the good info! Always appreciated!
July 21st, 2015, 03:02 PM | #5 |
Google. It's a great tool for commonly asked simple questions. If you're wondering it, there's a really really high chance someone else has already discussed it on the internet.
just sayin. |
July 22nd, 2015, 03:00 AM | #6 |
MOTM - July '15
I did Google it. This is a highly specific question. Google didn't help. I came here. What makes you think I didn't?
July 22nd, 2015, 03:19 PM | #7 |
Really? "DOT3 vs DOT4" is not a highly specific Google query.
EDIT: this is literally the first result for the above query: https://en.wikipedia.org/wiki/DOT_4 No offense here, but dude... |
July 22nd, 2015, 03:22 PM | #8 |
Maybe his NET NANNY was on
Front brake master cylinder | ninjagaiden09 | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 22nd, 2014 08:51 AM |
Front Master Cylinder Size | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 14th, 2013 02:38 PM |
aftermarket front master cylinder?? | tac12345 | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 25th, 2012 01:03 PM |
front master cylinder wanted | 03slime250 | Items Wanted | 4 | July 14th, 2011 09:56 AM |
[sportrider - tech] - Ask the Geek: Michelin Tire and Master Cylinder Questions | Ninjette Newsbot | Motorcycling News | 0 | July 7th, 2010 05:50 PM |
