September 1st, 2012, 03:00 PM | #1 |
Join Date: Jul 2012 Motorcycle(s): 2007 R6, 2015 KTM 250XC - Past: 2011 KTM 150XC, 2009 Ninja 250r, 2012 Ninja 650, 2007 CRF250R Posts: 194
Fairings.. Oem and aftermarket
Ok so I've been looking at all sorts of used bikes around town and a couple of them have some cracked fairings which is fine given how much the price gets knocked off. I was wondering how much Oem fairings cost or what aftermarket fairings are costing. If you guys have bought some before I'd be thankful for recommendations. Worried about buying plastics that dont fit as well. Also does Kawasaki sell the special edition decals?
Try it, you might like it. |
September 1st, 2012, 04:10 PM | #2 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
well i got an OEM right fairing for 300$ and it didnt fit right. the bottom kept sticking out like the plastic was molded straight. it was a pain to line up the bottom section with my old fairing because i guess it needs to break in and get the curvature. been about a month and a half and it still doesnt line up exactly
http://tyga-performance.com/site/ind...ee2f059208f087 this was mentioned in another thread. Looks OEM but definitely a lot cheaper. Ill probably buy one of these when i replace my other fairing |
September 4th, 2012, 04:12 AM | #3 | |
http://tyga-performance.com/site/ind...2_1045_791_792 |
September 4th, 2012, 01:26 PM | #4 | |
Lets go ride!
Can you get other colors for the fairings? Thanks, Jeff |
September 4th, 2012, 01:48 PM | #5 | |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
Life's better on the Mountain. |
September 6th, 2012, 08:42 PM | #7 |
Not exactly sure what you mean about foam. I don't think so but then again, I don't think our Thai spec bike didn't have any foam on the side fairings from the factory. Maybe you mean another panel or something?
September 6th, 2012, 08:52 PM | #8 |
Ambrosia.
I think he means the heat shield on the inside of the side fairings.
September 6th, 2012, 08:54 PM | #9 |
Lays er down
i thought the heat shield was the silver piece. im talking about a big black piece of soft material, maybe like a damper to reduce vibrations?
September 6th, 2012, 09:00 PM | #10 |
thanks for the clarification. I don't think the Thai versions have that sound deadening foam. Can't you reuse the existing one or will it get all ripped up? Or not bother at all, at least see to start with.
On the heat shield, I got a few in for personal use on other bikes etc. as it is good stuff. That said it wasn't crazy cheap like the panels. I think around 20 bucks or something |
September 6th, 2012, 09:01 PM | #11 |
Lays er down
ok thank you
September 20th, 2012, 04:36 PM | #12 | |
My lowers didn't line up for a long time until I redid my fasteners while holding them in place. Couldn't figure it out for the longest time!
October 12th, 2012, 01:01 AM | #13 |
Sometimes if a bike goes down, the brackets get bent out of shape but not always obvious, so worth taking a look at them and making sure everything is straight before trying to fit new panels.
October 12th, 2012, 03:19 AM | #14 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
OEM and aftermarket pregen parts | ieathonda | Motorcycle-related | 0 | March 29th, 2015 11:08 AM |
New Fairings (the aftermarket ones from eBay) | T-? | 2008 - 2012 Ninja 250R Farkles | 36 | August 14th, 2013 05:20 PM |
08-12 Ninja 250r OEM/Aftermarket Accessories | Broc | Motorcycle-related | 23 | February 15th, 2012 09:16 AM |
Aftermarket fairings | TFKninja | 2008 - 2012 Ninja 250R Tech Talk | 19 | August 25th, 2011 08:13 AM |
