January 13th, 2010, 10:25 AM | #1 |
Area P
Join Date: Dec 2008 Motorcycle(s): Too many to list Posts: 439
Area P Billet End Cap
We've been receiving a lot of requests to bring back our original two piece flat conical billet end cap option. So we've incorporated the "two piece" style, into a cnc'd one piece design that is four ounces lighter than the original. They are available now as an option (no extra cost) to our traditional turn down tip on all 250R full systems.
Pictures are shown with our large 2.50" core (for larger displacement sportbikes). The 250 core is smaller and has an internal adaptor that transitions it from the core to the large outlet. |
January 13th, 2010, 10:33 AM | #2 |
Aloha, Kerry. That's pretty nice!
Will these fit on the quiet core mufflers? How much are they sepeartely? |
January 13th, 2010, 12:16 PM | #3 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
Looks so much better. I would have been requesting that style tip as well had I not hooked up with sportisi.
Sportisimoto USA is born. |
January 13th, 2010, 12:24 PM | #4 |
Hey Kerry, if I already have the muffler, can it be converted to this? I am assuming that will be heavier than the traditional tip and also, obviously, the DEI will not work? Are there any differences on sound and performance with this style? Thanks.
January 13th, 2010, 12:24 PM | #5 |
Area P
Howzit Kelly! - Yep, the new end cap fits all style cores/mufflers. Requires it to be sent in to us for the mods/installation. Retro-fit to an existing muffler is $85.00, but includes a repack service. We disassemble the muffler, modify the core assembly, fresh repack, replace hardware, rebond and assemble.
January 13th, 2010, 12:32 PM | #6 |
Aloha, Kerry!
Does this mean once the muffler is modified, you can't go back to the other (turndown) tip? |
January 13th, 2010, 12:37 PM | #7 |
Area P
Yep. The new end cap is actually only 5 grams heavier than the standard turn down tip cap (if we left out the screws, it would actually be 5 grams less ). We've cavity machined out a lot of material to get it as light as possible. No, the DEI will not work with the new end cap. Performance is the same. The sound level is the same dbA reading, but it can be perceived to your ear as slightly increased. This is because the standard tip is "turned down" on the exit and deflects the sound more away from you.
January 13th, 2010, 12:45 PM | #8 | |
January 13th, 2010, 12:54 PM | #9 |
Area P
January 13th, 2010, 12:58 PM | #10 |
January 13th, 2010, 01:41 PM | #11 | |
Area P
On the ones we've disassembled and only added a minor amount of material, we have a minimum charge of $25.00. Full replacement repack service depends on the muffler length and core diameter, but normally run a maximum of $50.00. We highly recommend customers send their mufflers in to us for any kind of service. We press fit and bond the end caps in place to fairly tight tolerances. We design them to stay together! |
stock end cap rusting?!! | gantt | 2013 - 2017 Ninja 300 Tech Talk | 5 | September 4th, 2013 05:19 PM |
[sportrider - latest stories] - New Hindle Evolution and Carbon Fiber End Cap muffler | Ninjette Newsbot | Motorcycling News | 0 | March 16th, 2011 08:00 PM |
Muffler end cap | BKK1200rs | Items Wanted | 5 | August 31st, 2010 06:10 PM |
