August 9th, 2012, 09:38 AM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja 250 Posts: 33
Question about the chain...
Soo... I've put about 4000 miles without cleaning it or lubing it
I bought chain cleaner and lube the other day and will be getting a rear stand soon. I know it is terrible of me that I neglected my chain and so I was wondering how bad is it? I know it shouldn't look anything like the image had I cleaned it once in awhile... So should I just replace it? Was I ever close to dying from the risk of the chain just breaking while on the road? ;___; Also, I know what you're probably thinking... I'm an idiot and I should sell my ninja :l |
August 9th, 2012, 09:41 AM | #2 | |
Join Date: May 2012 Motorcycle(s): Ninja 250r 2012 Posts: 60
Looks like new!
Rah |
August 9th, 2012, 09:45 AM | #3 |
if you keep treating it like that, expect to replace it around 13k, something like that.
No worries. Just clean it and lube it every other tank (or every 3rd tank) of gas and you'll be fine Posted via Mobile Device |
August 9th, 2012, 09:50 AM | #4 |
OH thank goodness! I will definitely do that! Thank you sir
August 9th, 2012, 09:52 AM | #5 |
August 9th, 2012, 09:53 AM | #6 |
Haha yea bro you should be fine! just clean it with me! haha its easy less than 5 mins
Rah |
August 9th, 2012, 09:59 AM | #7 |
August 9th, 2012, 10:01 AM | #8 |
That's what happens when I'm government property =[. Saturday bro! well kick it
Rah |
August 9th, 2012, 12:34 PM | #9 |
dont believe these people.
the only way to know if you need a chain is to see the actual condition of the chain performance wise. looking at how much rust is on the outside isnt going to tell you **** except that you dont take care of it. any binding links == get a new chain. 4000miles with no chain maintenance i would expect that chain is stretched and has bound links. it probably sounds rough when you ride and has a weird jerky feeling
August 9th, 2012, 12:36 PM | #10 |
also theres no indication of sprocket wear with the photo you posted. if the sprockets are worn (if the chain is worn, chances are the sprockets are worn) then you need to replace those if you replace your chain otherwise the worn sprockets will just cut into your nice new chain and stretch it out quicker
August 10th, 2012, 04:03 PM | #11 | |
Chain Maintenance Question | dcj13 | General Motorcycling Discussion | 10 | January 27th, 2014 04:08 PM |
Chain Question | checho323 | General Motorcycling Discussion | 21 | December 21st, 2012 10:36 PM |
Chain question | RyderRider15 | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 18th, 2012 09:16 PM |
Another Chain Question | Sailariel | 2008 - 2012 Ninja 250R Tech Talk | 2 | January 20th, 2009 05:30 PM |
Chain question | Sailariel | 2008 - 2012 Ninja 250R Tech Talk | 2 | January 10th, 2009 08:46 PM |
