July 28th, 2012, 06:55 PM | #1 |
New Yoshi slip on - leak? Help!
Hey fellas,
Just installed my yoshi slip on, and the tail touches the stock header or w/e it's called and it is clamped all the way. There is still a minimal amount of air coming from the space in the picture below/attached. I have tightened everything, and it is as far down as it can go. The clamp is pretty tight too. Is this normal? |
July 30th, 2012, 07:39 PM | #2 |
Is there a gasket there? Is there still a leak after everything warms up?
July 31st, 2012, 07:28 AM | #3 |
No there is no gasket there.
Everything is clamped on as tight as can be, and yes it still leaks (slightly, but I can feel it on my hand when throttled) when heated up. Is this a major issue? |
July 31st, 2012, 08:10 AM | #4 |
Join Date: May 2012 Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission) Posts: 482
Same thing with my danmoto exhaust. Probably just condensation.only happens to me during cold start up
July 31st, 2012, 08:34 AM | #5 |
Try some high temp rtv to make your own gasket and seal your leak
Posted via Mobile Device |
yoshi slip on | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 19th, 2011 07:44 AM |
Should I shim for a Yoshi slip on? | wtfh4xx | 2008 - 2012 Ninja 250R Tech Talk | 27 | June 6th, 2011 06:15 PM |
Fitting Yoshi Slip On | clay | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 13th, 2009 09:34 PM |
WTB: Yoshi CF Slip-On | valerik | Items Wanted | 2 | September 27th, 2009 09:58 AM |
Headers for YOSHI Slip on. | shporsche | Items Wanted | 5 | June 1st, 2009 07:37 PM |
