March 28th, 2011, 07:18 PM | #1 |
Join Date: Apr 2010 Motorcycle(s): 2010 Lime Green 250R Posts: 82
Need help removing front cowl bracket
Hi folks, I am working on my friend's ninjette and want to remove the bracket which hold the front cowl (the one with A, B, F Ballon in the attached PDF). It has two rectangular ring for the cables, wires passage. I have removed all the cables, wires but dont know how to remove the wires from the ignition. Is anyone here have experience on removing those wires? I appreciate it.
Jason |
March 28th, 2011, 08:43 PM | #2 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
never dug down that deep. ive removed all of the plastics up front and the spedometer, and was only left with the bracket that you are trying to remove, but never had to remove that part, so it wasn't something i thought about.
i just looked at my bike, and i think you might need to take of the fuel tank, to reach the connector for the ignition cable, its probably somewhere under there; this might help
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
March 28th, 2011, 08:51 PM | #3 |
Join Date: Oct 2009 Motorcycle(s): 2008 Triumph Bonneville Black Posts: 627
I was looking at that the other day. If I had to remove mine, I'd figure out which 3/4" section of the square was unnecessary and break out the bolt cutters.
'08 Bonneville Black sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator |
March 29th, 2011, 05:25 AM | #4 |
Oh, looks like the tank is the way to go... Damn, a lot of extra work.......... But thanks a lot man
March 29th, 2011, 09:04 AM | #5 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
Yup, you're gonna have to pull the tank to get to the big connector. Once you have the tank removed, it will be self-explanatory.... Also, if you have the front fairings off, it implies you have the side fairings off... To remove the tank it's 2 bolts, 2 lines, and 1 wire... Pretty quick if you ask me...
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
March 29th, 2011, 12:20 PM | #6 |
Removing front wheel. | Løckøut | 1986 - 2007 Ninja 250R Tech Talk | 8 | July 30th, 2013 08:05 PM |
Removing the front fender | Old Lemon | 2008 - 2012 Ninja 250R Tech Talk | 5 | December 8th, 2012 08:06 PM |
Need help removing front sprocket (countershaft) | cb160racer | 2008 - 2012 Ninja 250R Tech Talk | 37 | November 11th, 2012 10:53 PM |
Removing Mirror Bracket (with removing all the fairings) | killermase | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 21st, 2012 11:16 PM |
