July 25th, 2009, 02:24 AM | #1 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250R 08 Posts: 59
XL Shark Helmet 10/10 Not a single scratch
I have a XL shark helmet i bought and used twice (during my rti course) It is immaculate and has not even a single scratch.
During said course i found out the fit was too lose (first helmet purchase) So i went out and purchased a size LARGE. Trying to recoupe some cost. 250 shipped, o.b.o I will get more pictures of the helmet later. Here is some info about the helmet. RSX excels in any circumstances. Its aerodynamic qualities mean it is equally at home for sports or GT use. The clean design and advanced technology will bring your senses to life and make this helmet your essential companion BRA- Black/Red/Anthracite Shell made form Carbon-fiber/Kevlar multi-directional fibers. Two Shell sizes. Multi-element interior shock-absorber (6) with air differential density Airflow directed by integrated ducts. Dual treaded (anti-scratch/anti-fog) “Total Vision” 3 mm visor. “Push One” visor quick release system using 4 anchorage points. "Touch One" fluch rapid-opening ventilation. Optimized demisting thanks to “Venturi” side extractors. Fully adjustable, removable & washable interior using 100% Coolmax® & Sanitized fabrics. Ergonomic 3D foam cheek pads. Breath guard and chin cover. Double-D ring “Racing” chin strap. Anti-fog mask & chin for visor. Weight: 1350g DOT and ECE 22-05 Approved Last futzed with by Rafalski; July 30th, 2009 at 01:30 AM. |
July 30th, 2009, 01:27 AM | #2 |
Bump.
Common no one has a XL head who needs a helmet. IT does not get any better then this baby. |
July 30th, 2009, 01:28 AM | #3 |
I think a picture might help.
July 30th, 2009, 01:30 AM | #4 |
July 30th, 2009, 08:47 AM | #5 |
Pedal Power
Join Date: Jun 2009 Motorcycle(s): 2008 Ninja EX250R Posts: 401
What is the sizing like? (I'm large in some Medium in others...might be XL in Shark)
Using Pedal Power |
July 30th, 2009, 09:12 AM | #6 |
Join Date: Jun 2009 Motorcycle(s): 2007 Suzuki GSX-R750 Posts: 378
too bad its XL and red
July 30th, 2009, 01:31 PM | #7 | |
But so you know its a 61-62cm fit around the head, you should measure about 1inch from the eyebrow. this has more info http://sportbiketrackgear2.homestead...ize_chart.html IF it was L I would have been using it. Had to buy a Large rsr2 when i found out that the fit was bad. Last futzed with by Rafalski; July 30th, 2009 at 01:32 PM. Reason: Addition |
August 11th, 2009, 12:07 AM | #8 |
Bump plus pictures
Front view Side View My new top and old helmet size. Showing that I didnt **** it up and am making up bs. I actually couldnt wear the XL. |
August 15th, 2009, 02:23 PM | #9 |
Join Date: Aug 2009 Motorcycle(s): 07 Kawi 250R Posts: 31
I know you are trying to recoupe funds but is that the lowest you will go?
August 16th, 2009, 03:11 PM | #10 |
August 22nd, 2009, 10:38 PM | #11 |
December 16th, 2009, 09:42 PM | #12 |
June 5th, 2010, 11:31 PM | #13 |
June 8th, 2010, 01:53 PM | #14 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
Hmmm can't you put a Shark Large inner liner into it thereby making it more useful to you. If the shell size of the XL is the same as a Large... its doable to pull the XL liners and shove the L in (including cheek liner)
June 8th, 2010, 03:11 PM | #15 |
Yeah except the top part of the head doesnt fix the issue. I tried that course of action when it first happened. put in smaller linear and small cheek pads but the crown of the head moved.
Arai helmet VS new shark s900 C | jack_bm | Motorcycle Gear | 8 | February 10th, 2012 09:34 AM |
Dazzling Daft Punk Helmet Made From Scratch | FerociousNINJA | Off-Topic | 3 | July 23rd, 2010 10:08 PM |
[motorcyclistonline] - Shark RSR2 Helmet | Ninjette Newsbot | Motorcycling News | 0 | July 9th, 2010 07:30 PM |
Shark s650 Helmet Medium - $90 | 00v_Lucky | Gear-related | 0 | May 25th, 2010 11:42 AM |
Shark Helmet | tinng321 | Motorcycle Gear | 15 | May 20th, 2009 09:35 PM |
