Old April 1st, 2012, 06:50 PM   #1
Jay T
Motorcycle(s): EX250J
Installing rearset, need some help
After a spill on the canyons, my stock shifter/rearsets were pretty much toast. I ordered some new ones on ebay, they appear to be Sato knockoffs. Anyway, I ran into a problem during the install. Have a look.
http://imgur.com/2Q5TR
The shift arm won't attach to the shift rod. I'm told the shift arm on the ninja sometimes has reversed threads. Anyone got some solutions?
If apparently the 250 occasionally comes with reversed threaded arms, where can I get a regular threaded one?
I could order another arm off bikebandit or something similar, but how can I be sure it won't be reversed like the one I already have? Thanks any and all help.
Jay T is offline   Reply With Quote
Old April 1st, 2012, 07:02 PM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
The shift shaft side SHOULD be left-hand threaded. The heim joint on the rearset pedal should be right-hand threaded. This way you can thread both ends in evenly by just rotating the shift linkage. The linkage is the correct length, it's just not threading in?
k-os is offline   Reply With Quote
Old April 1st, 2012, 09:09 PM   #3
Jay T
Thanks k-os
Turns out, I had the shift rod backwards *facepalm*
Either way, these rearsets feel kinda flimsy and I'm not all that confident in riding with them. Starting to look like a waste of 200 bucks :\
Old August 25th, 2013, 06:37 PM   #4
kurare711
Motorcycle(s): 250r
Mind answering a few questions?
Got the same thing just recently, Sato knock offs off ebay.
I cannot for the life of me understand how to install the shift rod.
How did you get yours onto the OEM balljoint part with the shift rod they provided exactly?
kurare711 is offline   Reply With Quote
Old November 7th, 2013, 10:28 PM   #5
bitaria
Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R
Same problem. Removed the threaded insert and tried it both ways, just does not work...
bitaria is offline   Reply With Quote
Old November 7th, 2013, 11:23 PM   #6
kurare711
Motorcycle(s): 250r
Use the OEM shaft + the one they provided at the same time...
Old November 7th, 2013, 11:27 PM   #7
bitaria
Not too long of a shift rod?
Transmission ball joint -> stock rod -> new rod -> shift pedal ?
Old November 7th, 2013, 11:28 PM   #8
kurare711
Motorcycle(s): 250r
Try it and see for yourself. It's not that long if you slide out the connection and insert it back in at a different starting angle. At least for me.
Old November 7th, 2013, 11:30 PM   #9
bitaria
Thanks, I'll give it a shot!
Installing New AP Exhaust xaple 2008 - 2012 Ninja 250R Tech Talk 9 September 29th, 2012 08:23 AM
Installing MX (motocross) bars xanderick 1986 - 2007 Ninja 250R Tech Talk 4 June 14th, 2012 01:20 PM
Installing a hitch Dano Off-Topic 7 September 6th, 2010 07:24 PM
[roadracingworld.com] - Video: Performance UpGrades--Installing Rearset Controls On T Ninjette Newsbot Motorcycling News 0 May 21st, 2010 03:50 AM
Installing New Brake Pads huhster 1986 - 2007 Ninja 250R Tech Talk 2 August 26th, 2009 03:48 PM
